The time now is Fri May 03, 2024 5:48 am
Island Raiders (2-3)
Moderators: Dawn of the Tiberium Age Staff
PostPosted: Sun Dec 02, 2012 3:33 pm    Post subject:  Island Raiders (2-3) Reply with quote  Mark this post and the followings unread
Name: Island Raiders (formerly Threeland)
Player: 3
Naval: yes
Size: 96x94 (see preview) -> 130x137 -> 161x187
Map size raised during a match after fulfilling a secondary objective.
Megamap preview
 Filesize:  1.89 MB
 Viewed:  3038 Time(s)
Last edited by Lin Kuei Ominae on Thu May 16, 2013 7:55 am; edited 1 time in total
PostPosted: Sun Dec 02, 2012 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like this'll provide some nice naval battles Smile
Those Apaches aren't properly centered on the helipads though. I know you can't properly do that to begin with when you try to place Apaches on the helipads in FinalSun, but you could get around that issue if you make a clone of the helipad, give it HoverPad=true and also add [General] PadAircraft=APACHE,x to the map's code.
PostPosted: Sun Dec 02, 2012 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's no problem. Since they are placed manually, they are in area guard mode. Thus as soon as a player gets close to them, they start, attack the player and when they land, they are perfectly centered.
So it's only an issue on the preview, but ingame you wouldn't notice that, since you can't see them before their first take off. Wink
And there are orcas and apaches, so hoverpad can't be used as it allows only one aircraft to be preplaced.
PostPosted: Sun Dec 02, 2012 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Name suggestions: Baypack, Sea of Serenity, Bermuda Triangle, The Gyre, Island Robbers (pun on Island Hoppers).
PostPosted: Sun Dec 02, 2012 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bermuda triangle could work.
On a different note: would it be good if i add neutral hovercrafts that allow infantry transports from each players island to each other players island?
PostPosted: Sun Dec 02, 2012 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
To be honest I think that neutral hovercrafts would be kinda pointless. Infantry traveling on their own will get mowed down easily as soon as they set foot on shore, meaning you're much better off if you just send several air transports (some carrying infantry, some carrying tanks).
I've personally never been able to make proper use of the neutral hovercrafts on any maps they were present on.
By the way, I was thinking it might be interesting to make the AI build ships instead of tanks on this map, but judging from the layout it unfortunately seems a bit too likely that those ships will just get stuck...
PostPosted: Sun Dec 02, 2012 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well the hovercrafts would allow some early scouting with infantry and maybe even doing some surprise attacks. Since they don't harm and only add some detail I think I'll add them anyway.
On Tiber these really are only some detail, though one of them is very useful to get early access to one of the civil tech outposts.
On Dantes Desert they will be much more useful in the next version. Especially at conquering the center island.
The AI will be a bit problematic, since the map still allows ground battles (once the player got access to the bigger map sizes)
I think this is really better played against humans only. It would be a pain to code a good working AI.
Though if the AI would build ships for defense only, it would at least make it not 100% boring to fight against them.
PostPosted: Mon Dec 03, 2012 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Neutral hovercraft seem a little contrived.
PostPosted: Mon Dec 03, 2012 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Little Europe! xD
[ Time: 0.1610s ][ Queries: 14 (0.0119s) ][ Debug on ]
