The time now is Fri Apr 26, 2024 6:56 pm
ParseMIS -- D2k MIS parser written in C#
Phrohdoh
PostPosted: Thu Feb 26, 2015 7:03 pm    Post subject:  ParseMIS -- D2k MIS parser written in C# Reply with quote  Mark this post and the followings unread
Source Code!
Currently the only output is whether or not the MIS is a test mission (designed for specific reasons by Westwood), though all of the data is parsed and available for you to do whatever you'd like with it.
I have also attached a pre-built assembly.
OS X / Linux / Windows
packaged.zip
Be sure to read the readme.
 Filename:  packaged.zip
 Filesize:  3.86 KB
 Downloaded:  16 Time(s)
FunkyFr3sh
PostPosted: Thu Feb 26, 2015 9:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, gonna check it out soon. Did you figure the values out on your own or did you use the .mis editor from mvi as base? There were still some unknown values i think, some guy was able to modify the file and the ai started to build completly different things and became much better. I didn't look into that file yet at all actually #Tongue
Phrohdoh
PostPosted: Thu Feb 26, 2015 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
This parser has 2 Unknown value fields (so I know nothing more of their content, if you know something let me know!) so I assume I've uncovered nothing new.
I used the data from d2kplus, which actually contains a typo in the table.
The Entry Count column for the Events row should be 64 (decimal), not 0x64 (which is 100 in decimal).
Suggestions and research very welcome. Smile
FunkyFr3sh
PostPosted: Fri Apr 17, 2015 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Phrohdoh
PostPosted: Sun Jan 03, 2016 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey FunkyFr3sh, I am not actively but if someone has more information I can certainly spend some time updating this.
Your link is 404 for me, could you try hosting that data elsewhere?
FunkyFr3sh
PostPosted: Tue Jan 05, 2016 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I wrote a tool that could modify almost every value, we have like 99% identified. Klofkac from forum.dune2k.com was spending a lot time to write down the findings and added support to his editor. You can find everything you need in his github repo, especially this file here is interesting https://github.com/jkoncick/D2kEditor/blob/master/config/mis_ai.ini
[ Time: 0.1508s ][ Queries: 13 (0.0106s) ][ Debug on ]
