The time now is Fri Apr 26, 2024 9:07 am
Problem with LaserFences
Post new topic   Reply to topic Page 1 of 1 [4 Posts] Mark the topic unread ::  View previous topic :: View next topic
Kamuix
PostPosted: Thu Dec 18, 2014 11:07 pm    Post subject:  Problem with LaserFences Reply with quote  Mark this post and the followings unread
I had it going before but than I lest and came back to having to set it up and it crashes Sad It doesn't crash when I place the first post, it's when I place the post that adds the sections.
The first Ini building listed is the section the second is the post itself if you need to see that
Thanks!! for any help
Running Ares 8.0
Laserpencesection ini:
[Nod LaserFence]
UIName=Name:NTWALL
Name=Nod Wall
BuildCat=Combat
Strength=800
Prerequisite=GAPILE
Armor=concrete
TechLevel=-1
Adjacent=8
Wall=yes
Sight=1
Selectable=no
Insignificant=yes
Nominal=yes
Owner=French
AIBasePlanningSide=0
Cost=100
Points=5
Repairable=false
Explosion=TWLT070,S_BANG48,S_BRNL58,S_CLSN58,S_TUMU60
ThreatPosed=0
BaseNormal=no
GuardRange=18
Image=laserpart2
RequiredHouses=French
LaserFence=yes
Laserpencepost ini:
[Wallpart11]
UIName=Name:NA3
Name=Test1
BuildCat=Combat
Strength=500
Armor=steel
TechLevel=5
Adjacent=12
ROT=10
Sight=12
DetectDisguise=no
Owner=British
AIBasePlanningSide=1
Cost=500
BaseNormal=no
Points=30
Power=0
Crewed=no
Capturable=false
DebrisAnims=DBRIS4LG,DBRIS4SM,DBRIS6LG
MaxDebris=2
MinDebris=1
Powered=yes
TurretAnimY=10
TurretAnimZAdjust=-20
ThreatPosed=30
IsBaseDefense=no
HasStupidGuardMode=false
ImmuneToPsionics=no
AntiInfantryValue=25
AntiArmorValue=10
Image=laserpost2
Selectable=no
RequiredHouses=British
LaserFencePost=yes
Powered=yes
IsBaseNormal=no
GuardRange=18
Prerequisite=Kamuix Radar
Zero18
PostPosted: Thu Dec 18, 2014 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure that you have building ID that have this?
Mod Leader and founder of World Domination
PostPosted: Fri Dec 19, 2014 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
[Nod LaserFence]
[Kamuix Radar]
Space in IDs, very bad decision.
RequiredHouses=British on the post while the section has RequiredHouses=French? illogical
Kamuix wrote:
[Nod LaserFence]
Wall=yes
If Ares hasn't changed the logic completely compared to TS, then this tells the game to use the special wall logic that searches in art.ini for the ToOverlay key to convert this into an Overlay.
Highly incompatible with special laserfence logic that wants to keep it as a BuildingType.
Kamuix
PostPosted: Fri Dec 19, 2014 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! It was the "wall=yes" afterall
[ Time: 0.1801s ][ Queries: 11 (0.0073s) ][ Debug on ]
