The time now is Fri Mar 29, 2024 7:36 am
Separate Harvesters for each side? Explained...
Post new topic   Reply to topic Page 1 of 1 [41 Posts] Mark the topic unread ::  View previous topic :: View next topic
christophski the great
PostPosted: Mon Jan 24, 2005 8:05 pm    Post subject:  Separate Harvesters for each side? Explained... Reply with quote  Mark this post and the followings unread
This is my first tutorial so I'm sorry if i do anything wrong.
Objective:
To create a different harvesters for GDI and Nod in TS.
First of all we will create the new harvester/s.
Near the top of the Rules.ini File there is  Section called:
******* Vehicle Type List *******
In this section add the name of the new harvesters voxel file (exculding extension)
Example:
48=WEED
49=GHUNTER
50=NHUNTER
51=YOURHARVESTERTAG ;Note: All In Capitals!!
Now go down to the
******* Vehicle types *******
Section, just bellow the definitions unit statistics.
The easiest way to do this bit is too clone the HARV entry, but you must change:
[YOURHARVESTERTAG]
Name=Your New Harvester's name
Prerequisite=GAWEAP,GAPROC  ;This is essential so that only GDI get this.
Image=  ;add the corresponding art.ini section tag here.
Dock=PROC,GAPROC  ;So that it can dock with GDI's refinery.
Owner=GDI  ;This is also essential so that only GDI get this.
Note: you must creat a corresponding art.ini tag, i wont tell you how because it is very simple.
Now go to the original harvester entry and change:
Prerequisite=NAWEAP,PROC
Owner=Nod
We will not be editing the HORV entry because unfortunately i have not yet found a way to give each side there own HORV. (Believe me it's not as simple as it sounds.)
Go to:
******* Audio / Visual rules *******
and change:
UnloadingHarvester=HORV ; harvester image to use when unloading tiberium
to
UnloadingHarvester=
so that the harvester image doesnt change when it goes in the refinery.(this is required because of the TS engine.)
Now we will go Up to the:
******* AI Controls *******
find the bit that says
BuildRefinery=PROC      ; refinery ratio based on these buildings
And change it too:
BuildRefinery=PROC,GAPROC      ; refinery ratio based on these buildings
This will make sure the AI can build the new GDI refinery.
Now to add a new refinery for GDI, this needs to be implemented so that when you build it you will get GDI's harvester and not Nod's one.
Go to the:
; ******* Building Type List *******
section, and add on the end the tag for your new refinery.
Example:
246=UFO
247=AMMOCRAT
248=GAPAVE
249=GAGREEN
250=GAPROC
Now down to the:
******* building types *******
section.
We will make a entry for GAPROC (or the name of your refinery)
the easiest way is to once again copy the original, so copy [PROC].
We must edit edit these bits:
; Tiberium Refinery
[GAPROC]  ;corresponding tag (GAPROC is an example)
Name=Your Tiberium Refinery's Name
...   ;note: unless you have a new one keep the Image= tag the same.
Prerequisite=GAPOWR  ;so GDI can only get it.
FreeUnit=YOURHARVESTERTAG  ;so you get the new harv when you build the refinery.
Owner=GDI  ;This is essential so that only GDI get this.
Now go up to the original refinery entry([PROC])
and change:
Prerequisite=NAPOWR  ; so only nod get this refinery.
Owner=Nod  ; so only Nod can get it.
next go to the GASILO entry and do we what we did to the refinery (i'm not gonna tell you because it should be obvious what to do now, e.g copy entry , make so only GDI or Nod can get it).
Search though the .ini looking fo stuff the GDI get which has prerequisite=PROC, and change it accordingly.
It should now be ready!
ps. If i missed anything, please tell me, cos i am very tired and my brain isnt working, i never knew it was soo tireing writing a tutorial.
Singer-Songwriter Christie Isaac
The DvD
TiberiumWeb.com Webmaster
PostPosted: Mon Jan 24, 2005 9:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Problems:
You can make the AI build GAPROC, but not have them build new harvesters. (the new ones)
Sk8erkid
INSANE
PostPosted: Mon Jan 24, 2005 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
They wont build them or they wont use them?
The DvD
PostPosted: Mon Jan 24, 2005 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
The can't build them. There is no ai.ini thing for new harvesters, it always tries the default one.
XxpeddyxX
PostPosted: Tue Jan 25, 2005 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That's pretty sad  Crying or Very sad
cant you like make 2 types of harvys like 1 gdi schemed 1 nod schemed and make a mix file and put 1 in sidexx and the other 1 in sidexx?
ayylmao on Discord
XxpeddyxX
PostPosted: Tue Jan 25, 2005 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
OR...does that only work with SHP files?
ayylmao on Discord
Gangster
PostPosted: Tue Jan 25, 2005 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Only with GUI SHP...
PostPosted: Tue Jan 25, 2005 6:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh yeh, i didnt think of that, i am totally useless when it comes too AI.ini
Clarkson
PostPosted: Tue Jan 25, 2005 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
AI.ini is a thing i try to avoid(alot.) i often just replace/add units to triggers. however i belive their is a tag in their for HARVESTERS in their. i know their is one for MCVs.
The DvD
PostPosted: Wed Jan 26, 2005 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a Harvester= tag. But it only accepts one entry.
Jah
PostPosted: Wed Jan 26, 2005 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Can't we force AI to make another, side-specific harvs instead of normal harvs via ai scripts, teams taskforces etc?
in 2009 to Florence. Viva Italia!
The DvD
PostPosted: Wed Jan 26, 2005 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
That's easy. One problem, they won't put the harvesters to work.. as unlike in RA2, newly built harvs in TS do not automatically start looking for Tib.
PostPosted: Wed Jan 26, 2005 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
But can't you make a script with 11,9 (Action -> Harvest) in the script? I think it works...
The DvD
PostPosted: Wed Jan 26, 2005 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I knew you would say that. I think I tried that and it did not work.
PostPosted: Wed Jan 26, 2005 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
this will sound Uber n00bish but is there no way to make them automatically look for tib?
Clazzy
Karma Police
PostPosted: Wed Jan 26, 2005 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can we make it attack a tiberium tree or the adjacent area, causing it to harvest?
The DvD
PostPosted: Wed Jan 26, 2005 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, as tiberium (trees) do not pose any thread or don't have a weapon..
XxpeddyxX
PostPosted: Thu Jan 27, 2005 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Dude this is confusing
ayylmao on Discord
The DvD
PostPosted: Thu Jan 27, 2005 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
For you, maybe #Tongue
Ackron
PostPosted: Thu Jan 27, 2005 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
im confused too.
The DvD
PostPosted: Thu Jan 27, 2005 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps that is because confusion is a part of your life?
Anyway, in short:
You can enable separate harvesters/refineries in TS perfectly fine, by simply making new ones and assigning the new ones to (preferably) GDI only, and restricting the old ones to Nod.
All fine and dandy, but remember the AI builds extra harvesters when they don't have enough? To determine what unit they need for that they look at the HarvesterUnit= tag. The problem is that it only accepts one value, and will ignore any others. So you'll have GDI AI building Nod harvesters. You can ofcourse make them able to dock at eachother's refineries but it will still look odd.
BTW, in RA2 the HarvesterUnit= tag accepts multiple values (or 2)
Clazzy
Karma Police
PostPosted: Thu Jan 27, 2005 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, maybe we can get that altered with a new game.exe file?
PostPosted: Thu Jan 27, 2005 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
At the moment, we should disconsider this possibility, Clazzy, since we have no one to do that for us...
Clazzy
Karma Police
PostPosted: Thu Jan 27, 2005 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
We can still hope...
Gangster
PostPosted: Thu Jan 27, 2005 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Damn. How could you be so passive? Even i whant to look at assembler code (am not a programmer at all) to search... or to try to search at least. Maybe you need ask Pad (aka pd) what soft he is using for, maybe he can give some hints. I bet non of you even havnt tried yet.
Tratos
PostPosted: Fri Jan 28, 2005 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Would there not be a way to script harvesters to automatically default to guard mode, would that not cause them to search for tiberium?
The DvD
PostPosted: Fri Jan 28, 2005 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
No, guard mode will not work, just like the 'Harvest' mode.
Ickus
PostPosted: Sat Feb 26, 2005 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
The only way I seen the AI use a different harvester if it gets it via FreeUnit=
Delirium..
The DvD
PostPosted: Sun Feb 27, 2005 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I've used that to make them have Advanced harvesters in TSTW (It's cheating but the only way)
John Galt
PostPosted: Sun Feb 27, 2005 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
One more problem I noticed:
[HARV]
Dock=PROC,GAPROC
As long as PROC exists, they never dock in GAPROC automatically, regardless of which is closer. They only go to GAPROC when, in their first moment of returning, all PROC are occupied unloading other harvesters.
SeySayux
Cyborg Specialist
PostPosted: Fri Aug 05, 2005 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
This is old topic reviving, but i also tried it and found other problems than noticed here...
I let the normal harvesters what they are, but i've added a chrono harvester for GDI, with it's own refinery, and a war harvester for Nod, also with it own refinery. It worked perfectly, only for the AI, it builds and uses it. But for human players, the Chrono/war harvester refuses to harvest.....
I use a Unix-based system, that means I'll get laid as often as I have to reboot.
Morpher
PostPosted: Fri Aug 05, 2005 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes this is old topic reviving
SeySayux
Cyborg Specialist
PostPosted: Fri Aug 05, 2005 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have added something usefull, the ai works in my example....
Morpher
PostPosted: Fri Aug 05, 2005 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes we have notice you have leaved,well you have made the sentence wrong for a start.Now do what your name says and leave so we can have the party,erm I mean get back to the topic.
Jah
PostPosted: Sun Aug 07, 2005 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Making AI build a new subterranean harv for Nod:
*RULES*
[NEWHARV] ;is a building type
Image=None
FreeUnit=NHARV
Armor=none
Strength=0.01
FirestormWall=yes ;the harv appears on the cell, not next to it
TechLevel=-1 ;you can't build it
AIBuildThis=yes ;ai can. since the building self-destructs, ai will build it repeatedly.
*ART*
[NEWHARV]
Buildup=DIG
Foundation=1x1
ActiveAnim=SELF_DESTR
[SELF_DESTR]
;make sure it is short in order not to damage the vehicle harv
Damage=0.1
And here's art and codes for the harvester itself
Styledatol
Flamethrower
PostPosted: Fri Aug 18, 2006 12:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... seperate harvesters work in that russian mod...
The AI is building them and all..
GameMaster0000
PostPosted: Tue Sep 14, 2010 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for bump, but may be useful
In my own mission, I must make AI build his own harvester due they use custom refinery.
First script, I use go to way point ##-> do this... harvest result is harvester play harvest animation on blank field!!!
Next, I use go to way point ## on point that have tiberium field-> do this... harvest, result is harvester play harvest animation on that but not harvest it.
Next, I use only go to way point ## on point that have tiberium field but result is harvest start harvest tiberium with no problem.
Then, I use only go to way point ## on blank field it will move to nearest tiberium and start harvest.
Last, I use only success script. Result is it will move to nearest tiberium and start harvest.
It's mean that AI harvester will find tiberium to harvest automatically when it get create and not have other order.
Tiberian Sun : True Power - Reality Power Of 5 Factions...
PostPosted: Wed Sep 15, 2010 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mission scripts ain't that useful in Skirmish mate Wink
GameMaster0000
PostPosted: Wed Sep 15, 2010 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
But script is do exactly same as AI use in AI.ini do, isn't it?
PostPosted: Wed Sep 15, 2010 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Correct, but you forget 1 thing: not all skirmish maps have the waypoints you mention.
GameMaster0000
PostPosted: Wed Sep 15, 2010 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
This Wink
[ Time: 0.1902s ][ Queries: 11 (0.0105s) ][ Debug on ]
