Posted: Mon Dec 16, 2002 2:51 am Post subject:
XCC Mixer
How do I convert a SHP that has many images in it from Tiberian Sun and convert it to pcx. I want it to be converted so that it copies each frame to a seperate PCX file. I once did this with the Cyborg.shp, but I forgot how I did it. _________________
Posted: Mon Dec 16, 2002 3:37 am Post subject:
select the correct pallete:
- anim.pal for animations,
- unitsno.pal for infantry and voxels
- cameo.pal for cameos (yet, cameos is not your case, since it only includes one picture).
After selecting the pallete, right click the .pcx file of the unit you want finishing with 0000.pcx. Following numbers would finish as 0001.pcx, 0002.pcx, etc...
click in convert/copy to/as SHP (TS) and it's done.
To convert shp files into pcx, select the correct pallete, right click the .shp file you want and copy as pcx and it's done. Note it's NOT copy as pcx single, it's only copy as pcx. I think that answers your question. QUICK_EDIT
I tryed that but its not working. Im trying to convert the Sam site supgrade which is called "gactwr_s.shp in the snow.mix. Im using the unitsno.pal, which is the correct pallete. I did as you said and right clicked on it and chose, "Copy as PCX." And at the bottom of the XCC mixer it says, "Copy gactwr_d succeeded." Also my directory where things are copied is in my XCC mixer folder, but it's not thier. HAve any ideas on what could be the porblem? My current verison of the XCC mixer is 1.19. Also if it wouldnt be too much trouble, could you or someone else convert it for me and put it in a zip file, that way I could just download it.
Just to let you know im working on the Missile Defense Tower. _________________
Hey, Banshee, u're not l33t... Every time I make a unit I use unittem.pal from RA2. The colors are same, but the transparency is blue, instead of black. _________________ in 2009 to Florence. Viva Italia! QUICK_EDIT
Posted: Tue Dec 17, 2002 2:35 am Post subject:
- No difference at all, like you said, "transparency"........ transparency doesnt appear in the game and TS was talking about making SHPs for Tiberian Sun, so I'm not wrong here. QUICK_EDIT
