Posted: Sat Sep 25, 2004 2:52 am Post subject:
[3.0,1] Program doesnt load if any other OS tool is opened!
OS SHP Builder won't load up if you have any OS tool opened like:
- OS Voxel Viewer
- Voxel Section Editor III
- OS HVA Builder
- etc...
The only way to bypass this problem is to save your voxel, hva or whatever you are editing in the other OS Tool. Then, close it, open the SHP Builder and open the tool you were using again...
I'll work on a fix for this problem for 3.2
Thanks Stucuk for the tip. Last edited by Banshee on Tue Oct 26, 2004 7:00 pm; edited 1 time in total QUICK_EDIT
Posted: Sun Sep 26, 2004 12:07 pm Post subject:
I also realized that...
However, I did not have that with beta 4, so it must be a conflict with something that was added/changed after that. Maybe that helps finding the problem. QUICK_EDIT
Posted: Sun Sep 26, 2004 1:17 pm Post subject:
I know where the problem is located. In Beta 5, I added a feature to, once you open a file associated with the OS SHP Builder, it would check if there is another copy opened and, if it has, it would open the file in the opened copy and close itself to avoid multiples builders opened at the same time. _________________
Mods, Mods Support, Public Researchs, Map Archives, Tutorials, A Friendly Community and much more. Check it out now! QUICK_EDIT
Each program i make i name the main form(window): FrmMain, banshee's thing to check if a previous copy is open checks for programs with FrmMain in them, thus the problem. _________________ Free Map Editor - Game Requirements - Stucuk.Net QUICK_EDIT
