The time now is Fri Mar 29, 2024 5:18 am
Combat Lighting
Post new topic   Reply to topic Page 1 of 1 [17 Posts] Mark the topic unread ::  View previous topic :: View next topic
Tratos
PostPosted: Thu Jul 15, 2004 10:01 pm    Post subject:  Combat Lighting Reply with quote  Mark this post and the followings unread
This tutorial will teach you how to change the size and color of the light flashes you see when certain weapons explode.
For the purposes of this tutorial i will be adding a green glow to the Desolator's Rad Beam.
Firstly, find the weapon you want to add the light flash to. In my case it is [RadBeamWeapon]. Add the code
Bright=yes
to the end of the weapons code, this tells the game to draw the light flash where the weapon hits. You may see this tag on some warheads too, but it is ignored for them and only works when included in the weapon code.
Next, find the warhead of the weapon, I am using [RadBeamWarhead].
I will be adding a green flash to the warhead, but if you want the light flash to be white you can skip this part of the tutorial.
Add the following code to your warhead,
CLDisableRed=
CLDisableBlue=
CLDisableGreen=
The values that you should use are true or false. This is the complicated bit. The tags above are used to tell the game to remove certain colours from the light flash. In my case i used the following code,
CLDisableRed=true
CLDisableBlue=true
CLDisableGreen=false
to make the flash green. However, you can make it a multitude of colours using different combinations. For example, disabling red, but leaving blue and green enabled will give you a yellow flash. Unfortunatly you are restricted by the three colours you see above, and as you cannot set values other than on or off you can only have a few select colours.
You can also use the following code on the warhead,
CombatLightSize=
to determine the radius of the light flash, the value should be a percent value (e.g. 50%, or 200%). Experiment with different values to see what you get.
And that's it, using this tutorial you should be able to add different coloured flashs to your explosions. Good ideas for their use are blue flashes on tesla bolts, yellow flashes on the over-powered yellow tesla bolts, red flashes for fire weapons, green flashes for radiation weapons etc...
Below i have listed all the possible combinations of colour:
CLDisableBlue=true
CLDisableGreen=true
=Red Glow
CLDisableRed=true
CLDisableGreen=true
=Blue glow
CLDisableRed=true
CLDisableBlue=true
=Green glow
CLDisableGreen=true
=Pink glow
CLDisableRed=true
=Turquoise glow
CLDisableBlue=true
=Yellow glow
Mike
PostPosted: Fri Jul 16, 2004 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Does this work for TS too?
The DvD
TiberiumWeb.com Webmaster
PostPosted: Fri Jul 16, 2004 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wouldn't think so...
Tratos
PostPosted: Fri Jul 16, 2004 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
No im afraid not.
Tratos
PostPosted: Sat Jul 17, 2004 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: I have added a list of all the possible combinations and athe colours they create.
The DvD
PostPosted: Sat Jul 17, 2004 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Lol, another example of how stupid RA2's programmers were..i mean, why start disabling colours (and having only 6 different possible end results) instead of just specifying a R,G,B value??!
Clazzy
Karma Police
PostPosted: Sat Jul 17, 2004 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Because maybe they only had needs for specific colours?
Tratos
PostPosted: Sat Jul 17, 2004 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
The only use of it YR is the red flash on the mirage weapon. Besides you have practically all the colours you need there.
Kravvitz
PostPosted: Sun Jul 18, 2004 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
You've got to remember that if they didn't use it in game or plan at some point to use it ingame, they didn't code it and for a lot of the stuff they coded, they did it as fast as possible. TS/FS and RA2/YR are modable, but they weren't made with that in mind.
Check out my FAQ and Modding Info Page.
Community Links Page
http://www.dynamicsitesolutions.com/
View user's profile Send private message Visit poster's website Skype Account Yahoo Messenger Account AIM Address
The DvD
PostPosted: Sun Jul 18, 2004 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
No but specifying a RGB value seems easier to me. Anyway...
Tratos
PostPosted: Sun Jul 18, 2004 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, but it's lighting, they couldn have used rgb for light posts in TS but they didn't, instead you have red green or blue intensity. It must be due to the way light is produced by the game.
The DvD
PostPosted: Sun Jul 18, 2004 7:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm you have a point there, smarty Wink
Tratos
PostPosted: Sun Jul 18, 2004 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Razz nuh nuh nee nuh nuh...
John Galt
PostPosted: Mon Jul 19, 2004 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
One point: CLDisableGreen= should be true in all but the first example.
Tratos
PostPosted: Mon Jul 19, 2004 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, fixed.
Rattuskid
Sergeant
PostPosted: Tue Jul 27, 2004 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hate to revive this, but would disabling them all give one a black 'glow'?
View user's profile Send private message Skype Account AIM Address
Tratos
PostPosted: Tue Jul 27, 2004 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
On paper, yes it should. In practice, im not sure having never tested that combination. If you try it and it works, tell me and add the combination to the tutorial.
[ Time: 0.1631s ][ Queries: 11 (0.0094s) ][ Debug on ]
