The time now is Sat Apr 20, 2024 12:46 pm
GDI Vehicles
PostPosted: Tue Mar 24, 2015 10:22 pm    Post subject:  GDI Vehicles Reply with quote  Mark this post and the followings unread
[ GDI Infantry ] - [ GDI Vehicles ] - [ GDI Aircraft ] - [ GDI Structures ] - [ GDI Dawn Units ]
Harvester
GDI's Tiberium Harvesters are slower than the Nod counterpart but have a much higher load capacity and are entirely amphibious allowing them to access isolated Tiberium with ease.
  • Cost: 1400
  • Requires: War Factory, Tiberium Refinery
  • Purpose: Resource Collection
  • Storage: +35
  • Armour: Very Heavy
  • Speed: Average
  • Crushes Infantry: Yes
  • Tech Level: 1
Mobile Repair Vehicle
GDI Mobile Repair Tanks are large units supplied by any Repair Bay that is constructed on the battle-field. These large vehicles can repair even the largest units on the battle-field in a matter of moments. In order for a vehicle this large to maintain a necessary movement pace, heavy armour had to be sacrificed.
  • Cost: 1000
  • Requires: War Factory, Repair Bay
  • Primary Ability: Repair Grappler
  • Purpose: Support
  • Armour: Average
  • Speed: Average
  • Tech Level: 6
Mobile Sensor Vehicle (MSV)
Developed in an attempt to combat the Brotherhood’s increasing use of Stealth technology, the Mobile Sensor Vehicle (MSV) has become a common sight within GDI controlled zones. The first prototypes were ordinary surveillance vehicles, upgraded with the best sensory equipment of the time. However, as Nod's stealth technology became ever more sophisticated, these M.S.V. models could not meet expectations and were soon rendered obsolete.
After forming an alliance with GDI, the mega corporation GloboTech expressed mutual interest in depriving Nod of its advanced optical camouflage. With GDI experience in combating previous Lazarus fields and GloboTech’s resources it was only natural that they would pool together to develop the next generation mobile sensor platform. Propelled by GloboTech’s patient hover technology, the MSV can be deployed virtually anywhere. This design proved to be an instant success.
In order to operate, the MSV must first be deployed into a Sensor Outpost. Only then can the vehicle accurately detect and track enemy movement. The Sensor Outpost reveals any units, whether they were shrouded, cloaked or subterranean, within its sensor radius. If the Outpost operators detect any enemy units within range, the crew will sound an alarm alerting any nearby troops of the danger. The M.S.V. is not entirely helpless whilst mobile, as it’s armed with a fixed 50.cal machine gun to defend itself.
  • Cost: 950
  • Requires: War Factory, Communications Centre
  • Primary Ability: Sensor
  • Primary Weapon: Anti-Personnel Machine Gun
  • Purpose: Support
  • Firepower: Low
  • Armour: Average
  • Speed: Average
  • Tech Level: 6
Mobile Construction Vehicle (MCV)
The foundation of any base starts with the Mobile Construction Vehicle (MCV). Able to deploy itself into a fully functioning Construction Yard, the MCV is a highly prized piece of equipment for the GDI.
To deploy the MCV, select it, then double-click. If you get a "no deploy" cursor, something is blocking deployment of the unit. Move any other vehicles and infantry away from it, or move it away from trees or rocks that would prevent deployment.
  • Cost: 2500
  • Requires: War Factory, Technology Centre
  • Purpose: Construction
  • Speed: Slow
  • Tech Level: 7
'Skimmer' LHV
GDI Skimmers are lightning fast hover units armed with rocket pods capable of dishing out damage to light armour and bringing down light aircraft.
  • Cost: 400
  • Primary Weapon: Rocket Pods
  • Purpose: Anti-Aircraft, Anti-Armour
  • Firepower: Low
  • Armour: Light
  • Speed: Very Fast
  • Crushes Infantry: No
  • Tech Level: 2
'Kazuar' Walker
The Kazuar ISW (infantry support walker) was the first mass produced combat biped utilised by the GDI rebels during the insurrection conflict. These lightly armoured but high speed all terrain vehicles are equipped with dual 50.cal miniguns, gearing them towards infantry suppression. However, the Kazuar is also capable of engaging other lightly armoured targets.
In addition, the mechanised walker’s cockpit is large enough to carry two passengers, allowing the vehicle to act as a light infantry transport.
  • Cost: 500
  • Primary Weapon: Twin GAU-19 Miniguns
  • Purpose: Anti-Personnel, Transport
  • Passengers: 2
  • Firepower: Average
  • Armour: Average
  • Speed: Average
  • Tech Level: 2
'Goliath' Heavy Tank
The M2 Generation IV Battle Tank, better known as the Goliath, forms the spearhead of GDI armoured battalions. Manufactured by Globotech the Goliath is derived from the Leopard 2 and X-66A Mammoth Tank, and has successfully replaced the ageing M1 Abrams as GDI's primary battle tank.
Standard armaments are over and under smoothbore 120mm tank guns that fire special Kinetic-Explosive shells designed to puncture even the toughest armour and subsequently detonate, dealing critical damage to the interior of an enemy vehicle. However such high-precision weapons are often inefficient against fast and mobile infantry and treacherous Tiberium fauna. The Goliath has earned several nicknames from GDI veterans the most popular being Mammoth JR. and Mini-Mammy.
  • Cost: 900
  • Primary Weapon: 120mm Anti-tank Gun
  • Purpose: Anti-Armour
  • Firepower: High
  • Armour: Heavy
  • Speed: Slow
  • Tech Level: 5
'Scatterpack' Vulcan Walker
The Scatterpack is GDI's main anti-air unit. The Scatterpack is armed with an array of rapid fire Vulcan Cannons capable of ripping infantry and aircraft to shreds in a matter of seconds. Due-to the heavy Machinery, the Scatterpack isn't very fast but can easily defend itself against infantry and aircraft and is also quite effective against heavy armour in large groups.
  • Cost: 700
  • Primary Weapon: Anti-Personnel Cannons
  • Secondary Weapon: Anti-Aircraft Cannons
  • Purpose: Anti-Aircraft, Anti-Personnel
  • Armour: Light
  • Speed: Average
  • Tech Level: 6
'Wasp' APC
Due to the ever increasing thorn infestation, conventional amphibious assaults were deemed too risky. Commissioned to counter this problem the 'Wasp' APC was designed to circumvent underwater thorn infestations by hovering safely above it.
Capable of carrying up to a total of eight soldiers across the battlefield the Wasp is more than just a troop transport. These APC's are armed with a small Electro-Magnetic beam weapon that can temporarily disable a single enemy vehicle or structure at a time, the effect is very short-lasting however due-to the high energy demands on such a small vehicle.
Unfortunately for GDI severe Tiberium related weather such as Ion Storms are becoming more frequent causing yet more problems for GDI's amphibious assault program.
  • Cost: 1100
  • Primary Weapon: Low Energy EMP Turret
  • Purpose: Transport, Support
  • Passengers: 8
  • Armour: Average
  • Speed: Fast
  • Tech Level: 7
'Bullfrog' MLDS
Built upon an instantly recognizable walker chassis, the Bullfrog fills the gap left by the old M270 MLRS used during the previous war. However unlike the M270, the squat quadruped sports an electronically assisted Multiple Launch Discus System in place of a more conventional rocket payload. Each MLD volley consists of five unguided high explosive discus rounds, that are highly effective against personnel and fortified structures. In addition, Bullfrog munitions are able to skip for increased range just like the smaller Disc-thrower grenade.
While the artillery walker has proven to be effective for the role it was assigned, the Bullfrog has seen it's fair share of criticism by field commanders. Most of these criticisms are typical for an artillery while others are unique to the vehicle itself. It's minimum range, light armour, lack of a turret and of course it's slow pace and over-designed locomotive system. Due to these drawbacks it is advised that Bullfrog packs operate with an escort.
  • Cost: 1300
  • Primary Weapon: Multiple Launch Discus System
  • Purpose: Support, Anti-Personnel, Anti-Fortification
  • Firepower: High
  • Armour: Average
  • Speed: Slow
  • Tech Level: 7
'Phalanx' Mobile Railgun
Before the second Tiberium War, railguns were heavily researched by GloboTech as means to defend from the ever-increasing meteor storms that threatened densely populated areas. The railguns were designed to shatter the meteors while in higher atmosphere; their fragments would be small enough to disintegrate before reaching the ground.
When the war broke loose between the two superpowers, GDI immediately saw the potential in these destructive weapons. They commissioned GloboTech to produce a single prototype which, unfortunately, was discovered and captured by Nod when they raided a GloboTech research facility. Owing to the heroic actions of a GDI Commando squad, the facility was liberated and the prototype secured.
GDI continued to further improve the design in their own R&D facilities, and eventually the Railgun Platform was finished, albeit it entered the battlefields late to the war. This heavy, dual-purpose vehicle can engage both air and ground targets with devastating accuracy. The weapon is designed to utilize kinetic energy rather than explosive rounds, making it effective against heavy armour but poor against small targets like infantry. However, it must deploy in order to target air units. This position makes the vehicle most vulnerable, so a company of Phalanx Railguns or other ground units is recommended to defend the deployed tanks.
  • Cost: 1200
  • Primary Weapon: Anti-Armour Railgun
  • Secondary Weapon: Anti-Aircraft Railgun
  • Purpose: Support, Anti-Armour, Anti-Structure, Anti-Aircraft
  • Firepower: High
  • Armour: Light
  • Speed: Slow
  • Tech Level: 7
Behemoth
Equipped with dual Metal Storm Howitzers consisting of sixteen 155.mm barrels, the Behemoth is the pinnacle of GDI's artillery divisions. Designed  over several years in tandem with Globotech and fielded shortly before the Emerald Peak Massacre, its state of the art design would later be used as the basis for GDI's Mammoth Walker. The initial practical tests were overseen by Colonel Nigel "Gunner" Grant, the GDI liaison in charge of the Behemoth's trial phase.
While the Behemoth is armed with an incredible payload and encased in heavy armour plating, it's helpless against aircraft and enemy attackers that have managed to get within its minimum range, as such it is advised that a protective escort be provided during combat operations.
Because of the high cost of tech and supplies, only three can be constructed at a time.
  • Cost: 2500
  • Primary Weapon: Dual Metal Storm Howitzers
  • Purpose: Support
  • Firepower: Very High
  • Speed: Very Slow
  • Tech Level: 9
'Mammoth' Walker
This hulking behemoth represents the pinnacle of GDI weapons research. More than a spiritual successor to the famous Mammoth Tank, the Armature tops every other ground unit in strength and firepower. Sporting dual railguns, it packs twice the punch a Phalanx Railgun does. It can defend itself from air strikes with S.A.M. batteries mounted on its back. Finally, the Mammoth Walker is fitted with an E.M.P. core. When activated, the device sends a circular, electromagnetic pulse, disabling any mechanical unit or structure, friend or foe, within its short range.
Because of the high cost of tech and supplies, only one can be constructed at a time.
  • Cost: 5000
  • Requires: War Factory, Technology Centre, Uplink Centre
  • Primary Ability: E.M.P. Blast
  • Secondary Weapon: Anti-Aircraft Missiles
  • Purpose: Special
  • Speed: Very Slow
  • Build Limit: 1
  • Tech Level: 9
ErastusMercy
PostPosted: Wed Nov 30, 2016 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Behemoth has been added to the GDI arsenal, voxel by erm, well me.
[ Time: 0.1974s ][ Queries: 11 (0.0086s) ][ Debug on ]
