The time now is Sat Apr 20, 2024 12:16 am
Soviet Psychic Sensor
Moderators: Global Moderators
Madin
Plasma Trooper
PostPosted: Fri Oct 17, 2014 2:57 pm    Post subject:  Soviet Psychic Sensor Reply with quote  Mark this post and the followings unread
Madin's Soviet Psychic Sensor
Files include all necessary XML, W3X, and texture files needed for editing and compilation.
Ready to use!
It is assumed that you have the C&C3 mod sdk and have been able to at least compile the sample mod. Check the included read me for permissions.
The format that I've packed the files in means that they are ready-to-compile, no XML work is needed at all.
This comes with a sample player power for you to try out.
You are expected to adjust the code to your needs, all I have added are the basics. Balance and fine tuning are up to you.
This uses Lauren's 'ObjectGenericHC.fx' shader file, which has been included in locations correct for both users of Bibber's RA3 based mod tools or those who still use the classic buildmod.bat.
You may re-distribute this package as long as all initial files, including this Read me and all uncompiled files, are included.
You may freely use, modify and improve all the graphical assets for any public mod as long as you give proper credits and it is not for any profit.
Primary credit: Madin (Model + Texture)
Secondary credit: Lauren (ObjectGenricHC.fx shader)
Public asset declaration
Ready to use: Yes
Sides: GDI
Portrait & Buttons: Yes
Shader: ObjectGenricHC
Build up animation: Yes
Damage textures: Yes
Damage 2 state: Yes
Destruction animation: Yes
Not so great, but you might find a use for it!
 Filesize:  1.79 MB
 Viewed:  3753 Time(s)
PsychicSensor.zip
 Filename:  PsychicSensor.zip
 Filesize:  4.47 MB
 Downloaded:  17 Time(s)
[ Time: 0.1564s ][ Queries: 14 (0.0093s) ][ Debug on ]
