The time now is Thu Apr 25, 2024 8:38 pm
XCC Mixer 1.47 Question
Zero18
PostPosted: Fri May 23, 2014 9:16 pm    Post subject:  XCC Mixer 1.47 Question Reply with quote  Mark this post and the followings unread
Is there a fast way to extract those files instead of doing it 1 by 1, and also is there a fast way to insert the files back into the mix with Mixer Editor?
PostPosted: Fri May 23, 2014 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's a middle coloumn.
PostPosted: Sat May 24, 2014 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
To extract multiple files at once, open the mix file you want to extract the files from in one pane, open the folder you want to extract the files to in the other pane, then select all files you want to extract in the pane where you opened the mix file, then right-click on one of those files and finally copy.
To insert multiple files at once you open the mix file you want the files to be inserted into and then simply drag and drop the files from windows explorer into XCC Mixer.
Zero18
PostPosted: Sat May 24, 2014 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Bittah!
[ Time: 0.1382s ][ Queries: 11 (0.0066s) ][ Debug on ]
