The time now is Wed Apr 24, 2024 12:47 pm
Getting Finalsun to use my mod files
Aydra
PostPosted: Tue Dec 24, 2013 10:30 pm    Post subject:  Getting Finalsun to use my mod files
Subject description: how?
I want Final sun to use my mod instead of Tiberian Sun game files. I changed the path 'Exe=" in FinalSun.ini to where my modded TS is but it still doesn't work. I heard someone say it uses the registry, where and how do i fix this?
MODDB Profile: http://www.moddb.com/mods/the-second-tiberium-war
Zaaz
Disk Thrower
PostPosted: Tue Dec 24, 2013 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know, but in the meantime someone resourceful answers, you could try to uninstall TS. If it can't find the reg key, I think it prompts you to select the path to the TS directory.
PostPosted: Tue Dec 24, 2013 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those who can disassemble the exe can probably give a better solution, but one way to fix this
-open the finalsun.exe with a hex editor
-search for "Software\Westwood\Tiberian Sun" (without quotation marks)
-change "Software\Westwood\Tiberian Sun" into "abcdefgh\abcdefgh\abcdefghijkl" (note that the edited string has the exact same amount of characters as the old one. Do not change any offsets.)
the registry key that finalsun searches for the game files doesn't exist anymore and this way you force finalsun to use the path from finalsun.ini
Aydra
PostPosted: Wed Dec 25, 2013 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome thanks it works now, but I have a question. What will happen if I change the path and it doesn't have the same amount of characters?
PostPosted: Wed Dec 25, 2013 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
you change the offsets of all the following bytes and this way completely mess up the program so it won't work anymore.
e.g. a function addressing a certain byte after this will then get wrong data
[ Time: 0.1215s ][ Queries: 11 (0.0074s) ][ Debug on ]
