The time now is Thu Mar 28, 2024 1:53 pm
Doom Desire November 2013 Update
Moderators: Global Moderators
mevitar
PostPosted: Sun Nov 03, 2013 12:34 am    Post subject:  Doom Desire November 2013 Update Reply with quote  Mark this post and the followings unread
Over half of a year has passed since the last news update of Doom Desire, this time it will be an Essence-exclusive news post.
At first a defense contractor, Essential Tech was the one behind the first successful counterattacks against the alien forces. As they were the only ones that seemed to capable to succeed, others soon joined, and this force became humanity's last hope.
Essence Hyperion Attack Craft Being heavy and bulky for an attack plane, it has a big power generator to generate plasma, used both for attack and to achieve flight.
Athena Hypersonic Interceptor Capable of achieving hypersonic flight, Athenas use lasers against ground targets, and against aiborne units a special kind of missiles, designed to combat Vintarid spacecrafts.
Essence Tartarus Subterrene Fully autonomous, these machines melt through rock with ease, emitting very little noise and vibrations. Their tunneling speed also leaves conventional tunnel boring machines far behind.
Icarus AMS Basic AA unit for the Essence. Using a modified Hummer chassis and fully automated, which helps Essence a lot when dealing with some of Vintarid flying units.
Essence Base Defenses Essence has the most base defenses of all sides, allowing them to cover every need. This includes the Autocannon, Laser Battery and Howitzer.
Smart Mines When attacking an Essence base, you can expect Smart Mines to be there. Since they can distinguish between fried and foe due to ID microchips every Essence unit and soldier has, they can be safely placed even inside a base, and will only harm the enemy. They will detonate to harm only objects without the coded signal signature.
EMP Drone Small tracked robots carrying a single-use EMP Bomb. Detonating the bomb completely fries the drone's circuits, making it one-time use only.
I should start working on Vintarids soon, since i neglected them a bit, and next update will probably be Vintarid-exclusive.
PostPosted: Sun Nov 03, 2013 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I love the glowing front of the Tartarus.
Volgin
PostPosted: Sun Nov 03, 2013 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
that Tartarus is an artpiece of texturing - well done. is it actually a voxel?
Victory!
Krow
PostPosted: Mon Nov 04, 2013 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
What Crim said. Extraordinary.
Team Black wrote:
mevitar
PostPosted: Mon Nov 04, 2013 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
All units here, except EMP Drones, are voxels.
[ Time: 0.1610s ][ Queries: 11 (0.0087s) ][ Debug on ]
