The time now is Fri Apr 19, 2024 12:30 am
Proper textless and glossless RA2/YR cameos
Moderators: Global Moderators, Media Hut Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Post new topic   Reply to topic Page 1 of 1 [18 Posts] Mark the topic unread ::  View previous topic :: View next topic
tomsons26lv
Cyborg Artillery
PostPosted: Sun Sep 01, 2013 5:20 pm    Post subject:  Proper textless and glossless RA2/YR cameos Reply with quote  Mark this post and the followings unread
Proper textless cameos restored by using pieces of the cameos from 5 foreign languages.
RA2 cameos won't be released as psd's tho because they will be too big to upload
Note, i mostly only removed the gloss and text, touch-ups only made if i was sure that it looks correct,i wanted to keep them as authentic as possible
YR cameos
Notes on YR cameos
Battle Fortress. WW accidentally moved the cameo one pixel row above, instead of fixing it they copy pasted the bottom pixel row from another cameo.
M.I.G cameo only exists in the English,Chinese and Korean version of YR but all say M.I.G. and the bottom section is corrupt so i had to paint the clouds in myself
Boris. I restored it from the official concept that i tweaked to look exactly like the cameo, its higher quality than the one in YR.
Brute. It's shadow its slightly corrupt
Citadel walls. Refer to the official WW render i added in the psd if you want to restore the remaps
Force shield. In the eng version of the cameo the shield shell was moved compared to the rest languages
G.G.I. The attached official render is from YR beta, the only difference is that the ground had grass
Gattling Cannon.Someone was probably drunk when making that, also the bottom was copy pasted
Genetic Mutator. Same derp as with the Battle Fortress only 2 pixel rows this time.
Industrial Plant. The bottom is corrupt.
Initiate.Restored from the official concept and textless image, it looks a bit different and its higher quality, if you need the original just turn off the layer of the concept image
Psychic reveal. Restored from the original image used for that cameo, if needed can make the original textless cameo as well.
Psychic tower.Someone was drunk again, the cameo has only the tower that's placed on the ground  Laughing
Dominator. The shadowed side is corrupt
Slave Miner. The bottom ground is seriously corrupt, some text and gloss partially left in, i highlighted the areas where there is still text in blue.
Spy plane. The cameo was moved in every single language, restored only the English version, original render included
Tank bunker. There is still some gloss left in the bottom left corner, that in that corner is another tank bunker
Virus. Restored from the official image and concept
Yuri Transport.If you want to restore the water in the section where its green remember that the pixel mess at the bottom that's the reflection.
Well that's about it, refer to the attached original renders if you want to fix it up or enhance it.
RA2 cameos
Notes on RA2 cameos
Both attack dog cameo bottoms are corrupted
The Black Eagle cameo is the official non-paletted image  Razz
The lightning storm cameo bottom was copy pasted two times
IFV bottom was copy pasted once
Sea Scorpion - WW used a JPG for that cameo there are a lot of artifacts,never found a higher quality version Sad
Iron Curtain building cameo, bottom duplicated
Crazy Ivan - official non-paletted image  Very Happy
The Allied transport - was owned by the Soviets in the beta
https://lh6.googleusercontent.com/-ygeXcTSC-P4/UfKyWIcrDBI/AAAAAAAAB58/28D4ZD8IO4Y/s251/command__conque-489.jpg
and vice versa for with the Soviet Transport
https://lh5.googleusercontent.com/-iHuwwMCUaHs/UfKxrMmiOtI/AAAAAAAABtw/Snw8BwkS91Q/s251/command__conque-350.jpg
there are red remap pieces around the allied team color and blue sections in the soviet transport cameo.
PSI commando - in veteran cameo the commandos shoulder was duplicated but just the shoulder.
PSI Trooper - official non-pelleted image
Patriot Missiles - bottom slightly corrupt
Tesla Trooper - The left side was duplicated to make room for the chevron
Soviet MCV - The bottom is from the late beta cameo, thats a part of a wheel Razz
Attack Sub - 24bit  Razz
Terrorist - left side duplicated
Tesla Coil - partially restored from a official non-pelleted image
Yuri - in the veteran cameo left side duplicated
Extras
Carrier - I accidentally added the fixed cameo to the RA2 pack but i meant to include it in the extra pack, this is the original unfixed version, WW duplicated the bottom to make room for the text
The Chronosphere - cameo was accidentally moved one row to the top by WW, to hide that they duplicated the bottom pixel row, here is the fixed cameo
Destroyer - Cleaned up the green and made the water less pixely
Conscript - HQ cameo and its late beta counterpart
Flak Cannon - Fixed the sky that was actualy from a late beta cameo
Flak Trooper - HQ version, not included in the RA2 pack because its a bit different
IFV - Fixed the duplicated bottom
Initiate - Original cameo before i enhanced it with WW's 24bit cameo and original concept
Rocketeer - Veteran cameo I accidentally pasted the tank destroyer ontop of that one in the RA2 pack  Embarassed
Soviet Power Plant - Really late beta cameo,found in the chinese version of RA2, its a lot higher quality than the final
PSI Trooper - Original cameo
Squid - The original cameo before WW messed it up with the green water
Yuri Prime - 24bit  Razz , not included in the RA2 pack because its not the exact same photo
Yuri - Tweaked cameo using Yuri cameo from YR
textlesscameoxras.zip
 Filename:  textlesscameoxras.zip
 Filesize:  88.69 KB
 Downloaded:  538 Time(s)
textlessRA2cameos.zip
 Filename:  textlessRA2cameos.zip
 Filesize:  576.89 KB
 Downloaded:  683 Time(s)
textlessYRcameos.zip
 Filename:  textlessYRcameos.zip
 Filesize:  1.71 MB
 Downloaded:  704 Time(s)
Tiberian Dawn, Red Alert, Tiberian Sun ,Red Alert 2,Renegade, Command & Conquer 3,Tiberium and Tiberium Wars and Westwood related image & video archive
https://picasaweb.google.com/113361105083292812413?noredirect=1
Skype live:tomsons26
Don't forget to state who are you otherwise i'll ignore the invite
tomsons26lv
Cyborg Artillery
PostPosted: Thu Sep 12, 2013 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bump
Finally got some free time
Added RA2 cameos and previews, extra cameos such as some extra 24bit originals coming soon(maybe in a few hours)
PostPosted: Thu Sep 12, 2013 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice job. Tho at some places, I'd be more happy if the cameos would be better than WW *cough* Soviet MCV *cough* but still, great job!
PostPosted: Thu Sep 12, 2013 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work, I admire your patience.
MRMIdAS
PostPosted: Thu Sep 12, 2013 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any chance of these in png format, so I don't have to DL photoshop to open them?
MIdAS - Turning wages into beer since 2002
tomsons26lv
Cyborg Artillery
PostPosted: Thu Sep 12, 2013 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only the YR cameos are in psd, all of the YR cameos are in the preview just cut them out
Atomic_Noodles
PostPosted: Thu Sep 12, 2013 8:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
GIMP works fine too.
~ Excelsior ~
tomsons26lv
Cyborg Artillery
PostPosted: Thu Sep 12, 2013 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Added the extras
That pack probably will be updated, i'm thinking of adding the Beta Soviet Engineer cameo once i figure out how to accurately remove the gloss and text
tomsons26lv
Cyborg Artillery
PostPosted: Fri Sep 13, 2013 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Late beta Soviet Engineer cameo
Finally he once again has his own cameo  Razz
Will update the zips once there are more than one cameo to add
 Filesize:  7.22 KB
 Viewed:  18396 Time(s)
Bu7loos
PostPosted: Sat Sep 14, 2013 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Great !
tomsons26lv
Cyborg Artillery
PostPosted: Sat Nov 30, 2013 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was comparing the late beta cameos to the final and discovered WW screwed up the final Battlelab cameo
Here is the fixed one
If i find any more screw ups in the cameos i will post the fixed ones
 Filesize:  5.18 KB
 Viewed:  18026 Time(s)
206UE
PostPosted: Sat Nov 30, 2013 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Blank cameos are nice. I think RA2 should have used the system that TS uses for cameos. It's easier to change the name of a unit.
Nikademis Von Hisson
PostPosted: Mon Dec 02, 2013 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
well, i dont think they intended people to use their stuff. Not sure if they ever intended people to be able to make their own mods, but wouldn't it be nicer to make your own stuff (tanks, buildings, terrain, ships, jets, icons) instead of being lazy and taking someone else stuff and changing the name?
Everyone these days want a short cut the goal line. No one wants to do their own work to get there.
Atomic_Noodles
PostPosted: Mon Dec 02, 2013 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I always thought the reason the RA2 Cameos had text on it was because it was a successor to RA which used the Portrait Style Cameos. Granted TD also had Portrait Style but when they moved onto TS they had changed the style to the more common Profile Style that they also used in Tib Wars,RA3 & Twilight.
~ Excelsior ~
PostPosted: Mon Dec 02, 2013 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
It also allows you to write whatever you want on the cameo while the actual unit name is different.
FurryQueen
PostPosted: Mon Dec 02, 2013 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh neat. I'll be using some of these improved ones. I really like that Tesla Reactor cameo from the extra set. That's really nice.
KGR | AT
AZUR
Discord: theastronomer1836
Steam
tomsons26lv
Cyborg Artillery
PostPosted: Sun Jun 15, 2014 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Noticed that the Yuri Battlelab cameo is messed up
 Filesize:  20.36 KB
 Viewed:  16993 Time(s)
deathreaperz
PostPosted: Sun Jun 15, 2014 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks tomsons!!! Very Happy
Humans were born for two things: to pray and be productive.
[ Time: 0.1873s ][ Queries: 16 (0.0117s) ][ Debug on ]
