The time now is Thu Mar 28, 2024 6:36 pm
CCCIII: Blistering Heatstroke [2]
PostPosted: Wed May 22, 2013 12:08 pm    Post subject:  CCCIII: Blistering Heatstroke [2]
Subject description: Zero18's Entry: Joint 4th Place
Zero18's entry: Joint 4th Place
Detail: Good work, you can tell that you have put a great deal of effort into detailing this map. Very pleasant to look at all round and excellent LAT, shore and very good cilff placement. As far as detailing goes, you've done a great job. Repetetive trees are a bit of a let down, but I understand that there aren't many of that type to use.
9/10
Layout: The map being very large could have benefited from having 2 or 3 players on each side of the river, but large 2 player maps are also good for tactical opportunties. Some good tech structure placement and a very balanced map makes the layout a good one. Your biggest (and really, the only) downfall is that bridges are the only way to access the other side via ground units. This can turn a map into a real camp-fest. All in all though, good job on the layout, I'm afraid the bridges have hurt your score though.
7/10
Lighting: The global lighting is, unfortunately, not to my taste. To create the feeling of a heatstroke however, you did a good job indeed. The best lighting factor in this map is the light post usage around the ore fields and the river, it looks fantastic.
My personal opinion would be to tone down the red lighting so that it isn't too strong and use more of an orange lighting instead, all in all though, still a good score.
8/10
Gameplay: Not much to say in terms of gameplay. The map plays very well, but the bridges being the only route for ground units to access the enemy lines is annoying when there are only two of them. The AI still plays well however, but once the bridges are destroyed, it's pretty much a camp-fest.
7/10
Triggers/Effects: This is what I like to see. A little bit of creativity. To emphasize the feel of a heatstroke, the map jams the radar every so often along with raising and lowering of the overall ambient lighting. Great job.
The map like so many others could have benefited from sound effects, but nevermind, you still acheived a great score.
7/10
Overall - 38/50
Well, there isn't much to say. A great map, probably could have benefited from some additional players due-to it's large size, but there is very little to complain about. This is one of the best I have seen from you and would like to see you continue mapping in the future. Good job. Smile
blisterheatstroke.rar
 Filename:  blisterheatstroke.rar
 Filesize:  198.99 KB
 Downloaded:  1007 Time(s)
Starkku
PostPosted: Wed May 22, 2013 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
The radar jam triggers rely on the fact that using, for an example, 'Americans' (United States) as a trigger owner makes the actions that rely on trigger owner affect the first instance and first instance only of that particular country while playing the map. For an example, if you play USA vs. USA on this map, only the first player gets their radar jammed while the second one stays unaffected.
Therefore I think that the triggers/effects score is tad bit higher than it should, but not that it matters anymore.
PostPosted: Wed May 22, 2013 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should've used the Player @ A/B/C etc. houses instead.
Starkku
PostPosted: Wed May 22, 2013 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Action 139 Blackout Radar is applied to the owner of the trigger. Can't use the MP houses as a trigger owner.
PostPosted: Wed May 22, 2013 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I wasn't aware. In this case, I'd have lowered the position of this map to 5th and kept Cesare's Oasis map in 4th, but the top 3 would remain the same anyhow so it's no big deal.
Speeder
PostPosted: Wed May 22, 2013 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ugh.. bad cliffwork.. will cause pathfinding issues. 1x1 cliffs for the inner corners should've been used and there are few errors unrelated to those as well.
The atmosphere done by lighting is nice though.
mentalomega.com
PostPosted: Thu May 23, 2013 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed a few things:
- Cliff errors fixed.
- Removed code that should be left to the mod (like AI changes).
- Weather storm lighting is no longer bubblegum blue.
- Added river sounds.
- Removed unharvestable ore beneath ore drills.
- Fixed overlapping water tiles (minor but kinda visible if you're insane).
- New minimap which has gems as purple.
- Fixed Mirage Tank disguises.
- The solar flare which disables radar is now done via Ares radar jamming logic. This means the radar will NOT be disabled without Ares. It also disables Spy Satellites for the 1:30 the solar flare lasts.
zero18_heatstroke_v2.zip
ARES edition
 Filename:  zero18_heatstroke_v2.zip
 Filesize:  201.06 KB
 Downloaded:  157 Time(s)
DaRkGlAcEoN
Rocket Cyborg
PostPosted: Thu May 23, 2013 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, Thanks OmegaBolt
You can call me Dark or Glace/Glaceon if my name is annoying to type.
4StarGeneral wrote:
I CAN USE CAPS TOO, HOW DOES IT FEEL?
Zero18
PostPosted: Thu May 23, 2013 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
OmegaBolt wrote:
Fixed a few things:
Well, thank you for fixing my map. I guess.
[ Time: 0.1796s ][ Queries: 13 (0.0097s) ][ Debug on ]
