The time now is Thu Mar 28, 2024 11:31 am
Final Alert2 YR Problem
Zero18
PostPosted: Fri May 17, 2013 1:22 pm    Post subject:  Final Alert2 YR Problem Reply with quote  Mark this post and the followings unread
Odd enough, this application was working fine for me few weeks ago. However now it stops working and gives me error. It keeps on telling me that it can't find the ra2.mix and can't be load.
Edit: I mean, how do I get the Map Editor to work with my mod? Every time I close map editor, it switches back to original game.
RP
PostPosted: Fri May 17, 2013 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Go to Settings and tick the box for supporting mods
/ppm/'s stupidity
DaRkGlAcEoN
Rocket Cyborg
PostPosted: Fri May 17, 2013 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried that with MO. All the stuff MO added was invisible.
You can call me Dark or Glace/Glaceon if my name is annoying to type.
4StarGeneral wrote:
I CAN USE CAPS TOO, HOW DOES IT FEEL?
Zero18
PostPosted: Fri May 17, 2013 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I managed to get it working, but when I select the new vehicles that I made which appears in the list and move my mouse over to the map to drop some vehicles around. It doesn't show the voxel and is invisible.
RP
PostPosted: Fri May 17, 2013 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check the INI's. FA2 doesn't like it if you place Image= in your artmd.ini, it will only accept it if you put that tag in rulesmd.ini
It is most likely an incorrect art reference.
Could however also be compression, but I've seen that only with SHP's so far.
@DaRkGlAcEoN: Just wait for Mental Omega 3.0 Razz
/ppm/'s stupidity
DaRkGlAcEoN
Rocket Cyborg
PostPosted: Fri May 17, 2013 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
It'll be worth the wait. @RP
[ Time: 0.1782s ][ Queries: 11 (0.0076s) ][ Debug on ]
