The time now is Sat Apr 20, 2024 8:18 am
TS/RA2 future at OpenRA
Moderators: Global Moderators
Post new topic   Reply to topic Page 1 of 3 [149 Posts] Mark the topic unread ::  View previous topic :: View next topic
Goto page: 1, 2, 3 Next
Matthias M.
Stealth Laser Trooper
PostPosted: Fri Jan 25, 2013 11:34 pm    Post subject:  Will there be a Tiberian Sun/Red Alert 2 Mod in OpenRA? Reply with quote  Mark this post and the followings unread
OpenRA with Tiberian Sun/Red Alert 2 support depends on:
  • Voxel support
  • Isometry and 3D terrain
  • SHP file format changes
which is a quite an amount of work and currently not on the agenda. You patches are welcome however.
Have a look at:
There is lot's of pre-existing code. Join #openra on FreeNode IRC if you are interested in OpenRA 2.0
PostPosted: Sat Jan 26, 2013 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll be honest and tell you: I can't trust in the combination of .NET and GPL. I know Mono guys are doing a great job with porting .NET onto Linux but I can't trust in any framework being a good solution when it comes to Linux, because those mostly needs a reimplementation, especially when it's a Microsoft one.
You guys did a great job with OpenRA but you can't assure performance since Mono does ebverything differently than .NET in engine level.
Call me Stallman, but I'd either go C++ or D if I would do that.
Renegade
Cyborg Artillery
PostPosted: Sat Jan 26, 2013 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooooh, programming language advocacy. This thread has evolved alright. Laughing
Frankly, I don't see the connection you're making, Graion. GPL does not mean "guaranteed to run on Linux", it's a Free Software license. It allows you to beat it into shape to run on Mono, if you wish. It doesn't force you to, and it doesn't encourage you to. In fact, the GPL states clearly
GPL wrote:
THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
So yeah. Really not seeing the issue you have with someone writing free .NET software. Confused
@Matthias M.: Have you guys considered packaging the fundamental functions like reading the game formats into a library?
#renproj:renegadeprojects.com via Matrix - direct link
PostPosted: Sat Jan 26, 2013 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't have issues with writing free NET software, be it BSD, MIT or any CC. But writing GPL software when the patents under that are not certainly to be compatible with GPL everytime is an issue IMO.
Microsoft can declare Mono breaching their patents whenever they want and that's totally against the GPL spirit. Java is a bit better because at there Oracle will make certain that there will be a version on the Linux, but that's only just a bit better.
GPL makes sure that the code is useable by the public... throwing out an OS makes the code unusable for that OS entirely, so yeah, there goes the general public part of the license.
Renegade
Cyborg Artillery
PostPosted: Sat Jan 26, 2013 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did not understand that. At all.
What do the potential patent issues in Mono have to do with developing free .NET software?
After the fifth read, I am assuming you're having an ethical/moral issue with this, based on the idea that GPL'd software should work everywhere, easily, equally, and that's not guaranteed for the .NET environment...
...can't say anything but "I disagree, and that's not what the license says" to that.
PostPosted: Sat Jan 26, 2013 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your assumption is correct, after all, and yes, it's a moral issue of mine.
Matthias M.
PostPosted: Sat Jan 26, 2013 7:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
The OpenRA engine only uses parts of the ECMA standardized C# language and CLI framework. The rest is https://github.com/mono/tao for SDL and OpenGL calls https://github.com/icsharpcode/SharpZipLib for handling .zip files. Only the map editor uses WinForms and we think of replacing this because of usability problems with the GUI and redundancy. The OpenRA project is not affected by any Microsoft patents. Your concerns are unwarranted. You can contribute to http://openredalert.googlecode.com/ in C++ or https://github.com/ultraq/redhorizon in Java if you want to reinvent it in your favorite language. I like our current approach as the code is beginner friendly and I don't need to install a virtual machine that comes with adware crap by default now thanks to Oracle. The language design of C# also eases some parts required for this project like vector math.
https://github.com/OpenRA/OpenRA/tree/bleed/OpenRA.FileFormats already compiles into a DLL. The whole engine is modular. https://github.com/Mailaender/OpenRA/tree/shpviewer/SHPViewer and https://github.com/OpenRA/OpenRA/tree/master/OpenRA.TilesetBuilder as well as https://github.com/OpenRA/OpenRA/tree/master/OpenRA.Editor make use of the library.
Renegade
Cyborg Artillery
PostPosted: Sat Jan 26, 2013 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice. Did I gather correctly from previous comments that the file format support ends with RA, essentially? (No TS/RA2 support?)
Matthias M.
PostPosted: Sat Jan 26, 2013 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but we recently found about https://github.com/zzattack/ccmaps-net/tree/master/CNCMaps/FileFormats so I suggest you join #openra to get the latest news and talk plans as there are more interested developers involved.
Matthias M.
PostPosted: Sat Feb 23, 2013 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Sat Feb 23, 2013 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting, the first step to the future!
PostPosted: Sat Feb 23, 2013 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
If that is the future... that is not my future.
Good job, tho.
PostPosted: Sat Feb 23, 2013 10:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah it's very nice for people who want to port TS/RA2/YR etc to that engine but if you've got full SHP or 2D support then voxels are essentially useless.
Personally I'd so rather see a new game being developed on OpenRA rather than porting the old ones since the old ones are perfectly fine and I'd rather play those.
Deformat
PostPosted: Sat Feb 23, 2013 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
This. I said it, but sadly this became a priority.
But then, what's left is transition to RA palette format, and entire mods can be ported later.
PostPosted: Sun Feb 24, 2013 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I like to see voxels being implemented.  It's cool.
kenosis
PostPosted: Sun Feb 24, 2013 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
OpenRA does not include vpl thing so the voxels look like in FA2
Tired of grabbing my random SHP conversions? Why not learn to create SHPs for yourself?
View user's profile Send private message Send e-mail Visit poster's website Skype Account Yahoo Messenger Account
Holy_Master
PostPosted: Sun Feb 24, 2013 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
wow those voxel look impressive. i'm sure they will include vpl in the future. [but truely what a point to use voxel if they can go to use real 3d that a lot more flexible but however...]
only thing i hate on OpenRa is their game slow as hell and 1 second response command make it even worse.
if some one help me about coding I'm glad to make new original game for Open Ra.
just wanna say. :p
contact me if anyone interesting.
Renegade
Cyborg Artillery
PostPosted: Sun Feb 24, 2013 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias M. wrote:
OpenRA now has experimental Voxel support: http://www.sleipnirstuff.com/forum/viewtopic.php?f=83&t=16215
Very nice work! Smile
Regarding our previous exchange, I am interested in getting a bit deeper into this and maybe helping out with some YR extensions, but I'm about to move (physically, IRL), so I'm a bit occupied atm.
Maybe I'll just send you a pull request out of nowhere someday. Wink
ViPr
Gauss Rifle Trooper
PostPosted: Sun Feb 24, 2013 8:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget the official games probably generated sprites from the voxels and used those instead most of the time as a lossy optimisation.
PostPosted: Sun Feb 24, 2013 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Based on what I see in YR++... I honestly doubt that one.
ViPr
Gauss Rifle Trooper
PostPosted: Mon Feb 25, 2013 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know what you are referring to. Are you talking to me?
PostPosted: Tue Feb 26, 2013 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep.
ViPr
Gauss Rifle Trooper
PostPosted: Tue Feb 26, 2013 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I'm quite certain I mentioned this before, ages ago, and people seemed to agree with me on that point. So how about now, does anyone agree with me here?
Renegade
Cyborg Artillery
PostPosted: Tue Feb 26, 2013 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, pd, Alex, D and half a dozen others have looked at the game's code again and again for years now, and I don't remember anyone ever mentioning anything that suggested the voxels aren't used directly as they are.
I don't remember seeing anything in YR++ suggesting that, either.
Frankly, I don't see the point, either - they were already using SHPs for infantry and had systems in place to do the same for vehicles, so why implement quasi-3D-support, ship dozens of 3D models, only to then render 2D-content on the fly?
Where do you see the optimization in that?
pd
PostPosted: Tue Feb 26, 2013 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
An optimization would be caching the voxel's rendered image for each kind of rotation that ever occurs (ie once a new rotation occurs, cache that). Saves all the lighting and normal calculations that have to be done (I suppose).
I don't think the game does that by default, at least I can't remember seeing any of that. Honestly though, I've never been that deep into voxel rendering that I could tell for sure right now, but I agree with Ren that somebody should have noticed that.
Cranium
PostPosted: Tue Feb 26, 2013 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you look at the game vxls via xcc mixer, isn't it basically showing a sprite?
PostPosted: Tue Feb 26, 2013 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those are renders, not sprites.
ViPr
Gauss Rifle Trooper
PostPosted: Tue Feb 26, 2013 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I'm sticking to what I said. I'm surprised it didn't occur to you guys that this is what was going on. I very faintly think that, sometime before Tiberian Sun was released, Westwood Studios said that the voxels were cached to sprites. I cannot find that information again though.
This lossy optimisation doesn't have to apply to just voxels either; it could also apply if they had chosen to use textured polygons instead and I suggest perhaps OpenRA do that.
pd
PostPosted: Wed Feb 27, 2013 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no idea what OpenRA is based on, but if it's any kind of modern rendering engine (I hope they use OpenGL), then caching textured polygons into sprites would be a waste of VRAM, as drawing the textured polygon directly is as fast (because sprites are textured polygons).
Concerning voxels, it may still be a good idea.
Just by the way, why is this in the "Ares is dead" thread?
PostPosted: Wed Feb 27, 2013 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Animated HVAs, though, would probably be easier if the model wasn't converted into a sprite.  Or so I would assume?
ViPr
Gauss Rifle Trooper
PostPosted: Wed Feb 27, 2013 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
It is in the "Ares is dead" thread because if the community can build their own game engine from scratch then they wouldn't need to edit a pre-existing engine via hacking, which I assume is extremely technically difficult and also has potential legal and moral problems.
Sprites can use textured polygons but they don't have to; they can use another method which is a lossy optimisation which was probably used by the original games. However, even if they were textured polygons, they wouldn't draw at the same speed as proper 3d model textured polygons.
Guest
Guest
PostPosted: Wed Feb 27, 2013 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Would extending OpenRA to make it look like RA2 be to much work?
Note, I am not talking about features, I am talking about the appearance.
PostPosted: Wed Feb 27, 2013 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Most likely yes.
Isometric, half-3d terrain, vxl support, and other aspects are a whole new level. Except the OpenRA devs considered this when they started the project and thus use already data structures with 3d support, while using now only the 2d components for RA. But isometric terrain is also quite different to the rectangle-tile layout of the classic C&Cs
pd
PostPosted: Wed Feb 27, 2013 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
In 3D renderers like OpenGL, "sprites" do not exist. In that case, "sprite" is a synonym for a quad (= 4-gon) with a texture. A "proper 3D model" is a set of textured triangles. So how would drawing two textured triangles (a quad, or "sprite") be any slower?
The original games did not use any 3D renderer, they used software blitting, sprites are bitmaps in that scenario. They are not (and cannot be, without complicating blitting so much it becomes even slower) compressed, unless you want to consider RLE (as used in various SHP variants) a compression. I'm also not sure why you keep refering to "lossy" compressions, that doesn't make any sense at all in this context.
I can imagine that Westwood pre-rendered voxels into sprites, but as mentioned, I'm not sure about that. It might definitely speed things up and OpenRA should do it.
ViPr
Gauss Rifle Trooper
PostPosted: Thu Feb 28, 2013 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
pd, it seems we are confusing each other because when we say textured polygons we could be referring to proper 3d textured many triangle models or just flat pictures represented using 2 triangles in rectangle formation (quads). I'm sure we both agree blitting is the fastest, then next fastest is quads, and then slowest are voxels and proper 3d textured many triangle models. I was guessing that OpenRA was using the slowest method and was suffering badly because of it so I was trying to help by pointing out an alternate method which is much faster but not as good in quality and accuracy. I was also suggesting that perhaps voxels should be ditched in favour of proper 3d textured many triangle models.
I didn't mean lossy compression as in using less data and memory. I meant using less processing power while also losing some quality and accuracy. Perhaps there is better terminology for that but I don't know it currently.
pd
PostPosted: Thu Feb 28, 2013 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, that's what lossy compression means. Blitting is copying pixels (or more generally, bytes) from one place to another directly. They have to be raw so the video driver can display them. If you have to pipe them through a decompressor, it makes blitting even slower than it already is.
Nope. Very Happy
Blitting is probably the slower kind of drawing operation on a large scale, which is why it has been abandoned widely in games and most 2D games these days are created in a 3D space with an orthographic view. 3D renderers can render a quad for as good as free (in presence of proper hardware and compared to blitting at least), what takes most time in a GPU concerning that is swapping textures.
I'm not sure if voxels and triangle models can be compared, unless you see them as Minecraft-like block models. In either case, they are probably slow as hell to render (unless there is explicit hardware support which seems to be in development).
What we can definitely agree on, I believe, is that whatever OpenRA uses blitting or 3D, they should pre-render voxels. Very Happy
ViPr
Gauss Rifle Trooper
PostPosted: Thu Feb 28, 2013 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
When I was talking about the speed I was making an assumption that all processors are heading towards being RISC instead of CISC, meaning no more specialised hardware and no more complex operations for free. If that assumption is correct then what I said about the speed of the different methods is correct, no?
PostPosted: Fri Mar 01, 2013 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
This is an interesting discussion.
I have nothing to add, just wanted to say that.
Carry on.
pd
PostPosted: Fri Mar 01, 2013 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
3D is done on the GPU, not the CPU. Those days are past. I have honestly no idea what models GPUs are these days, but they are horribly fast in what they're doing - and dedicated to it.
Blitting is usually a simple copy operation of pixel data (whatever format, 5R6G5B in YR and TS) from one place in memory a back that's uploaded to the video RAM every frame so it can be displayed. It was safe to use it when resolutions were low, but the more you blit the slower it gets (640x480 was 307,200 pixels, 1280x1024 would already be four times as much, that's assuming we're just filling the screen with pixels, usually things are a lot more complicated). Features like alpha blending and depth checks additionally complicate it and make it slower. Uploading stuff to the video RAM also takes an awful while. The thing is that this is all done in the same time window as game logics and possibly networking (I'm not sure if networking was multi-threaded in YR and prior). So on a large scale, blitting becomes slow, not because it's a slow operation in itself, but because of the overhead it generates and the time it takes away from other things.
3D saves that CPU and memory load and operates almost solely on the GPU. All you upload to it are textures (usually once, before you draw anything, e.g. in a loading screen) and from that point on, it's mostly just commands (e.g. render that quad with that texture at that place), which are passed as good as instantly. The GPU takes care of actually rendering and displaying things whenever it's ready, so the main program flow is not interrupted.
I can't honestly tell whether a textured quad is rendered a lot faster by the GPU than blitting a sprite of the same proportions etc. is using CPU and RAM. Of course, that also depends a lot on the hardware involved. But the key is that the GPU is dedicated to doing its 3D stuff and can do it on its terms, while the CPU and RAM are being left alone of sorts and can take care of whatever else needs to be done (game logics). That's what I mean by 3D is faster than blitting.
ViPr
Gauss Rifle Trooper
PostPosted: Fri Mar 01, 2013 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes when we have specialised hardware like a GPU then estimating the speeds of calculations is very difficult. However I've just been wondering about the future and whether GPUs will end up just being replaced by general purpose processors that have pretty much no specialized hardware in order to leave more space for even more parallelism.
PostPosted: Sat Mar 02, 2013 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
GPGPUs already exist. (CUDA and all the NVidia cards made in the recent 4-5 years) The GPU itself will not get replaced, it will be the software which will have subroutines paralellized upon the GPU.
I just started a course on the uni about this exactly.
I doubt the specialized hardware of current GPUs will get changed, because that's where their advantages of paralellism invoked. The whole thing aims for parallelism, and if you want to generalize the architecture, that means you have to sacrifice from this ability... maybe it'll just left as-is and ends up as a support ALU like the ones back then in 286-era. (387, 487)
Matthias M.
PostPosted: Sat Mar 02, 2013 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.moddb.com/games/openra/news/openra-20 has some nice screenshots and explains the progress as well what is left to do in a non-technical way. If you want to help or discuss the implementation details follow http://www.sleipnirstuff.com/forum/viewtopic.php?f=83&t=16215 or talk to Paul directly. We also do a lot of dreaming for the future at http://bugs.open-ra.org/ so if you want to port your mods to OpenRA contact the developers via those channels. I might be the only one reading this thread from time to time.
Deformat
PostPosted: Mon Mar 04, 2013 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I knew that this project will be awesome quite soon, and seems I was right. And it keeps being more awesome...
Matthias M.
PostPosted: Mon Apr 29, 2013 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Progress is being made to make OpenRA attractive to RA2/TS modders. Support for VXL/HVA and SHP(TS):
New construction options!
 Filesize:  52.98 KB
 Viewed:  20767 Time(s)
Kirov reporting!
 Filesize:  138.44 KB
PostPosted: Mon Apr 29, 2013 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are a beautiful person.
PostPosted: Mon Apr 29, 2013 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well as things keep going it get's better for a none-C&C project.
Matthias M.
PostPosted: Mon Apr 29, 2013 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Katzsmile already did this concept
with just OpenRA, custom made SHP(TS) sprites and fake isometry terrain tiles borrowed from C&C ReWire.
PostPosted: Mon Apr 29, 2013 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you finally have a gamespeed slider? I find myself falling asleep while waiting dozens and dozens of seconds for a war factory to finish building (I play TS only at speed 5 -> 60 FPS, while OpenRA's speed feels like approximately half of that).
Matthias M.
PostPosted: Mon Apr 29, 2013 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
We recently unlagged move orders and auto-target. I have the game speed slider done https://github.com/OpenRA/OpenRA/issues/2058 but it is not yet shared to all clients so we can't enable it without breaking multi-player. I can put it on my TODO list again after we tagged a new stable release.
Nikademis Von Hisson
PostPosted: Tue Apr 30, 2013 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice
Post new topic   Reply to topic Page 1 of 3 [149 Posts] Goto page: 1, 2, 3 Next
You can edit your posts in this forum
You can delete your posts in this forum
You can vote in polls in this forum
You can attach files in this forum
[ Time: 0.2357s ][ Queries: 15 (0.0160s) ][ Debug on ]
