Joined: 10 Dec 2012 Location: I'm too busy conquering the world!
Posted: Sat Apr 20, 2013 11:31 pm Post subject:
Suggests
I suggest that the programmer who made VXL Editor, that when you click on save button, it should actually save. I clicked on it and it saved as untitled, but sometime some of my work is gone because of that save button, so I'm forced to use save as.
Also, another suggestion. Fix it when you click on close the program, sometime I forgot to save it and then it becomes untitled and its gone. Pretty much annoyed.
Another one, can someone fix HVA Builder rotation position? It seems to be wrong, as it rotates on an edge of voxel, instead of rotating at the center of the voxel. Can the programmer fix it? It will make my work and other works easier without having to reposition it.
Example
34.61 KB
2150 Time(s)
_________________ Mod Leader and founder of World Domination
Sounds more like the voxel is not centered and it rotates off as result, else I haven't seen it have any issue with that. If bounds reset mispositions, you originally made the voxel miscentered given the dimensions. QUICK_EDIT
