The time now is Fri Apr 19, 2024 11:38 pm
Also Very not dead!
Moderators: Zengar_Zombolt
Zengar_Zombolt
Plasma Trooper
PostPosted: Tue Feb 05, 2013 9:09 pm    Post subject:  Also Very not dead!
Subject description: Zombie I be not!
The War Factory is not dead, just a bit harder coding RA3 than RA2. In the time it takes me to code one RA3 unit to Ingame status, I can have buckets of RA2 stuff ingame. But to tide, and hopefully get more interest in PPM's Only RA3 mod, here's a ship!
 Filesize:  1.68 MB
 Viewed:  7795 Time(s)
I am Zengar Zombolt, The Sword That Cleaves Evil!
There is Nothing I can not Cut!
PostPosted: Fri Feb 08, 2013 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Wouldn't it make more sense as an aircraft?  In Empire scheme it'd look reasonably fitting imo.
ApolloTD
PostPosted: Fri Feb 08, 2013 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Why don't you invest time actually to edit the model if you want it work in water? not to mention do a new texture shading work to fit it in... and guns on waterline is so off, it really was meant to fly as far design was concerned and looks dumb as it stands so edit the model to house guns on the deck or simply erase them from the bottom and put torpedo tubes.
Zengar_Zombolt
Plasma Trooper
PostPosted: Tue Feb 12, 2013 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
One, I can't edit models, no 3dsmax. That's on the label of the mod. If after looking all I did in RA3 you have not noticed that...
Two, this is in the prototype step of adding a unit, there is no new texture yet. I have still yet to fiddle with the shaders text-ualy, think of a name, fiddle with weapon code and etc. You RA2/TS folk may see this as the time where the normals on your model are off and you need to tune it.
PostPosted: Tue Feb 12, 2013 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I'd see it more as the part when I made a giant aircraft, but I'm using it as a ship.
ApolloTD
PostPosted: Tue Feb 12, 2013 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Frankly I don't recall looking your little project like before but given it is just existing models just ported over is not too interesting to me given I mostly loathe the EA models.
Main point however... the design is aircraft, just because you made it go on water doesn't make it look naval ship.
Might do nicer as airborne artillery really.
Sir Modsalot
PostPosted: Tue Feb 12, 2013 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
That's the C&C4 Kodiak. Not to crap on your efforts, but turning aerial artillery into a naval ship makes absolutely no sense.
[quote="DCoder"]There is no sanity left in this thread.[/quote]
View user's profile Send private message Skype Account AIM Address
freedom fighter
PostPosted: Tue Feb 12, 2013 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh c'mon guys, its not like you've never seen a spaceship as a watercraft before in countless mecha animes. But I agree that this one should be an Empire aircraft. Looks weird to see all those big guns underwater...
The future belongs to The Forgotten!
Zengar_Zombolt
Plasma Trooper
PostPosted: Fri Feb 15, 2013 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, there are NO AVAILABLE SHIP MODELS that work as units outside of the two CnC3 ships. And they only fit two sides. The Soviets are getting shafted when it comes to ships.
[ Time: 0.1593s ][ Queries: 14 (0.0092s) ][ Debug on ]
