The time now is Fri Apr 19, 2024 3:42 am
Black Eagle
Moderators: freedom fighter
freedom fighter
PostPosted: Sat Dec 29, 2012 10:42 am    Post subject:  Black Eagle
Subject description: "Korea's finest!"
Type: Ground attacker
Armament: Maverick 2 ATGMs, 20mm cannons
Armour Class: Heavy
Speed: Fast
Cost: $1200
Purpose: Anti-Armour, Anti-Infantry
Requires:  Airforce Command HQ
Strong against: Vehicles, Infantry
Weak against: Structures, Anti-Air, Aircrafts
Additional Info
- gains Armour bonus on veteran
- gains Speed bonus on veteran
- gains Firepower bonus on elite
- gains laser-guidance systems on elite, increasing range and firepower
- carries two additional payloads on elite
Originally a domestic modification to the famed F/A-18 Hornet multirole fighter, the Black Eagle is the result of a joint venture between McDonnell Douglas and Korea Aerospace Industries. While it was still based on the Hornet, it was completely redesigned as a heavy ground attacker. It has a much more rigid structure and swept back wings, increasing it's armour while making it much more maneuverable at the cost of reduced speed. It's main armaments are Maverick 2 missiles. These are vastly improved Mavericks with greater armour piercing ability, making them deadly anti-tank weapons. If soft targets are needed to be destroyed, it's 20mm cannons gets the job done efficiently. While its nearly as indestructible as the fearsome A-10 Thunderbolt II while still being a lot faster, it can't soak up as much damage from anti-air fire and is unsuitable for aerial engagements with other fighters.
credit: MigEater
The future belongs to The Forgotten!
Last edited by freedom fighter on Mon Apr 08, 2013 2:09 pm; edited 5 times in total
PostPosted: Sun Dec 30, 2012 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice! The blue cockpit window isn't as intimidating as the rest of the fighter, though.
[ Time: 0.1727s ][ Queries: 11 (0.0072s) ][ Debug on ]
