The time now is Sat Apr 20, 2024 10:06 am
LCAC
Moderators: freedom fighter
freedom fighter
PostPosted: Sat Dec 15, 2012 7:01 pm    Post subject:  LCAC
Subject description: "Plenty of window seats."
Type: Landing craft
Equipment: EM Nullifier
Armour Class: Heavy
Speed: Slow
Cost: $900
Purpose: Amphibious transportation
Requires: Seaport
Additional Info
- immune to EMP
- has four additional passenger slots (4 infantry or 1 tank)
The Landing Craft Air Cushion (LCAC) has always been the Allied navy's means of transporting ground troops over vast stretches of water. It has been a vital piece of equipment that has undergone little to no modification. In the wake of the Imperial naval assaults, the LCAC's hull armour has seen vast improvements. It will still succumb to heavy fire though. The fact that LCACs are unarmed means that protecting them is very important. They are however equipped with a unique device known as the EM Nullifier, an experimental countermeasure designed to negate EMP effects which threaten to immobilize it's parent vehicle and potentially sinking it should it be above deep water. The Wing of Freedom is a heavy user of such disruptive tactics.
credit: die
The future belongs to The Forgotten!
Last edited by freedom fighter on Mon Apr 08, 2013 11:28 am; edited 1 time in total
PostPosted: Sun Dec 16, 2012 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd prefer it if this unit was amphibious. What you could do at least is to reduce it's distance from the ground (via HVA or rules.ini settings).
[ Time: 2.8061s ][ Queries: 11 (2.6440s) ][ Debug on ]
