The time now is Thu Apr 18, 2024 1:44 pm
( ) All Palettes for XCC Mixer
PostPosted: Thu Dec 13, 2012 9:32 am    Post subject:  ( ) All Palettes for XCC Mixer Reply with quote  Mark this post and the followings unread
This is a short tutorial that shows you how to give XCC Mixer every palette from all C&C games, without the need for having them all installed.
This way has some slight advantages over the inbuild automatic palette location of XCC Mixer:
-no registry crap is needed to find all the palettes
-the palettes appear neatly arranged in the bottom infobox of XCC and show in much shorter text which palette is currently selected
-you can move the XCC Utilities on a portable medium and are still able to use all the palettes
-you can enhance it later easyly if you want to add modified palettes to create SHPs etc (in the cctdawn.mix inside the LKOccallpal.mix you can find already such 2 palettes redremap.pal and shadow.pal)
1. Download the attached mix LKOccallpal.mix: LKOccallpal.mix
Place the LKOccallpal.mix inside your XCC Utilities folder.
Start XCC Mixer and open the Tab View then open "Directories..."
2. Now enter in the TD Primary: textbox the path to your XCC Utilities. (Do the same for TD Secondary: and RA:)
Press OK.
Close XCC Mixer and restart it again.
3. Now the Mixer has loaded the LKOccallpal.mix file with all the palettes. You can see it in the bottom info box of the Mixer.
Change the palette as usual.
This tutorial is sponsored by tibweb.
Key Words: #Tutorials #Palettes #TiberianDawn #RedAlert1 #TiberianSun #Firestorm #RedAlert2 #YurisRevenge #XCCUtilities
Last edited by Lin Kuei Ominae on Sun Dec 29, 2019 11:08 pm; edited 2 times in total
PostPosted: Wed Mar 04, 2015 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Note: it is enough to set the TD Primary path only.
No need to set the XCC Folder on TD Secondary and RA too.
[ Time: 0.1502s ][ Queries: 11 (0.0079s) ][ Debug on ]
