The time now is Fri Apr 19, 2024 6:13 am
Mod Updater 1.0
¥R_M0dd€r
PostPosted: Sat Mar 24, 2012 7:27 pm    Post subject:  Mod Updater 1.0 Reply with quote  Mark this post and the followings unread
What is Mod Updater and when do we use it?
Mod Updater is a tool that help mod/project leaders to make sure their testers is using the latest version/files of their project. If your mod/project is large and contains a lot of files that constantly being updated/improved(or whatever), this utility is a good option.
Why not just send the updated files to all the testers?
Having to remember what files that have been updated, and then send them to every tester is a bit of pain if you ask me.
With this program, you don't have to do anything except pressing the "Connect" button.
Documentation wrote:
Mod Updater/Fast Connect 1.0 by YR Modder
Usage for Server:
Start with exporting the file-list(as a txt). Follow the simple pattern in the file-list and add as many files and directories as you like.
The program must be in the same directory as the files and directories listed in the file-list.
For example, if you want to share C:\Westwood\RA2\expandmd01.mix, add expandmd01.mix to the file list, and put the server program in C:\Westwood\RA2.
Example of a correctly formatted file-list: list.txt:
gamemd.exe
expandmd01.mix
expandmd99.mix
audio.bag
auid.idx
SomeDirectory
Other notes:
- The file list is remembered when you start the program, so there is no need to import it everytime the program is launched.
- Putting a directory into the file list will share every single file in that directory tree.
- The file-list: contains information about the shared files such as their size, checksum and path.
Usage for Client:
Pressing the button "Check for updates" will download the file-list from the server and then scan for the files listed in the file-list that is in the same directory as the client program itself.
If a file is found, you will be asked to download it if the two checksums are unequal. If a file is not found, you will be asked to download it as well.
Exceptions: Many forms of different runtime exceptions can occur in this program, here is explanations to some of them:
UnknownHostException: ... - This host/ip address do not exist.
IndexOutOfBoundsException: null - The server program disconnected while you were downloading from it.
ConnectException: Connection refued: connect - This have three known meanings:
* Yhe host address is valid and exists, but the program is offline.
* The host address is valid and exists, the server is online but the port value is incorrect.
* You successfully connected to the server, and the server(later) disconnected before you started to download.
Safety:
- The server is safe from any type of virus. The server will only receive a string array from the client, which is harmless.
- The client, like all download programs, is at risk. You should not connect to people you do not trust.
Other:
This program is 100% free and you may modify it in any way you want.
 Filesize:  16.85 KB
 Viewed:  3262 Time(s)
 Filesize:  12.84 KB
 Viewed:  3261 Time(s)
 Filesize:  32.38 KB
 Filesize:  16.54 KB
Fast Connect 1.0.rar
 Filename:  Fast Connect 1.0.rar
 Filesize:  173.68 KB
 Downloaded:  249 Time(s)
¥R_M0dd€r
PostPosted: Thu May 17, 2012 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
15 download. Some feedback? Do anyone find it useful?
Personally, I think it is a awesome utility for modders to keep their testers up to date.
This of course require a decent connection.
PostPosted: Thu May 17, 2012 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably I'll take a look.
I am tempted to drop out LB from distributing, and this sounds the perfect option, but so far I haven't decided neither in my final mixing ways neither if I'll just wrap up installers to make it working or writing a custom client on my own. (that actually sounds the most possible due to it could be a nice experience for me).
¥R_M0dd€r
PostPosted: Sat Jun 30, 2012 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Updated the thread with 1.0.
Changelog:
No longer get the hashcodes two times.
Support of directories.
Better information(before, if a file was smaller than 1024 kb, it would print it as 0.0MB).
[ Time: 3.2449s ][ Queries: 17 (3.0696s) ][ Debug on ]
