The time now is Fri Apr 19, 2024 10:01 am
Casablanca
Dak
PostPosted: Tue Mar 13, 2012 4:10 am    Post subject:  Casablanca Reply with quote  Mark this post and the followings unread
This maps for [YR].
Its a [4] player Skirmish map.
This is a large Desert map, with quite a bit to fight over. This was my first try at a desert map and while not the best it turned out to be a fun map to play. There has been some INI editing done, Make sure to visit Ricks place. All sides now get spys and they can steel vehicls, so don't pass up on some of the Civ vehicls. You are free to edit and change this map as you wish. Have Fun.
Dak
 Filesize:  26.71 KB
 Viewed:  2812 Time(s)
casablanca.zip
 Filename:  casablanca.zip
 Filesize:  468.66 KB
 Downloaded:  332 Time(s)
[ Time: 0.1438s ][ Queries: 14 (0.0095s) ][ Debug on ]
