The time now is Tue Apr 23, 2024 9:36 pm
Run Mod with modified resolution?
Moderators: Carnius
CrossplaneR1
PostPosted: Sun Sep 25, 2011 3:30 am    Post subject:  Run Mod with modified resolution?
Subject description: How to run the game with mod with modified resolution?
The highiest resolution on my laptop is 1366x768 and C&C3 doesn't support and I have use this trick to run my C&C3 game in 1366x768.
Right-click on the shortcut, go to properties. In the target field add -xres 1366 -yres 768 to the end of the shortcut. Click Ok, then run the game from the shortcut.
"C:\Program Files\Electronic Arts\Command & Conquer 3\CNC3.exe" -xres 1366 -yres 768
But how do I run Mods with modified resolution? because in order to run Mods files you have to go thru Game browser which the default highiest resolution will be use, in my case C&C3 will use 1280x720 for my spec.
Any help would be appreciated!
Sorry if this question has been asked before.
Thanks
Alex06
PostPosted: Sun Sep 25, 2011 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
You have to add a "-mod something" command to the shortcut, I believe, or make the actual target the config.txt file of the mod you want to run (under My Documents/Tiberium Wars/Mods/Mod Name) instead of the game's executable.
CrossplaneR1
PostPosted: Sun Sep 25, 2011 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
hey thanks for your prompt reply!
But I don't get it, now the target field is "C:\Program Files\Electronic Arts\Command & Conquer 3\CNC3.exe" -xres 1366 -yres 768"
Which part should I add the -mod thingy? let's say the mod I'm going to run is TiberiumEssence.
Thanks
CrossplaneR1
PostPosted: Sun Sep 25, 2011 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile haaa! I got it work!
I just browse thru forums and found the "-ui" command and add it to the target. It looks like this now:
"C:\Program Files\Electronic Arts\Command & Conquer 3\CNC3.exe" -ui -xres 1366 -yres 768
Thanks PPMSite
Wink
[ Time: 0.1397s ][ Queries: 11 (0.0083s) ][ Debug on ]
