The time now is Tue Apr 23, 2024 5:37 pm
[YR] Fortification (2-4)
PePsiCola
Cyborg Specialist
PostPosted: Wed May 11, 2011 10:26 pm    Post subject:  [YR] Fortification (2-4)
Subject description: First public map
This is my first public map for YR. I trained a lot with maps.
This contains triggers for sound effects such as rivers. There was a taskforce with a bus that moved around. Everything is there except the trigger because for some reason, if I move to the bus on the map then the game will freeze. So I removed that trigger. There are a few tactical routes to enemy bases.
It takes place in a nighttime state. There is no day-night loop but the small town in the middle has some lighting.
This was made by me but I did check some maps for styles such as the bottom-right corner. You MIGHT recognize that cliff style.
There's probably a few shore errors, maybe cliff errors too.
Zip and screenshots. Enjoy.
Note that the name is just so I have one. Although there are some suprises...
As you can see, these are done playing my mod but this is compatible with anything. I'm playing the mode "I Like Crates" and I had to find a map reveal crate so I could give the screenshots.
They are big but I'd put them in a spoiler if I could.
Top-right starting point
 Filesize:  823.78 KB
 Viewed:  2841 Time(s)
Top-left starting point
 Filesize:  679.23 KB
Bottom-right starting point
 Filesize:  759.84 KB
Bottom-left starting point. My base.
 Filesize:  759.13 KB
Minimap
 Filesize:  17.24 KB
Tiberium Uprising (a few missions for TS): http://www.ppmsite.com/forum/viewtopic.php?t=31029
PePsiCola
Cyborg Specialist
PostPosted: Wed May 11, 2011 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well you know, fives the limit.
Fortification (2-4).zip
 Filename:  Fortification (2-4).zip
 Filesize:  93.3 KB
 Downloaded:  320 Time(s)
[ Time: 0.1497s ][ Queries: 18 (0.0118s) ][ Debug on ]
