The time now is Fri Mar 29, 2024 12:05 pm
[TS] SP Mortar
Moderators: Global Moderators, Media Hut Moderators, OpenRA Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
radar92
PostPosted: Sun Mar 14, 2010 3:09 am    Post subject:  [TS] SP Mortar
Subject description: SP mortar team
A small SP mortar. The mortars in the back, the roof is open.
The small size hides the details I could fit in. But I was able to place a mortar tube in the back.
It even has a drivers compartment, not that it can be seen.
The camo just simple one.
 Filesize:  5.9 KB
 Viewed:  3013 Time(s)
 Filesize:  26.75 KB
116tnk.zip
 Filename:  116tnk.zip
 Filesize:  7.28 KB
 Downloaded:  159 Time(s)
ph34r the cute ones!
Askhati
Jumpjet Infantry
PostPosted: Mon Mar 15, 2010 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
The labeling of your voxels makes me curious - this one is labeled 116tnk, and the troop truck you posted is 118tnk. Are they all part of a larger voxel pack?
Adapt or die
radar92
PostPosted: Mon Mar 15, 2010 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
XXXtnk is just a naming convention I use. Some are related, some are not.
[ Time: 0.1730s ][ Queries: 15 (0.0120s) ][ Debug on ]
