The time now is Wed Apr 24, 2024 5:59 pm
CNC4 GDI Support Kodiak
Moderators: Global Moderators, Media Hut Moderators, OpenRA Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Post new topic   Reply to topic Page 1 of 1 [17 Posts] Mark the topic unread ::  View previous topic :: View next topic
Is it
Amazing!!!
76%
 76%  [ 23 ]
Good
20%
 20%  [ 6 ]
needs some improvements
3%
 3%  [ 1 ]
bad
0%
 0%  [ 0 ]
send it to the trash
0%
 0%  [ 0 ]
Total Votes : 30
asvnix
PostPosted: Thu Mar 11, 2010 8:58 pm    Post subject:  CNC4 GDI Support Kodiak
Subject description: Awailable for download! (RA2YR)
Hello everybody!!! Today I have finished my work at this amazing unit.
I made a voxel and 2 cameos for it.
This unit is made as a single body. I didn't made turrets becouse they will not work properly on RA2YR engine.
As always I want to hear your oppinion and suggestions! =)
 Filesize:  982.27 KB
 Viewed:  13647 Time(s)
 Filesize:  169.59 KB
 Filesize:  150.31 KB
CNC4_Kodiak.zip
 Filename:  CNC4_Kodiak.zip
 Filesize:  1.69 MB
 Downloaded:  895 Time(s)
ronco
PostPosted: Thu Mar 11, 2010 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is freaking awsome! the only thing i dont like is that you use ultra smooth normals .. so it looks very bright in some facings
asvnix
PostPosted: Thu Mar 11, 2010 9:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't use normals, they are generated automaticaly by 3DS2vxl converter, I just found the best values. If you try to use auto normals, all voxel will be f*** up. This bright side occures becouse of big planar faces
ronco
PostPosted: Thu Mar 11, 2010 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok then 3ds2vxl makes it so smooth.. i guess your voxel wil look better if you do some normal hand paint/improve...
i made that image to show the difference ... its not perfect #Tongue
 Filesize:  16.04 KB
 Viewed:  13592 Time(s)
Roadwarrior
PostPosted: Fri Mar 12, 2010 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know what you're talking about, It's not to bright at all. In fact any other normal's would ruin this awesome voxel, and indeed make it way too bright. (And as we all know RA2 voxel rendering is way too bright anyway)
IMO this is the best one you have made ^_^
I vote Spotlight.
View user's profile Send private message Skype Account AIM Address
001010011100101110
PostPosted: Fri Mar 12, 2010 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
That's nice...
AltomareXD
PostPosted: Fri Mar 12, 2010 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
001010011100101110 wrote:
That's nice...
Very nice!
MT
PostPosted: Fri Mar 12, 2010 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Very good work. May I ask, what modeller you used?
ronco
PostPosted: Fri Mar 12, 2010 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
IMO. this normals makes it looks like it has a small spot near to it not the sun...
Askhati
Jumpjet Infantry
PostPosted: Fri Mar 12, 2010 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice... Could someone autonormal it with TS-range normals and post a TS ingame? Would be interesting to see, as well as to compare with the SHP Kodiak that is already ingame.
Excellent job, asvnix!
Adapt or die
Regulus
PostPosted: Fri Mar 12, 2010 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
KA-BOOOOOOOOM!
You come for the modding but you stay for the Crap Forum.
Starkiller
Pyro Sniper
PostPosted: Fri Mar 12, 2010 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome work . Spotlight ?
Roadwarrior
PostPosted: Sat Mar 13, 2010 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, yeah it could be toned down a bit, but it's somewhat RA2's fault.
Darkstorm
PostPosted: Sat Mar 13, 2010 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
The voxel is great, as far as the concept, EA obviously didn't get the info on the Kodiak. It is like a ship, its name is unique. Adding to that, the kodiak is a command & logistics transportation aircraft. Anyhow, regardless, the voxel is well made.
ArvinCool
Tiberian Beast
PostPosted: Sat Mar 13, 2010 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like it
"I'll be staying strapped cuse my mac-eleven make my nuts bigger"
ViPr
Gauss Rifle Trooper
PostPosted: Sat Mar 13, 2010 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
there is a problem with normals on this voxel i think because you are not aware of how 3d programs generate normals. 3ds2vxl generates normals probably the same or at least similar to 3d programs like 3D Studio Max. in 3D Studio Max i recommend that you reduce the angle on the Auto Smooth, or clear all the smoothing, or fiddle around with tesselation or chamfering and meshsmoothing, or simply disable smoothing in 3ds2vxl. I think you will find that this gives you approximately the same result as ronco got when he improved the normals by hand.
Xovvo
PostPosted: Sat Mar 27, 2010 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
It still rocks hard.
[ Time: 0.1656s ][ Queries: 19 (0.0144s) ][ Debug on ]
