Posted: Wed Jun 03, 2009 2:16 am Post subject:
Man I'm running into problem after problem
Subject description: help would be liked
Well I fixed most stuff but when adding my new sov plane I get this IE and the sounds don't work right, itll play one then some random animal and then another mig sound. (voices)
Here's me code:
Prerequisite=NAPAD
Primary=Maverick
CanPassiveAquire=no ; Won't try to pick up own targets
CanRetaliate=no; Won't fire back when hit
Strength=150
Category=AirPower
Armor=light
TechLevel=3
Sight=8
RadarInvisible=no
Landable=yes
MoveToShroud=yes
Dock=GAAIRC,AMRADR,NAPAD,YAPAD
PipScale=Ammo
Speed=14
PitchSpeed=1.1
PitchAngle=0
OmniFire=yes
Owner=Russians,Confederation,Africans,Arabs
Cost=1200
Points=20
ROT=3
Ammo=2
Crewed=yes
ConsideredAircraft=yes
AirportBound=yes ; If I ever need to land and there are no airports I crash because I can only land on them
GuardRange=30
MaxDebris=3
IsSelectableCombatant=yes
VoiceSelect=CMigSelect
VoiceMove=CMigMove
VoiceAttack=CMigAttackCommand
VoiceCrashing=CMigVoiceDie
DieSound=
MoveSound=MigMoveLoop
CrashingSound=IntruderDie
ImpactLandSound=GenAircraftCrash
Locomotor={4A582746-9839-11d1-B709-00A024DDAFD1}
MovementZone=Fly
ThreatPosed=20 ; This value MUST be 0 for all building addons
AuxSound1=IntruderTakeOff ;Taking off
AuxSound2=IntruderLanding ;Landing
VeteranAbilities=STRONGER,FIREPOWER,SIGHT,FASTER
EliteAbilities=STRONGER,FIREPOWER,ROF
Fighter=yes
ImmuneToPsionics=yes
ElitePrimary=MaverickE
PreventAttackMove=yes
Sorry bout double post but this problem is getting a little pressing, I found out to add them to PadAircraft but still IE, this time right on selection is how I remember it, this is except for that one, I believe it is same cause.
Posted: Wed Jun 03, 2009 6:12 am Post subject:
plane
have you tried taking out your new sounds, using old ones as a test? maybe getting the INI checker might help you out. _________________ I am authorized to send out the TMP Studio, PM ME IF YOU WANT IT And check this out, these were sent to me for help with terrain and zdata help along with TMP Studio/Builder
pssst, you fucked up the AttackCommand voice in the sound file, and you may not have listed the audio in the [SoundList]. The except drops right back to audio. QUICK_EDIT
First, take the "attack" and "decay" out from Control= setting. You don't seriously want to use those with unit response voices. They are used with looping sounds to define "attack" and "decay" sounds (start and end sounds of loop) taking the first entry of Sounds= list as "attack" sound and last one for "decay" respectively. You dont need the other Attack= and Decay= statements either.
Altough I am not sure if those even work without Control=loop defined but better to be safe than sorry.
Hyper wrote:
Im not RA2 modder, but dont each sound have to have a $ prefix? CMigAttackCommand dont seem to have them...
AFAIK $ prefix was only used by Westwood to differentiate between all other sounds and unit voices. I don't think it has any effect upon how sounds play because they work perfectly without. QUICK_EDIT
Well, your doing it wrong, here is guide to sound control tags and their purpose.
;Explaination of the following attributes:
; Sounds
; Volume
; Control
; Delay
; Priority
; Limit
; LoopCount
; FShift
; VShift
; Range
; Type
; MinVolume
; Attack
; Decay
; SOUND:
; Syntax: Sounds = {$}<sound1> {$}<sound2> ...{$}<sound32>
; Up to 32 sound files can be associated with an audio event. Do not
; specify path or extension of the file, just the name of the file. The
; file name must not be more than 16 characters. If there are spaces in the
; filename then enclose the name in double quotes(e.g. "Big Bad Sound").
; However, avoid using spaces if possible.
; Any sounds that require localization must have a dollar sign ($) in front
; of their names in the sound list (not in the filename itself) and
; versions of these sound files must be placed in the appropriate language
; sub directories.
; NOTE: all sound files should be normalized
; VOLUME:
; Syntax: Volume = <0>
; Volume level playback for audio event. We assume that all sounds are
; normalized. Use this attribute to set the mixing levels for audio.
; The value specified is the percentage of full volume. e.g. 25 means
; playback at one quarter of full volume.
; CONTROL:
; Syntax: Control = <loop>
; The control attributes can be used in any combination to achieve desired
; playback effects.
; The default control behaviour is to play the
; first sound in the sound list just once. The following control keywords
; can be used to:
; loop
; Continually play sound event. LoopLimit attribute can be used to
; specify how many times to loop the event.
; random
; Randomly pick sound from sound list to play.
; interrupt
; This new instances of this type sound event have priority over
; already playing instances.
; all
; Use all sounds in sound list.
; predelay
; Normally if the DELAY attribute is specified the delay happens
; when the sound finishes playing. PREDELAY forces the delay to
; happen at the start of the sound. Random predelays help avoid
; 'phasing' when multiple instances of the same audio event happen
; at the same time.
; attack
; Specifies that the first sound in the sound list gets played,
; regardless, at the start of the audio event (see ATTACK attribute
; also). This sound is called the attack sound.
; decay
; Specifies that the last sound in the sound list gets played,
; regardless, at the end of the audio event. ( see DECAY attribute
; also). This sound is called the decay sound.
; DELAY
; Syntax: Delay = <minDelay> <maxDelay>
; Used to specify a delay (in milliseconds) to wait at the end of an each
; sound that is played in an event. The control PREDELAY moves the wait to
; the start of each sound being played. The delay is randomized between
; the min and max delay times. e.g.:
; Delay = 3000 8000 ; wait from 3 to 8 seconds between sounds
; Delay = 1000 ; wait exactly 1 second between sounds
; PRIORITY
; Syntax: Priority = <LOWEST>
; Priority and Limit are the most important attributes of them all. While
; possibly hundreds of audio events want to trigger every frame, only a few
; will be chosen. It is vitally important to ensure that important events
; do not get dropped. The audio engine uses the priority of the audio event
; when choosing which events to drop. So make priorities are set correctly
; for all events.
; LIMIT
; Syntax: Limit = <max>
; Limit specifies the maximum number of instances of an audio event type
; that can be played SIMULTANEOUSLY. Limit of one, along with IMMEDIATE
; control, can be used to achieve monaural sounds.
; LOOPLIMIT
; Syntax: LoopLimit = <count>
; By default looping is infinite. LoopLimit can be used to specify the
; exact number of loop iterations. 0 count means loop forever.
; FSHIFT
; Syntax: FShift = <minDelta> <maxDelta>
; The FShift attribute alows the playback frequency to be randomly changed
; in order to give some variance to repetitive sounds. The engine uses a
; percentage value to represent the frequency of a sound. 100 percent
; means normal frequency. 50 percent means half the frequency. 200 percent
; means twice the frequency, and so on.
; The minDelta and maxDelta values describe a range relative to 100 percent
; frequency. For example:
; FShift = -5 5 ; vary frequency between (100 -5) and (100 + 5)
; FShift = 5 10 ; vary frequency between 105% and 110% of original
; FShift = -50 0 ; vary frequency between 50% and 100% of original
; VSHIFT
; Syntax: VShift = <maxDrop>
; Like FShift, VShift is used to randomly change the volume of a sound
; in order the give it more variance. The VShift value is the maximum
; drop in volume alowed. For example,
; Volume = 80
; VShift = 10 ; vary volume between 80 and 70
; RANGE
; Syntax: Range = <cells>
; Specifies the audible range of a sound in game cells.
; TYPE
; Syntax: Type = <global>
; Type information allows the game engine to modify event behaviour. Meaning:
; global
; Positional audio event is always audible regardless of where in
; the world it is. Instead of fading to silence when out of range
; like normal events, global events do not fade below MINVOLUME.
; normal
; default type.
; screen
; Audio event fades out only when it moves off the edge of the screen.
; center
; Audio event fades out from the center of the screen
; shrouded
; Not audible when shrouded
; MINVOLUME
; Syntax: MinVolume = <0>
; See "GLOBAL" TYPE above.
; ATTACK
; Syntax: Attack = <num>
; By default when the control keyword 'attack' is specified the first sound
; in the sound list is used as the attack sound. If the Attack attribute is
; supplied then the first <num> sounds in the sound list are considered
; attack sounds, and are randomly chosen from on playback. Obviously this
; is used in order to vary the attack sound.
; DECAY
; Syntax: Decay = <num>
; By default when the control keyword 'decay' is specified the last sound
; in the sound list is used as the decay sound. If the Decay attribute is
; supplied then the last <num> sounds in the sound list are considered
; decay sounds, and are randomly chosen from on playback. Obviously this
; is used in order to vary the decay sound.
just for reference and what you did horribly wrong is using those Attack=7 and Decay=7 things to specificly tell the game that you had 7 attack start sounds in the list and same for decay and there isn't so game is forced to CRASH. QUICK_EDIT
