The time now is Fri Mar 29, 2024 12:21 am
Adding new music
Post new topic   Reply to topic Page 1 of 1 [13 Posts] Mark the topic unread ::  View previous topic :: View next topic
devin11590
Cyborg Artillery
PostPosted: Sat Jul 19, 2003 4:11 am    Post subject:  Adding new music Reply with quote  Mark this post and the followings unread
If you have windows XP, open any wave file in the built in sound editor. Then, click file, save as... In the save as dialogue, click the change settings button (near where you click the save button.) Under the 'format' drop down menu, choose IMA ADPCM, then choose 22.050 kHz, 16 bits, mono. Then click ok and save, it will then work, i've tried it! Also, dont forget to add your song to the csf files and the theme.ini file.
Key Words: #Tutorials #Modding #RedAlert2 #YurisRevenge #Theme.INI
View user's profile Send private message Send e-mail Visit poster's website Skype Account Yahoo Messenger Account AIM Address
PostPosted: Sun Aug 10, 2003 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
4 bit?
Mike
PostPosted: Sun Aug 10, 2003 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
i think he means 16 bit
Divi-Dead
PostPosted: Sat Aug 16, 2003 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's also a tutorial about this at the xcc site which isnt specifically for XP
View user's profile Send private message Visit poster's website Skype Account AIM Address
devin11590
Cyborg Artillery
PostPosted: Wed Aug 27, 2003 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh. i tried that tutorial and it didnt work.
Eqx
PostPosted: Wed Aug 27, 2003 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did it this way:
Convert the wav or mp3 file to 22050Hz 16bit mono Windows PCM wav with Cool Edit Pro 2.0 than convert it to aud with wav2aud.exe. I place the aud file into the game folder and manually edit the theme.ini file.
It works.
Fire walk with Me...
PostPosted: Wed Aug 27, 2003 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
yea, it makes more sense than 4bit sounds...
DeeZeL
PostPosted: Thu Aug 28, 2003 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
it worked fine for me (even under winXP)
"Sometimes the mind needs to find somethings on its own" -Dr. Xavier
devin11590
Cyborg Artillery
PostPosted: Sun Aug 31, 2003 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
uh, aud is tiberian sun format, ra2 uses IMA ADPCM wav files only
Mike
PostPosted: Mon Sep 01, 2003 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
umm banshee it IS 4bit
PostPosted: Sat Jul 17, 2004 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
wrong. Tutorial has been edited. It is 16 bits mono according to Kravvitz and kravvitz is experienced with it. (My RA2 modding job was very limited...) and 4 bits makes no sense... even DOS games have 8 bits sounds or better... 4 bits is compared to a packman or worse Neutral...
Amak
PostPosted: Sat Feb 05, 2005 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is how I did it.
You will need XCC Mixer, XCC IMA ADPCM WAV Writer Plug-In, Command & Conquer: Red Alert 2 and WinAmp.
You can download the XCC utilities from http://xcc.tiberian.com/.
You can download WinAmp from http://www.winamp.com/.
Install and enable the XCC IMA ADPCM WAV Writer Plug-In. You go to output, then look for the plugin. Convert the songs you would like to add to RA2 by simply playing them with WinAmp. You won't get a prompt to save the file, this happens automatically..Start XCC Mixer.
Launch XCC Theme Writer. I got this from the XCC home page and it works. I was even able to edit the main menu screen music and skrimish loading music.
gog
PostPosted: Sat Apr 22, 2006 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
does this mean the other player can hear the music as well? i dont really understand how to do it either Confused
thanks,
gog
[ Time: 0.1583s ][ Queries: 11 (0.0094s) ][ Debug on ]
