The time now is Fri Apr 19, 2024 4:51 am
The Ultimate Generals/Zero Hour map pack: 3026 maps!
Moderators: Generals Moderators, Global Moderators
purplescrin
PostPosted: Fri Mar 06, 2009 10:52 pm    Post subject:  The Ultimate Generals/Zero Hour map pack: 3026 maps! Reply with quote  Mark this post and the followings unread
For the first time ever, I have collected over 3000 maps at this point, but this is definitely the last time I am updating the huge map packs for Generals and Zero Hour. All files have been tested and are 100% virus free.
946 Generals Maps: http://www.filefront.com/14807389/946GeneralsMaps.7z
1900 Zero Hour Maps: http://www.filefront.com/14807469/1900ZeroHourMaps.7z
180 Generals/Zero Hour Mission Maps (including the lost Generals map "Black Sheep")
Download: http://www.filefront.com/14807275/180GenZHMissionMaps.7z
The .7z files can be opened either with WinRAR, 7-Zip or PowerArchiver. Not all versions of WinRAR can open .7z files correctly. I cannot guarantee that all maps will work regardless if there are missing files for those maps. When you place those skirmish or mission maps, the location of putting them is as according to OS.
For XP users:
Generals Maps: C:\Documents and Settings\your user name\My Documents\Command and Conquer Generals Data\Maps
Zero Hour Maps: C:\Documents and Settings\your user name\My Documents\Command and Conquer Generals Zero Hour Data\Maps
For Vista users:
Generals Maps: C:\Users\your user name\AppData\Roaming\Command and Conquer Generals Data\Maps
Zero Hour Maps: C:\Users\your user name\AppData\Roaming\Command and Conquer Generals Zero Hour Data\Maps
For mission maps, all you have to do is to extract them into "My Documents" folder regardless of which OS you are using.
Credits to all the people of the CNC community who made those skirmish and mission maps especially the former EA Pacific dev team.
Please note this:
To add something about the map pack, please do not attempt to put all maps into the map folder, otherwise the program will slow down, unless if you have a fast PC. It appears the limit amount of placing custom skirmish and mission maps into the map folder is at least one hundred. Despite the numerous amount of maps, you probably don't have all the time to play all of them. You should decide which good maps you want to play and put them in the map folder. With all that being said, enjoy playing those maps.
MT
PostPosted: Fri Mar 06, 2009 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
You made them all? If not, where are the credits?
If you did make all 2507, then that would be... ztyping unbelievable
PostPosted: Fri Mar 06, 2009 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unbelievable. Who can possibly need 2507 maps?!
Amazing, but 'No Thanks', a top 5 would be better - I'd play those.
[ Time: 0.1292s ][ Queries: 11 (0.0073s) ][ Debug on ]
