The time now is Sat Apr 20, 2024 1:38 am
Edit your minimap for your TS MAPS. (*)
Post new topic   Reply to topic Page 1 of 1 [23 Posts] Mark the topic unread ::  View previous topic :: View next topic
Wiziwig
PostPosted: Fri Dec 05, 2008 1:59 am    Post subject:  Edit your minimap for your TS MAPS. (*)
Subject description: Because everyone loves doodling dongs on their minimap for everyone to see. 8D
Pretty much the title is self-explanatory. This is for those people who hate the look of the minimap that is generated by Finalsun, and want it to look more 'Official', aka similar to the official Westwood maps.
What follows is a step-by-step guide to do this. Wink
WHAT YOU'LL NEED:
PART1: The Croppening
STEP 1:
Take a printscreen of your minimap. This is best achieved by minimizing the main Finalsun app and bringing up the minimap by clicking on it while Finalsun is still minimized. (this removes that annoying box on the minimap.)
NOTE: To save you some trouble ahead, before you take the printscreen of the minimap, delete ALL of the lightposts on your map; this will allow you to skip STEP 2 of PART2. (remember, don't save your map after doing this, as then you'll have to place all of the lightposts again! Instead, close your map and reload it.)
ADVANCED MODE: Load up your map in a text editor, and navigate your way to here:
After you have found it, delete any structure with the inclusion of 'IN' at the start of its name; eg. INBLULMP, INYELWLAMP, INGRNLMP etc. (thanks Lin! Razz )
STEP 2:
Copy and paste that printscreen into paint and remove everything so that only the minimap is shown. (note: you can use IrfanView to do the same, but using paint allows you to get the size more precise.)
STEP 3:
Zoom in and start croppin'!
NOTE: Because Finalsun also includes the area outside of the map border in the minimap, you may also have to crop it a little bit more than the images above; roughly 5-6 pixels worth around the outside should do it. (thanks Bittah. Wink )
PART2: The Paintening
STEP 1:
Now that we have it in paint, lets get rid of all that fugly stuff that makes the minimap look 'unprofessional'.
Click on the Color dropper tool, and select the red from one of the starting positions.
After thats done, click the Brush tool and select the largest square from the selection. (if you feel it's too large, you can then hold CTRL+ "-" to make it smaller (or optionally, CTRL+ "+" to make it larger))
Now click away at those starting positions!
STEP 2:
Well that looks nicer, but what about those invisible lightposts everywhere!
Well, let's get rid of most of them shall we?
This parts pretty simple; just use the Color Dropper to select a color that surrounding the lamps, and then paint over it. Simple!
See, doesn't that look better already? And now for the FUNPART.
STEP 3:
This parts only mainly important if you have blue Tiberium on your map. (which like, everyone should have, jeez u guiz.)
As we all know, blue Tiberium turns out black thanks to Finalsun, but now, it's time to change that!
Simply choose a nice blue color, and paint the black areas blue! (note: you'll have to be careful, as walls are black on the minimap as well, so keep your Original Minimap open in Finalsun so you can check to see what's blue Tiberium or not.
PART3: The Textaning
This is the part where it gets tricky, but we're nearly finished so yay.
Save your preview as .BMP (so that there's no quality loss) and re-open it up in IrfanView. Once it's loaded, save it as a .PCX (save as... -> PCX from the drop down menu)
Now that it's saved, copyandpaste it into the SUN DIRECTORY. (purely so that it's easier for XCC to find.)
Now load up XCC Mixer 1.22, and navigate to your preview.
Now right-click it and select Copy as MAP (TS) Preview.
After you've done that, go to the folder where XCC Utilities is located (1.22). It's here that you'll find a text file named *previewname*.txt
Open it up and copy ALL of the text in it.
Now open up your map in a text editor, and navigate to here:
Now delete all of that text (preview pack included) and replace it with the text from the text file in the XCC folder.
AND YOU'RE DONE! CONGRATULATIONS!
Finished product:
Key Words: #Tutorials #Mapping #TiberianSun #Firestorm #RedAlert2 #YurisRevenge #FinalSun #FinalAlert2 #Graphics #Media #XCCUtilities
Ex Cliffie-detector and continued general annoyance.
PostPosted: Fri Dec 05, 2008 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
very useful tutorial, thanks for posting it up
Paranoia
Cyborg Specialist
PostPosted: Fri Dec 05, 2008 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, cheers for this!
PostPosted: Fri Dec 05, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
IMO you're better off just taking ingame screenshots from your map, merging them together into 1 huge image, then shrinking and sharpening it and finally converting it to MAP (TS) preview (this is what I did for all maps in DTA).
XCC Mixer always crashes when I do this however, although it does convert the image (sometimes it requires multiple attempts because XCC Mixer crashes slightly too early or something, but copying the converted image to the root of a drive also seems to improve the chances of it working).
Wiziwig
PostPosted: Fri Dec 05, 2008 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Yea, that's why I posted a link to v1.22, which, for some odd reason doesn't crash when you convert it. The newer versions crash on me aswell. (sometimes they make the preview, but most of the time it crashes too early, like you said.)
Thanks for the comment anyway. I'm sure someone will find use for this. #Tongue
PostPosted: Fri Dec 05, 2008 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome Wiziwig, nice to see you posting again. Wink
PostPosted: Fri Dec 05, 2008 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Very useful, but aren't veinholes black in Vanilla TS Minimaps? #Tongue In any case, thanks for this, never really crossed my mind.
Wiziwig
PostPosted: Fri Dec 05, 2008 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yea, but black is such a fugly color for veins. I'm sure it won't kill anyone to leave it a nice healthy yellow. Wink
Cheers Hyper. Wink
Also:
Wink
PostPosted: Fri Dec 05, 2008 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
By the way, another problem with FinalSun minimaps is that includes that non-accessible area (the area outside of the blue rectangle) in the minimap, so you might also want to crop the minimap you're fixing up a little.
PostPosted: Fri Dec 05, 2008 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
editing minimaps would be a good way to promote our site on XWIS..
Adding a line like "To get this map download @ ppmsite.com" as most of our maps are too heavy for damn XWIS to transfer.
perhaps it would help get some of our sexy maps into the hands of more TS players out there
Anderwin
PostPosted: Fri Dec 05, 2008 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should I delete everything under previewpack?
Nice tuts anyway Very Happy
Can you hide from me Wink?
PostPosted: Fri Dec 05, 2008 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I Think I'll do this for the Twisted Insurrection maps, it does look a lot better than FinalSun's ugly minimaps.
PostPosted: Fri Dec 05, 2008 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a very good tutorial. Nice one Wizwig Smile
PostPosted: Fri Dec 05, 2008 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice tutorial
maybe an improvement would be, to temporarily delete manually the lightposts in the map with a text editor, before you start creating and editing the final minimap. This should be faster and cleaner than a pixel by pixel edit in the picture.
Ixith
PostPosted: Sat Dec 06, 2008 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Lin Kuei Ominae wrote:
nice tutorial
that is if all the invis light posts are next to each other in the text of the map. Wink From my experience they tend to get jumbled up in the list of placed buildings.
But I must agree nice tutorial. I did always hate how blue tib showed up black on the minimap
Kalistia Crestland (2)
PostPosted: Sat Dec 06, 2008 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finalsun doesn't have an option to just not show the buildings? If there are no neutral buildings on it that's probably easier...
PostPosted: Sun Dec 07, 2008 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Not that I know of anyway.
Followed the tutorial and everything turned out perfectly! Smile
 Filesize:  160.97 KB
 Viewed:  22549 Time(s)
Wiziwig
PostPosted: Sun Dec 07, 2008 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, gonna add that now. Wink
Yup, all of the text DIRECTLY under the preview pack needs to be deleted, so that it can be replaced with the new preview pack without it glitching up. Wink
It's not really a big concern, really. The main ones that stand out are the ones on/near water or in the middle of open areas where they're noticable on the minimap. You're free to do that though. Smile In fact, I'll probably add that to the tut as an optional thing.
Sadly no. I wish someone with enough time on their hand would remake Finalsun and fix a lot of the problems that are with it. It shouldn't be too hard, considering the lowdown on the TS mappack data is on Olaf's website.
Nice! Glad someone used it. #Tongue
Morpher
PostPosted: Sun Dec 07, 2008 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I've used a similar method before to test random images for map preview, just like an ingame unit shot or something. Was pointless but interesting lol. Also, if you have a map with no civilian / neutral buildings on it, but have light posts and don't want them on the preview can't you just save the map, and import it using finalsun and select to not import units and buildings?
Sorry if I read the thread wrong I quickly skimmed the last few posts.
-=HelloDave=-
PostPosted: Sun Dec 07, 2008 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Very Happy, I'm going to make a goatse one now.
Ixonoclast
PostPosted: Sun Dec 07, 2008 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
SRSLY U >:V
MadHQ
PostPosted: Fri Aug 03, 2012 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for topic reincarnation but is this for menus only? In-game it draws its own mini-map... Is there something Im doing wrong, or not doing? (Note* Im doing this in RA2)
MadHQ's Graveyard - Click here!
(Permissions) - (F.A.Q.)
Krow
PostPosted: Fri Aug 03, 2012 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes. This only changes the minimap in the menu. You're not doing anything wrong.
Team Black wrote:
[ Time: 0.1990s ][ Queries: 14 (0.0113s) ][ Debug on ]
