The time now is Tue Apr 23, 2024 10:39 pm
Red Alert 2 + New computer.
Post new topic   Reply to topic Page 1 of 1 [32 Posts] Mark the topic unread ::  View previous topic :: View next topic
Chrisse
PostPosted: Wed Oct 08, 2008 8:34 pm    Post subject:  Red Alert 2 + New computer. Reply with quote  Mark this post and the followings unread
So. I bought a new computer not to long ago, as i also felt i'm going back to modding thus installing Red Alert 2.
The only annoying problem i have that it's running slow as hell. On gamespeed 6 i get like 10 fps or even slower whenever a conyard or something like that get's blown up, and when i move the screen over a base it's really slow and laggy. I have the TFD version installed for the matters.
Computer specs:
Intel Core 2 Quad 6600@ 2,40Ghz
XFX GeForce 9600 GT, PCIx16 2.0 512 MB 650mhz/900mhz (But plugged to normal PCIx16 port)
Corsair Dominator/w fan 2x2GB, 1066Mhz
Western Digital HDD 7200rpm, 500GB
EDIT: Win XP Professional 32 Bit, SP3
I can run Crysis on Max Graphics without ANY lag at all, but Red Alert 2? No.
Someone got any clue what this can be?
Thanks in Advance.
//Chrisse
EDIT: Important, Read Beowulf's First post. Problem Solved, for all having the same problem Wink
R.I.P Xeno.
http://open.spotify.com/track/3B5lZi3QJ8AeVpdLtO9NcI
www.myspce.com/ttex91 (Listen to my music (Outdated)).
PostPosted: Thu Oct 09, 2008 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use compability mode, and set it to Windows 98/ME... Works for me Wink
Chrisse
PostPosted: Thu Oct 09, 2008 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is automaticly set when installing TFD because it won't start without it, so it didn't fix my problem Sad
R.I.P Xeno.
Lt Albrecht
Location: Hampshire, England. Creating RA2: Moscow's vengeance
PostPosted: Thu Oct 09, 2008 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
OS?
Yes, work on MV continues. It is not forgotten.
NewGuy
PostPosted: Thu Oct 09, 2008 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
ra2 is a old game to. It may not be compabilty with dual core or something else.
Chrisse
PostPosted: Thu Oct 09, 2008 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
And RA2 worked just fine on my old computer which had Dual Core and the same OS.
R.I.P Xeno.
NewGuy
PostPosted: Thu Oct 09, 2008 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
could be 32 bit(dunno what I have, one of these require a patch that VK made) or SP3.
I havent installed SP3 yet, waiting on a swe version of it.
Chrisse
PostPosted: Thu Oct 09, 2008 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Swe version is already out, i have the Swe version of it.
Still havent got it fixed, updated TFD, DirectX and GFX Drivers. Still no result.
R.I.P Xeno.
Somebody Else
PostPosted: Thu Oct 09, 2008 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Limit it to only one CPU core, that might help, it helped me with a few things (Task Manager -> processes -> right click -> set affinity). Preferably the second one. I heard something about RA2 using the CPU for transparency instead of the graphics card, and that it dislikes dual cores.
- Somebody Else
NewGuy
PostPosted: Thu Oct 09, 2008 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chrisse
PostPosted: Thu Oct 09, 2008 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alright, i tried this and no result. Also i tried disabling multiple cores in BIOS with no result Sad Still after all updates, it's been a little better but far from as fast as it should be. at speed 6 without any explosions etc it's on about gamespeed 5, when explosions, etc come. it's seriously lagging.
R.I.P Xeno.
NewGuy
PostPosted: Thu Oct 09, 2008 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahh I had that bug before. It made me crazy but I forgot how I fixed it Very Happy
Dupl3xxx
PostPosted: Thu Oct 09, 2008 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
reinstall the game? and can you play for some time, but then is suddenly ginds to a halt (like 2 SPF) or is it just when there are multipl animations? Also, try this
This is a signature
EVA-251
Also Known As: evanb90
PostPosted: Thu Oct 09, 2008 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Voxel engine TS and RA2 use is terribly unoptimized.
In TS, put the RA2 Apoc Tank in, and have your average Apoc assault. Your FPS should drop about 66%-75% upon viewing your tanks. Fortunately, when W$ developed RA2, they greatly improved the voxel rendering.
The worst FPS dropper in RA2/TS is the transparency of animations. Cut the transparency from explosions, smoke effects and whatnot, and you will notice a huge FPS increase, especially during battles.
Cutting combat light is also good. A huge combat light flash will cause your computer's speed to drop regardless of how good it is.
There is really nothing to do with your computer to make RA2 run faster.
YR modder/artist, DOOM mapper, aka evanb90
Former Project Lead Developer Star Strike (2005-2012), Z-Mod (2006-2007), RA1.5 (2008-2013), The Cold War (2006-2007)
Chrisse
PostPosted: Fri Oct 10, 2008 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
The weird thing is that it did run about 2 times faster without any FPS drops on my previous computer. While this is faster in every single way.
EDIT: Tried to set all Translucent=yes to Translucent=no in my artmd.ini and start the game. this unfortiantly had no diffrence. As before it's lagging when anims like explosions etc appears, running a little slower than my last computer when units just move around etc, general play.
EDIT2: Ok, so i tried not building a SpySat when playing and set a powerplant on build, moving to fully shrouded area (Where's no graphic involved) Now, it took me about 1 sec to build a powerplant costing 800 Credits. When Moving over a base it took me about 6 sec.
So what it looks like is, that the Graphics is the thing that slows my RA2 down really much, as we maybe already know. But to make it more clear. Also, The newer and more Graphic card i have had the slower the game has become (Graphic wise, generally) eg. on my dads computer which has an ATI Radeon 9600 with AGP Bus the game runs much faster graphic wise than this one does, which has PCIx16 2.0.
So i'm then asking myself, and everyone else. If this could be because of some settings or rendering methods the new Grahic cards use, which leads to Incompability. I'm going to test this someday with the settings i have, like maybe Disabling Anti-Aliasing and such. To see if it have an impact.
Also i'd like to know if you can Display the FPS ingame when playing RA2 to compare.
Thank you.
EDIT3: Tried to set all options on my Graphics card to minimum, still no diffrence. Hmm.
R.I.P Xeno.
Chrisse
PostPosted: Sun Oct 12, 2008 9:25 pm    Post subject: *Important Bump* Reply with quote  Mark this post and the followings unread
Okay, so i looked around a bit on Google, where i came to a site saying something about DirectDraw. DirectDraw is a function you can either Enable of Disable in the dxdiag program (DirectX Config tool). When DirectDraw was enabled (Which it is by defeault) I had around 3 fps while blowing up a whole base with a custom Demo truck. When Disabling DirectDraw, i had around 50-60 FPS. The Problem though is, if you Disable DirectDraw. Most games will be unable to run.
And i don't know any way to only automaticly disable it when running RA2 or YR and then re-enabling it.
But it is a Solution to the problem, and a solution good enought. To have a stable gameplay.
R.I.P Xeno.
Beowulf
PostPosted: Sun Oct 12, 2008 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Drop in RA2 directory. Might even work with TS, as well.
ddraw.rar
 Filename:  ddraw.rar
 Filesize:  16.38 KB
 Downloaded:  28599 Time(s)
View user's profile Send private message Visit poster's website Skype Account AIM Address
Chrisse
PostPosted: Sun Oct 12, 2008 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
You sir... Made my day!
Tested with the file. And exact same result as if i had disabled DirectDraw, no lag, fast and smooth gameplay!
Now, what exactly did you do with that file? Or id it just that RA2 uses DirectDraw only when it's in the RA2 Directory?
Anyway this file should be stickied on a seperate topic with an Description why it's usefull.
Also, EA should include this file in the game by Defeault. Seriously.
Anyway, Thanks! Smile
R.I.P Xeno.
Beowulf
PostPosted: Sun Oct 12, 2008 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got that from Piscinex I believe. I'm pretty sure it's like the LAN Patch, modifies it for the game only.
PostPosted: Mon Oct 13, 2008 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Does this also fix the bug in TS where the game slows down when you build a cheap structure (aka everything below $1000)?
Chrisse
PostPosted: Mon Oct 13, 2008 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
It fixes the Graphical Issues. The file Disabled DirectDraw making the GFX Drawn by Software, CPU Based.
R.I.P Xeno.
John Galt
PostPosted: Mon Oct 13, 2008 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
No. That bug is due to the game's hardcoded usage of 54 gclock frames. This dll simply disables video back buffering.
PostPosted: Mon Oct 13, 2008 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
HOOOOLY SHIT. #Shocked THIS DDRAW FILE FIXED MY TS WAVECLASS ERROR!!! (sorry for this outbreak but it was necessary)
Sonic beams and Laser work now perfectly fine!
Please, all TS player which have the WCE test this.
I love you Beowulf. Thank you very much.
John Galt
PostPosted: Mon Oct 13, 2008 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
That might work better if posted in the actual TS forum...
PostPosted: Mon Oct 13, 2008 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Kurorahk
PostPosted: Mon Oct 13, 2008 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thank you so much, this is something that will greatly help with just playing RA2 and TS, thank you again!
-Kurorahk-
Defiance Industries: We prefur to call it well prepaired not over kill.
Blaze, Demon of The Round Table, Mobuis One call me what you want I am one with the sky.
u6795
PostPosted: Mon Oct 13, 2008 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is excellent! I've been playing RA2 for years with my new computers and each one of them had puzzling lag, especially in multiplayer.
Thank you so much, Beowulf.
"The thing about biology is that while it is really easy to kill a lot of something, it's a lot harder to kill all of something. And the survivors tend to be a lot tougher and pissed off."
Kurorahk
PostPosted: Mon Oct 13, 2008 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well um... it is not working for me, I just get a black screen, get audio but no video when I run the game and the dll seems to be corrupted some how, mainly that it just makes the game unplayable at all now, which is really bisare...
So if someone could help me with this I would be very happy.
Before downloading the DDraw.dll it worked just fine, I remove ddraw.dll from the folder and it works just fine.
-Kurorahk-
partyzanPaulZy
Location: laptop? ... otherwise the Czech Republic -> south Moravia Posts: long int Posts;
PostPosted: Mon Oct 13, 2008 11:02 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Will try if it works for me too! Very Happy
Don't blame the others if you haven't checked your own (in)ability in the first case.
PostPosted: Tue Oct 14, 2008 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well you only need this if you have problems in the first place...
Kurorahk
PostPosted: Wed Oct 15, 2008 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I have the problem of random slow downs to a crawl or it just crashing if I view something, it has been that way since I have started playing it on my new computer that is:
1.86 GHz Duel Core
2 GB of RAM
NVIDIA GeForce 7150M, 64 MB of Video RAM
(yes I know I got gibed on that part)
And it is a HP Pavilion dv6000 Laptop from exactly a year ago.
I would rather not have the slow downs that I get, and have gotten since I got my computer, and have no access to a older computer such as the one I first played RA2 and TS on. And I do get WaveClass errors too, or do from time to time, anyways cool still that someone got the lag and graphics problem fixed.
-Kurorahk-
Chrisse
PostPosted: Wed Oct 15, 2008 8:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
1.86 GHz Duel Core
2 GB of RAM
-Kurorahk-
Try adding VideoBackBuffer=no in your RA2MD.ini file,
and in your SUN.ini file
R.I.P Xeno.
[ Time: 0.2007s ][ Queries: 13 (0.0109s) ][ Debug on ]
