The time now is Tue Apr 23, 2024 11:00 pm
How To Fix CTDAM
DeeZire
Cyborg Engineer
PostPosted: Thu Feb 14, 2008 5:18 pm    Post subject:  How To Fix CTDAM
Subject description: The civilian dam animations problem
Something that has literally bugged me for years so I thought I'd finally sort it out. You know the score with this one - the dam anims dont display and they look funky if you uncomment the lines in ART.INI due to bad pallette problems (as the comments themselves warn you).
It's a 2-part fix, so first open ART.INI and replace the existing entries with these ones;-
[CTDAM]
Foundation=2x5
NewTheater=yes
ActiveAnim=CTDAM_A
ActiveAnimDamaged=CTDAM_AD
ActiveAnimZAdjust=-120
ActiveAnimTwo=CTDAM_B
ActiveAnimTwoDamaged=CTDAM_BD
ActiveAnimTwoZAdjust=-60
TerrainPalette=yes
ExtraDamageStage=false
DemandLoad=true
[CTDAM_A]
Normalized=yes
LoopStart=0
LoopEnd=9
LoopCount=-1
Rate=350
TerrainPalette=yes
NewTheater=yes
DemandLoad=true
[CTDAM_AD]
Image=CTDAM_A
Normalized=yes
LoopStart=10
LoopEnd=19
LoopCount=-1
Rate=220
TerrainPalette=yes
NewTheater=yes
DemandLoad=true
[CTDAM_B]
Normalized=yes
LoopStart=0
LoopEnd=7
LoopCount=-1
Rate=350
Surface=yes
TerrainPalette=yes
NewTheater=yes
DemandLoad=true
[CTDAM_BD]
Image=CTDAM_B
Normalized=yes
LoopStart=8
LoopEnd=15
LoopCount=-1
Rate=350
Surface=yes
TerrainPalette=yes
NewTheater=yes
DemandLoad=true
Second, replace the CTDAM_A.SHP and CTDAM_B.SHP with the ones attached here. Done!
WARNING - the end result is not that spectacular and was not worth half the effort I made but hey at least it spices the dam up a bit which has been sadly lacking for the last decade or so LOL.
You can make it look a little better by NOT replacing CTDAM_A.SHP thus leaving it to be drawn in the wrong palette which actually looks a little better IMHO but I included it anyways for the purists so its done properly.
CTDAM.zip
Required SHP files.
 Filename:  CTDAM.zip
 Filesize:  10.71 KB
 Downloaded:  648 Time(s)
Key Words: #Tutorials #Modding #TiberianSun #Firestorm #Art.INI
Rico
Tiberian Beast
PostPosted: Fri Feb 15, 2008 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
the shp looks good, I'll have to put it into my mod asap Very Happy
[ Time: 0.1452s ][ Queries: 13 (0.0093s) ][ Debug on ]
