The time now is Fri Mar 29, 2024 1:46 pm
Canopy [4]
Post new topic   Reply to topic Page 1 of 1 [17 Posts] Mark the topic unread ::  View previous topic :: View next topic
FinalMoon
Cyborg Cannon
PostPosted: Sun May 18, 2003 5:41 pm    Post subject:  Canopy [4] Reply with quote  Mark this post and the followings unread
Here it is, the first map I ever created, and it's currently featured in Tiberian Sun Retro. It's a pretty good map, SMIFFGIG has informed me of one tiny bug in it with the bridges, but it's not that bad. Once it gets fixed I'll update the file. I'll also post screenshots later, right now I don't have time. There's several more maps I've made to come, this is just the first. Forgive the ancient readme file, it's from TiberiumSun.com.
Creator: FinalMoon
*Firestorm Not Required*
Map Size: 65, 115 (Medium); Taller than wide.
Players: 2-4
Theatre: Temperate
Resources: Abundant (including Tiberium Veins)
Preview:
Description: This map is very well detailed and very well designed. Each player starts on a plateau in one of the four corners of the map. The ground is covered in green tiberium and the only way to get to it is via one of the ramps at the four player's base plateaus. There are several other plateaus in the "sea" of tiberium that are covered by tiberium veins and can only be accessed via bridges from other vein plateaus and from the base plateaus. A Small river run meandering down through the middle of the map, on the "floor" and is bridged by several small bridges.
Possible Strategies: This map makes for very interesting strategies as if you send infantry out you must send them on the upper level lest they be killed in the tiberium and if you send vehicles out you must send them on the lower level, for the veins are above. If you are looking to build a second base it won't be easy. To find room for one you must destroy one
of your enemies' bases or destroy a vein hole on one of the vein plateaus. Very good play!
273_1053279636.zip
 Filename:  273_1053279636.zip
 Filesize:  74.56 KB
 Downloaded:  942 Time(s)
Guest
PostPosted: Sun May 18, 2003 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah lot of tiberuim
SMIFFGIG
PostPosted: Mon May 26, 2003 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
heres the fixed version
canopy.mpr
 Filename:  canopy.mpr
 Filesize:  155.09 KB
 Downloaded:  1294 Time(s)
zdflamer2
Shrapnel Sniper
PostPosted: Fri Nov 07, 2003 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
good strategies. i would carryall my units across the veins etc...
Tiberian Eclipse for TW
the_kid
Cyborg Informer
PostPosted: Sat Nov 08, 2003 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I absolutely loved this map!!! I still have it on my comp and play it in skirmish every now and then when I'm testing a modification or voxel I"m working on... I downloaded it a tumsun about 2 years ago...
Formerly active PPM modder (maps, voxels, sprites) and Webmaster of C&C Central in the early 2000's on the Origin/Revora network.
zdflamer2
Shrapnel Sniper
PostPosted: Tue Nov 11, 2003 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
i tend to play my own maps when testing
Fremen5
Location: Laughing at Donald Trump in a rather flat place
PostPosted: Tue Nov 11, 2003 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I play anything, usually dueling islands...
but FM's map is very good
Tiberian Station
Image guy on the Dune Sun\
- Peace - Through - Wossname -
Skywalker
Location: in the 41st century SE, thinking up a new chapter of my novel
PostPosted: Thu Dec 16, 2004 6:50 am    Post subject: Question about updating thread Reply with quote  Mark this post and the followings unread
Do you have any updated strategies, or do I just use the Hover MLRS and Wolverine.
*suddenly appears behind superior officer*
"Wing Commander Matthew Skywalker reporting for duty, sir."
Gangster
PostPosted: Thu Dec 16, 2004 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why not just kill a vein monster
or use an infantry... then?
Skywalker
PostPosted: Mon Dec 20, 2004 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Because I have better things to do with my time than send infantry out to kill vein monsters, such as firestorming the incoming drones and missiles that they always throw at me, not to mention the banshees and orca bombers.
Tyler Adams
PostPosted: Wed Dec 29, 2004 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah, use aircraft, like ORCA bombers or Banshees to kill the enemy, or if you like tanks better, the veinholes...
"Banned" RP here
Skywalker
PostPosted: Fri Dec 31, 2004 10:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I do not like using aircraft, because they are so... stupid #Mad Just like zed1515, x-wing, or ATM* from T'umsun. It's even worse than the harvester AI Mad . I may use carryalls, though Wink .
*Ackron the Mighty should have realized that picking a name like that would make him sound like the smallest, weakest kid in his class, if not school.
Ackron
PostPosted: Fri Dec 31, 2004 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
well actualy you would be supprised i may be small and weak but alot of peopel who think i take shit lying down ended up with a punch squarley in their face. but i hardly see how thats relevent to this topic.
Tyler Adams
PostPosted: Sat Jan 01, 2005 9:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
they are an important part of a battle. in Desert Storm, the aircraft may have saved many, many, many americans and other allied countries citizens..
plus, in the RA2 mission where you have to defend the Pentagon, I killed the WHOLE soviet forces in the area with a wing of 12, or so, AV8s (AKA Harriers)... I got a wing of them to FULL elite status.They can take out a ConYard in one raid... that worked...
"Banned" RP here
Skywalker
PostPosted: Wed Jan 05, 2005 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
This is TS, not RA2. The aircraft in the game we're talking about, supposedly, can't even reload without you babysitting them. I understand that RA2 might be different, but I have not got RA2, so I wouldn't know. This is also not real life, where the Iraqi forces didn't hava a chance*. I quote: "The hinge factor of the Gulf War was a blatant technological superiority in the first hour of the attack. After that, there was no more war, only annihilation."
PS: Sorry, Ackron, but you couldn't have gotten away for so long with that name. If it is any consolation, I am the tallest and weakest kid in my class except for Christopher Smith and Emma Moule, by five and one centimetre respectively.
*'The Hinge Factor', by Erik Durschmied. The chapter called 'The Zero Factor'
Clazzy
Karma Police
PostPosted: Wed Jan 05, 2005 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Aircraft in TS (excluding the Orca Bomber) are far more suited to killing infantry and vehicles than buildings. However, 3-4 Orca Bombers will wipe out anything you can throw at them. Also, am I the only person in this world to build more than one helipad instead of constantly swapping all the units about on the pad?
Skywalker
PostPosted: Wed Jan 05, 2005 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I do both, Clazzy. The STUPID AI simply Ionizes the helipads for some reason. Also, why don't you or somebody else build a map like that except the lower level is all water, like I did for a Starcraft map.
[ Time: 0.1724s ][ Queries: 13 (0.0090s) ][ Debug on ]
