The time now is Thu Apr 25, 2024 3:14 pm
Fixed Veinhole Veins
Moderators: Global Moderators, Media Hut Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Post new topic   Reply to topic Page 1 of 1 [48 Posts] Mark the topic unread ::  View previous topic :: View next topic
Renegangsta
PostPosted: Fri Jan 04, 2008 7:09 pm    Post subject:  Fixed Veinhole Veins
Subject description: The Veins, I fixed them
Well this is something that always bothers me in maps, the veins have the dirt in the frames so i removed it.
This affected lighting and underlying tiles such as the roads and grass
act now and download this for only 26.28 KB!
and if anyone wants, i have done a green version! Very Happy
maybe i'll do the monster too...
 Filesize:  510.18 KB
 Viewed:  16540 Time(s)
greenveins.tem
 Filename:  greenveins.tem
 Filesize:  26.23 KB
 Downloaded:  312 Time(s)
veins.tem
Got ma veins on and they look alot cleaner
 Filename:  veins.tem
 Filesize:  26.28 KB
 Downloaded:  345 Time(s)
With sadness in my heart and joy in my mind
View user's profile Send private message Yahoo Messenger Account AIM Address
PostPosted: Fri Jan 04, 2008 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
great idea and great work!
seems like a lot of work you've put into this, since it isn't only a color replace imo.
Do you know a way to add the green veins in addition to the original instead of replacing it? This should be really researched, since the green would be perfect as an infantry killer, grabbing them, holding them (with reaper web logic) and converting them into visceroids using the veins warhead for those.
However, some of the green veins have too bright spots in them. You should soften them a bit. Also the rest green part looks a bit plain.
Last edited by Lin Kuei Ominae on Fri Jan 04, 2008 7:38 pm; edited 1 time in total
PostPosted: Fri Jan 04, 2008 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I've seen this done before, but nice work nonetheless Smile
PostPosted: Fri Jan 04, 2008 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I've seen this done before too, but yours is actually much better. Smile Nice one, mate.
Clarkson
PostPosted: Fri Jan 04, 2008 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
You missed something.
The monster itself still has terrain under it. #Tongue
Also, pics of the green pls.
PostPosted: Fri Jan 04, 2008 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, it'll look better if you make a crater for mr. veins to sit in #Tongue
Ickus
PostPosted: Fri Jan 04, 2008 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lol I did the same thing long ago, but I also added in a grey version for snow maps.
but that does raise an interesting question.Is it possible to add in a custom veintree..and veins? doubtful. but worth a try?
Since its about veins I got a few questions to boggle ppm with.
Also is it possible for debris to spawn vein patchs like tiberium. albiet they fade away due to lack of a VHM near them. So you can add it to the debris to Chemical missile WH whichs spreads several patches of veins to harass the enemy units as well.
I did test it, by naturally giving TiberiumToSpawn=VEINS nothing happened? unless that means adding (Is)Tiberium=yes/ to [VEINS] or won't work since it isn't a valid tiberiumtype.
. but any other way to spawn overlays from debris/explosion animations?
One way you can add in green veins as a replacement to the aboreus tiberium set with the green veinset... give it a high power value..unforunately it won't play the vein attack frames when infantry walk on it..or anything else for that matter..
alternative would be a large flat building not sure if its possible to have enemy units cross over it to get damaged by the attack animation. or make it work like a sunken colony. #Tongue
Delirium..
CalChillin
PostPosted: Fri Jan 04, 2008 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
if any body wants to make it all green i have green veinhole and the veinatac
Renegangsta
PostPosted: Fri Jan 04, 2008 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
im working on it
and the attacking veins is a great idea. i was thinking instead of the veinhole, a mutated tree
i did this cause i never seen anyone do this, and thanks
willing to share?
maybe replace one of the tiberium with it
well, ya beat me Laughing
but the vienhole could use brick to green schemize
PostPosted: Sat Jan 05, 2008 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I like it, good job renegangsta!
But there is one problem: because the veins have a new image, they show up black on the radar... I know this can be fixed, but it takes much time and some haxxing skills...
partyzanPaulZy
Location: laptop? ... otherwise the Czech Republic -> south Moravia Posts: long int Posts;
PostPosted: Sat Jan 05, 2008 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work.
BTW, does anybody know, what happened with all Tiberium creatures (except of Forgotten) in CnC3 ?
Don't blame the others if you haven't checked your own (in)ability in the first case.
Suiseiseki
PostPosted: Sat Jan 05, 2008 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
partyzanPaulZy wrote:
Nice work.
EA retconned them.
Clarkson
PostPosted: Sat Jan 05, 2008 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Um, not really. Just because it didn't appear doesn't mean it doesn't exist. Toothless Pteranodons in Jurassic Park 3 don't appear, but that doesn't mean they don't exist on Isla Sorna. The old Worker Village isn't seen either, but its there.
PostPosted: Sat Jan 05, 2008 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, but the Veins should have appeared in the "Red Zones". And so should have other Tiberium-related Fona (and fauna), not just those damn Tiberium Glaciers. Red Zones appeared in TW aren't really as dangerous as they were in Tiberian Sun (Toxic levels might be high, yes, but with those titanium Zone suits you're free to walk where ever you want).
CalChillin
PostPosted: Sat Jan 05, 2008 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
hears the green vein pic, i don't think its detail that good but im working on it
 Filesize:  127.25 KB
 Viewed:  16352 Time(s)
Clarkson
PostPosted: Sat Jan 05, 2008 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're assuming that all the same animal life would form up all over the world, which is utterly stupid. I doubt Fona will evolve everywhere on the planet and look exactly the same, if they survive even. American elephants(mammoths) looked totally different from their African counterparts, and lived around the same time. Veinholes may form only in certain climates, Floaters may be swamp dwellers, who knows?
CalChillin
PostPosted: Sat Jan 05, 2008 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
hear the update
 Filesize:  157.56 KB
 Viewed:  16240 Time(s)
Clarkson
PostPosted: Sat Jan 05, 2008 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sexy. Fix the veinhole itself and make it match the others. Thats epic.
PostPosted: Sat Jan 05, 2008 9:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
The new green veins don't look right to me... They seem too bright. Confused
Machine
PostPosted: Sat Jan 05, 2008 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The darker veins look better IMO. Anyways good work, green veins = good
CalChillin
PostPosted: Sat Jan 05, 2008 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
the bright green looks alot better in game, im going to try and do a snow type one
Ickus
PostPosted: Sat Jan 05, 2008 9:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
agreed some bits are overblown but it is better looking than the one before it due to the contrast.
Sharing? I'll see if I can find it. I recall also doing a blue set for snow as well. not that is hard to create. #Tongue
Delirium..
PostPosted: Sat Jan 05, 2008 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why create a blue version for snow? Just keep the original color (or in this case, the green color), it looks much better then a blue version Wink
Ickus
PostPosted: Sat Jan 05, 2008 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I didn't like orange color for snow. tis why! but seems I don't have it anyway. #Tongue
it was years ago when I made it. but I do have a grey version if anyone wants it.
Delirium..
PostPosted: Sat Jan 05, 2008 10:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just upload them here, this is about fixed veins, and IIRC, there ain't veins for snow, so it's a fix! (gosh, I'm acting weird so late in the evening #Tongue)
Ickus
PostPosted: Sat Jan 05, 2008 10:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Grey Veins for your pleasure. just credit me if you use them.
Pix are here. Old Mod's
They're the last two images, the palette was inverted.
greysnoveins.zip
 Filename:  greysnoveins.zip
 Filesize:  27.17 KB
 Downloaded:  295 Time(s)
Delirium..
CalChillin
PostPosted: Sat Jan 05, 2008 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
dam you thats the colour i made it and it went well
hear it is
 Filesize:  243.91 KB
 Viewed:  16269 Time(s)
Ickus
PostPosted: Sat Jan 05, 2008 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
o_O..mine were more of a pale light blue, what you have there is way too saturated.
Delirium..
Suiseiseki
PostPosted: Sat Jan 05, 2008 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ickus' were and are far superior to your ones CAL. #Tongue
CalChillin
PostPosted: Sun Jan 06, 2008 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
The same goes with this one it looks a lot beater in game if you want to see hear it is
ecache97.mix
green and blue veins
 Filename:  ecache97.mix
 Filesize:  156.68 KB
 Downloaded:  254 Time(s)
PostPosted: Sun Jan 06, 2008 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Argh... That burns my eyes, I'm seriously not joking. Neutral
CalChillin
PostPosted: Sun Jan 06, 2008 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Well ok it is a tiny bit bright Very Happy Laughing
Dupl3xxx
PostPosted: Sun Jan 06, 2008 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
viens, green and sexy, and tastes like chicken Very Happy
This is a signature
PostPosted: Sun Jan 06, 2008 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the grey ones from Ickus more for a snow version then those blue ones.
BTW Ickus, you sure have some crazy ideas (points at topic where the grey veins are)#Tongue
ORCACommander
PostPosted: Sun Jan 06, 2008 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
great job either way did you recolor the mouth animations as well?
CalChillin
PostPosted: Sun Jan 06, 2008 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
ye the mouth animation as well
 Filesize:  30.91 KB
 Viewed:  16146 Time(s)
Ickus
PostPosted: Mon Jan 07, 2008 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Neutral...sorry CAL.. its very messy job. tone down the saturation. Did you recolor the grey veins I provided?
well. thanks for the comments.
Delirium..
CalChillin
PostPosted: Mon Jan 07, 2008 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
no i used the original one, and if i did use your one it would have recoloured it all.
PostPosted: Mon Jan 07, 2008 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
CAL, what are you doing?!...
You made rainbow veins Confused
Renegangsta
PostPosted: Mon Jan 07, 2008 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gay veins? Confused
also i have a voxel of rofltastic proportions coming
and a super (happily sarcastic) helipad doodle as well
Anderwin
PostPosted: Mon Jan 07, 2008 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
What program did you use to change the color?
Can you hide from me Wink?
CalChillin
PostPosted: Mon Jan 07, 2008 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
shp editor
Von Kriplespac
PostPosted: Mon Jan 07, 2008 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Renegangsta wrote:
Gay veins? Confused
Its a new craze sweeping Tiberian Sun, duh.
Anyway, I'm digging the darker colored green veins.
GameMaster0000
PostPosted: Wed Jun 18, 2008 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for dig but I think this should be useful.
Don't put this veins.tem into any ecacheXX.mix or expandXX.mix kept it in SUN folder. Because it will screw up Final Sun to display veins when mapping.
Tiberian Sun : True Power - Reality Power Of 5 Factions...
PostPosted: Wed Jun 18, 2008 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Works fine for me. Confused
GameMaster0000
PostPosted: Wed Jun 18, 2008 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
But for me it look like this.
0x7e = veins overlays
 Filesize:  228.74 KB
 Viewed:  15017 Time(s)
PostPosted: Wed Jun 18, 2008 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Green and blue veins? :/ Definately not for me.
Maritimus
Cyborg Engineer
PostPosted: Sun Apr 11, 2021 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys, I realize I am very late to this party, but I use the cleaned up veins.tem Renegangsta provided. It messed up the colour of the veins on the minimap, they appeared black.
Using Nyerguds Radar Colour Editor, I corrected the radar colours back to orange.
Anyway, just wanted to provide the fix, in case anyone else needs this.
veins.tem
 Filename:  veins.tem
 Filesize:  26.28 KB
 Downloaded:  14 Time(s)
[ Time: 0.2274s ][ Queries: 19 (0.0155s) ][ Debug on ]
