The time now is Fri Mar 29, 2024 1:39 pm
HyperPatch Announcement
Post new topic   This topic is locked: you cannot edit posts or make replies. Page 5 of 7 [320 Posts] Mark the topic unread ::  View previous topic :: View next topic
Goto page: Previous 1, 2, 3, 4, 5, 6, 7 Next
PostPosted: Thu Sep 24, 2009 10:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Err no.
PostPosted: Thu Sep 24, 2009 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
The first and last C&C that supported bigger units was TD. There the gunboat occupied 3 cells in a row.
However, you could also try to make a building mobile by allowing to change the standard locomotor for buildings from Locomotor=statue to something else. Then the standardly applied building foundation should do the job of occupying more than just one cell.
*dreaming of a jumpjet conyard* Smile
Rayne
PostPosted: Sat Sep 26, 2009 7:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
My suggestions:
  • an AIWontAttack tag for buildings, which will make the AI not attack that building.
  • the ability to set your own difficulty level in skirmish (So you might be playing on hard and your enemy easy... that'll make it hard)
This looks cool!
PostPosted: Sat Sep 26, 2009 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
It would always be nice to have a unit that can occupy at least 2x2 cells. Primarily for MMKII-like units.
Tony
PostPosted: Sat Sep 26, 2009 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
More variables as to why and how the AI would attack or defend would be a nice feature.
EX: (sw=super weapon, 95% of us know that though)
Enemy [user defined sw type] almost ready
Enemy [user defined sw type] fired
Owner[user defined sw type] almost ready
Owner [user defined sw type] fired
Chaotic General
PostPosted: Sat Oct 17, 2009 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just a quick question, would it be possible to change how the game loads terrain.
What I am thinking about, is if it is possible to have the game read a new ini file, example: have a new ini file called Terraintypes.ini with a list of terrain types, each one with its own ini file (example myterrain.ini) that acts like Temperate.ini or Snow.ini
and so it would be,
Terraintypes.ini
..Temperate
..snow
..newterrain
then each object on the list would have its own ini file,
temperate.ini
snow.ini
newterrain.ini
this would allow people to add new terrain without having to throw everything into either temperate.ini or snow.ini
plus it would be more organized, I think.
but Im just thinking out loud here.
"we must do everything possible to do the Impossible
PostPosted: Sat Oct 17, 2009 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its a interesting idea, but something that would require far too much work i think...
You never know, ill keep a note of this.
PostPosted: Sat Oct 17, 2009 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep, this would be a lot of work as you also have to add new filetypes for the new terrain to differentiate it from tmp and sno.
Maybe a simple alternative would be a "terrain loader".
This is nothing than a small program which reads the theater key in a map and then changes the name of the theater mix files.
e.g.
in the map stands
[Map]
Theater=MYTERRAIN1
Before the map-loading process starts the "terrain loader" reads the Theater key.
The mixfile myterrain1.mix contains your new terrain.
The "terrain loader" renames myterrain1.mix to temperate.mix and then the map loads from temperate.mix all the terrain stuff. After you close the map, the mix is renamed back to myterrain1.mix.
This way you don't have to add new filetypes, new autolats or other theater specific stuff, as the game still works on 2 terrain types.
PostPosted: Sat Oct 17, 2009 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im confused, wouldnt new theater types be better? I can already get the working to come degree...
PostPosted: Sat Oct 17, 2009 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
of course, complete new theaters would be awesome.
It was just an idea how you could do it, if you don't want to spend that much time in it. Wink
PostPosted: Sat Oct 17, 2009 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
New theaters are much easier, i just have to add to a array and then recode the array function a little.
Gangster
PostPosted: Sat Oct 17, 2009 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any chances of having extra palletes for terrain?
PostPosted: Sat Oct 17, 2009 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Naturally new theaters would come with their own unique palettes, or it'd be prettymuch pointless #Tongue
View user's profile Send private message Send e-mail ModDB Profile ID YouTube User URL Facebook Profile URL
PostPosted: Sat Oct 17, 2009 11:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I assume he means being able to use more than one palette within a theatre.
Chaotic General
PostPosted: Sun Oct 18, 2009 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking about this after I had posted the idea.
what I came up with, would it be possible to add a new tag
for example:
Is Tem/Sno = yes
this would then tell the game what to look for in Ecache.mix, a .tem or .sno, and you wouldnt have to create new file formats.
would that be possible?
Edit: though, if Hyper can create new theaters completely, that would be awesome
PostPosted: Sun Oct 18, 2009 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Well something like.
[NewTheatres]
1=imadesert
2=imthemoon
[imadesert]
Name=Desert
FileExtension=des
Palette=isodes
INI=Desert.ini
WhateverInfoTheGameNeeds=yes
PostPosted: Sun Oct 18, 2009 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Adding per INI is hard, more work needed, but just hardcoded another 6 would not be a problem...
djohe
Cyborg Informer
PostPosted: Thu Oct 29, 2009 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I would love to se unit specific CloakSound (think it was in RA2 but not sure) so that you can like have C&C1 Stealth sound on Stealth Tank, RA1:AM phase sound on some other and normal TS cloak sound on some others and submerge sound on submarines cloaking/submerging
Also fun to attach on units with no cloaking device and comes under the influence of a stealth generator.
Also the Redalert2:YR buildspeedmultiplier line so you can customize the built time on invidual buildings & units & stuff, very usefull for expensive stuff and very cheap vehicles messing with the war factory door anim
PostPosted: Thu Oct 29, 2009 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
The TechnoType specific CloakSounds are planned, dont worry...
PostPosted: Tue Nov 03, 2009 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok then, this is where it gets going...
Im really eager to get a release out, but there are some things that are just not 100% coded up, thus i cant release the patch with them.
So, im asking experienced modders here, what features do you find, that i have already discussed about in this topic or elsewhere would be best for a release.
Please, do post!
m7
PostPosted: Tue Nov 03, 2009 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I think the major things requested here involved RA2 logics. An up-to-date list of what is already in the HyperPatch and what you have been considering for final additions would help us figure out what we need to demand from you.
Also; you're going to get me back into modding if this is as badass as it plans to be. :p
PostPosted: Tue Nov 03, 2009 11:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well i totally restarted the patch last night, new base etc, so other than the hundred or so researched and possibly finally documents of code i have, i only want to add the ones people really need.
As a start, would it perhaps be a good idea to add some of what ETS has? If so what features?
PostPosted: Tue Nov 03, 2009 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
moved global keys to unit types
fixed logics like airtransport, nuke silo firing anim, destroyable jumpjet vehicles
super weapon clones
fixed waveclass errors
fixed 100 unit bug
2 or more working complete separate sides (fixed BuildConst, BaseUnit etc)
that's all i can come up with right now
Machine
PostPosted: Wed Nov 04, 2009 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
-Fixed jumpjet infantry sequences (Not really important, since I guess I'm the only one making infantry ATM).
-Elite Secondary, Tertiary and Quaternary weapons.
-Unhardcoded Superweapons.
Also you could look into how the Mobile EMP vehicle works, to have different vehicles that work like it, with different weapons.
PostPosted: Wed Nov 04, 2009 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
super weapon clones
fixed 100 unit bug
- Nuke Anim, i cant find what controls the anims on buildings...
- Damage to Jumpjet Vehicles i have had some trouble with, so this will be another revision later down the line.
- Super Clones, i think 2 of each should be fine.
- WaveClass stuff is already planned
- 100 unit bug will be done once i can understand VKs code
- Sides might be later down the line with a new system.
- Never been able to find the Jumpjet Sequence code, ill look more.
- Of course planned, gotta sort out some TechnoTypeClass allocations.
- How do you mean unhardcoded?
Machine
PostPosted: Wed Nov 04, 2009 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
The same thing we have always wanted, the ability to code more superweapons, and stuff like setting the contents of a droppod superweapon to something besides E1 and E2.
I guess, I should have said, generic superweapon petitions/stuff (I actually missed that LKO had typed superweapon clones though Laughing).
PostPosted: Wed Nov 04, 2009 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
well, if airtransport works, there is no need to use vehicle jumpjets. Though working hva anims and deploy logic would be nice to have on aircraft.
yep, that's very fine. Smile
please also make it ini controlled (e.g. via sun.ini), as i wouldn't like to turn it on and rather use ddraw.dll, so i can still see laser glow and ion cannon wave effects.
PostPosted: Wed Nov 04, 2009 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
BuildConst has been mentioned already, right?
PostPosted: Wed Nov 04, 2009 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
yep
but it can't be mentioned often enough. Very Happy
PostPosted: Wed Nov 04, 2009 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats it, you just killed the patch...
m7
PostPosted: Wed Nov 04, 2009 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Off the top of my head, some ideas. These were already discussed, and I generally tried requesting anything that didn't have code elsewhere.
New features:
- Deglobalization of things like Jellyfish logic and Visceroid logic could be useful to those who love the environmental effect.
- SWs triggering Ion Storms is also something I thought would be useful in TS.
- Return of Naval Yard logic (look into YR?)
- Disabling Storage to have the economy work similar to RA2/YR
- Tech Oil Derrick logic
- Custom armors, like Ares
- The -CD command reimplemented
- Support for more side-based .shp files. Maybe even include voxels?
Bug fixes:
- *Types limit fixed
- Component Tower Bug fixed
- The load time from having skirmish maps loose in the directory would be something worth looking into.
- Fixing other bugs, like the WaveClass and the
- Lag from moving across the screen while building something is rather annoying, it could be worth looking into.
0warfighter0
PostPosted: Wed Nov 04, 2009 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
-The ability to add new custom pallets
-Shp units wich have "slope climbing" support
Ordosherrscher
PostPosted: Wed Nov 04, 2009 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
bug fixing:
-Art.ini doesn't really look at the warhead
-particels ignore TypeImmune
that came just through my mind Very Happy
Think of me as Nordos, 'cause Banshee wouldn't rename me
PostPosted: Wed Nov 04, 2009 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just found out that it indeed works correct and perfectly fine the way it is.
You just have to understand how TS uses the warheads and anims, which is imo a very wise solution by WW.
TS knows 2 different types of anims: normal frame based anims and debris.
1. frame based anims like fire use by default the warhead "Fire2" which is set with the key "FlameDamage2=" in rules.ini [CombatDamage]. This is necessary to make sure, that the warhead has Sparky=no, or every anim with damage would create a feedback loop that creates more and more flames.
The damage on these anims is done on each frame, thus they also allow floating point damage like "0.06".
2. art.ini debris (like meteors) use perfectly fine the warhead which you assign to them. They just don't use the animation of the warhead, to again prevent a feedback loop where an art.ini debris creates a warhead anim which in turn could create an art.ini debris again.
The damage on these anims is done only once on impact, thus they only allow integer damage (Damage=0.99 would be changed to Damage=0).
PostPosted: Wed Nov 04, 2009 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
How come meteors in unmodded TS (or FS) have a warhead called Meteorite, and even though the meteors themselves do little but some damage, the warhead doesn't even exist on the warheads list :/
PostPosted: Wed Nov 04, 2009 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
just a mistake by WW as they forgot to add it. Since nearly all keys have default values, the Meteors still work and do damage. They simply use Verses=100%,100%,100%,100%,100% and Spread=1
PostPosted: Wed Nov 04, 2009 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm could try and fix the gclock2 lag.
PostPosted: Thu Nov 05, 2009 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
That i cant fix, but i think it has to do with the way the SHP is drawn over the cameos.
Rico
Tiberian Beast
PostPosted: Fri Nov 06, 2009 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
- The ability to use the jumpjet locomotor on vehicles without needing railguns to shoot them down would be a must in the first version IMO.
Ordosherrscher
PostPosted: Fri Nov 20, 2009 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
CCHyper wrote:
Really? Game is the problem?
Ill have to look at this and see if there is a transfer limit. Remind me Wink
PostPosted: Fri Nov 20, 2009 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
What was that in relation to again? #Tongue
Ordosherrscher
PostPosted: Fri Nov 20, 2009 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Transfer Limit of Maps, if the number of players is too high (after a special time, the transfer stops, and all got a reconn error, because the maps aren't the same)
about 100kb for 8 players is maximum, maybe less
Blade
PostPosted: Fri Nov 20, 2009 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe it is a time out, only so long is given for map transfer to occur so it depends on what every players connection speed is. If everyone has broadband it is probably considerably more than 100kb these days.
Ordosherrscher
PostPosted: Fri Nov 20, 2009 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
even with fastest speed, I think, there is a cap for the transfer speed. Since it always takes not less then a specified amount of time....
Thats my experience... And I play TS about 2 years online Wink
PostPosted: Thu Nov 26, 2009 7:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hardcoded cap? ill look into it after...
It seems my primary hard drive is on its way out, and i dont feel like tempting fate again, becuase Recoil was lost the same way...
HP will be on hold for X amount of time, until i can afford a new drive.
PostPosted: Thu Nov 26, 2009 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Back-up! Now!
PostPosted: Thu Nov 26, 2009 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Doing so, its all good.
Ordosherrscher
PostPosted: Thu Nov 26, 2009 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm.... it would be great if you could expand the 'Land'[Country] Logic, so that you can add more thinks like
[Nod]
Power=...
TiberiumHeal=yes ;all Units build byx this side got this tag
-> all tags listed under these factions, should overwrite the definition for this faction. Dont know if it can be done, though
EDIT
sorry for being confusing^^
PostPosted: Thu Nov 26, 2009 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, you mean country/house. Calling it the 'Land' logic is a bit confusing #Tongue
PostPosted: Sat Nov 28, 2009 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yea, that is possible, but i wont think about doing it for everything, only things needed.
Post new topic   This topic is locked: you cannot edit posts or make replies. Page 5 of 7 [320 Posts] Goto page: Previous 1, 2, 3, 4, 5, 6, 7 Next
[ Time: 0.2182s ][ Queries: 11 (0.0201s) ][ Debug on ]
