The time now is Tue Apr 23, 2024 11:50 pm
[FS] Siege City (2-4)
Post new topic   Reply to topic Page 1 of 1 [32 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Sun Nov 04, 2007 9:16 am    Post subject:  [FS] Siege City (2-4)
Subject description: updated to 1.35
Yes, when I started this map I opened up FinalSun for the first time, in back in September 2006.
March of 2007, posted a preview, and it's really come a very very long way since then.
After a great deal of adjustments, monotony, failures, and successes - there were many times where i just wanted to scrap this map entirely.. but I kept with it, till now - I think it's finally ready for public release!
Behold the megamap:
(last minute change - tib by player's bases is now green instead of blue)
This map is called "Siege City" for a good reason. As you will notice, all four players are in well fortified in each corner. However, there's limited tiberium by each base. In order to maintain a good economy, players must venture out into the larger tiberium fields, where their harvesters are more vulnerable. I've made several structures capturable, which players may use to extend the reaches of their base.
al of the Tiberian Dawn buildings (power plants will supply power - also keep in mind the TD buildings aren't repairable),
solar panels (supply power)
Civilian array (radar, and cloak detector)
Civilian armory (lets you build sandbags... lots of em)
You may also utilize the civilian air transports as you see fit - simply load up a tranport with 5 troops, and it will automatically fly to the next airbase and unload. The Chinhook transports travel in a clockwise direction around the map from base to base, and the orca transports travel counterclockwise.
The civilians in this region are aware of the importance of maintaining a steady transit system. If the train in operation happens to be destroyed, another one will automatically take its place.
(no, bikes aren't equipped with core defender guns in the final version - that was just for testing Wink )
Features I wanted to implement, but ditched:
>This was originally going to be a TS:Retro map, using dropship/dropship bays as the civilian air transports. Firstly - I couldn't get it all to work properly, second - the map was crashy with Retro. Third - Retro isn't really that good of a mod anyways..
>I wanted the trains to carry & unload passengers. You have no IDEA what kind of mental pain and agony I went through trying to get this to work. What little I learned from all that mind grinding is posted in the train research topic.
>I wanted to implement a day/night loop where the mutants turned enemy at night, then ally at day.
I got a good day night loop going, but I couldn't get my trigger to spring correctly. Not only that, but my on/off day/night lightposts weren't even working the way I wanted. I figured, even if I were to put in this feature, I wasn't even really sure if it would be good for the gameplay aspect of the map. After much frustration, I deleted all the mutants, and the day/night triggers (which screwed up my trains, so then I had to play with those a bit to get em working again :wall: )
Now at 4AM Nov 4th, here it is at last. Enjoy Wink
EDIT: Now updated to 1.35 as of the last edit. Fixed air transports, trains, tunnels, bridges, and every error I could find (thanks LKO for finding some errors Smile )
EDIT: updated links to tiberiumweb.org
Siege City 1.35.zip
 Filename:  Siege City 1.35.zip
 Filesize:  173.65 KB
 Downloaded:  2937 Time(s)
hogo98
PostPosted: Sun Nov 04, 2007 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Map of EPIC WIN! Wow Nice map team Black. I would like to ask you if I could Convert this too RA2 Map and Credit you of course Smile Thanks
Hogo
And keep up the awesome Mapping.
Thanks for the banners GM
warlord
PostPosted: Sun Nov 04, 2007 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thats your first map? Because if it is that is GREAT for your first one Very Happy
Signature By Aro^
"So long as there are men, there will be wars." - Albert Einstein.
PostPosted: Sun Nov 04, 2007 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The triggers are awesome. The map layout is great. Neat work, man!
Oshog
PostPosted: Sun Nov 04, 2007 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Immediate spotlight.
I love it.
m666
PostPosted: Sun Nov 04, 2007 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm gonna play this for the next few days. This is a great map.
I vote for spotlight, the trigger work, lighting effects, and everything about it looks more epic than one could imagine.
If Hogo makes this for RA2/YR with all triggers and the epic dynamic lighting, he should post it here for spotlighting too.
Good damn job, Team Black. Good damn job.
Tartan Bunny
Flamethrower
PostPosted: Sun Nov 04, 2007 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is one great map, especially for your first ever. I Like how you have the bursts of colour, and the triggers look great. You sure deserve a spotlight.
m666
PostPosted: Mon Nov 05, 2007 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I played it offline with the AI, then tried in TSD with no success with Judeau.
This map is definitely one of the best I've ever played. I second my motion on my vote for spotlight.
PostPosted: Mon Nov 05, 2007 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comments! For the effort I put into this map, I really appreciate the feedback Smile
I'm also planning to make a remixed version of this map for TS:Dusk
Styledatol
Flamethrower
PostPosted: Mon Nov 05, 2007 10:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something weird happened...
I was playing in the North Western Corner, and I noticed that the bridge above the river was destroyed. Than my Titans developed a Jesus Complex and walked on water where the bridge is supposed to be.
PostPosted: Wed Nov 07, 2007 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed. Thy faithless titans shall henceforth be bound to the land, as is proper.
Also made the train "neutral", with less strength, and some other minor changes
So, any chances of a spotlight, Bansh?
Tartan Bunny
Flamethrower
PostPosted: Wed Nov 07, 2007 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
You know what would really put the cherry on the cake? Some of your civvy units going round the map, and incorporate some Terrain Expansion, it has some really good road bits
PostPosted: Thu Nov 08, 2007 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I think Dusk is using TX.. and yea I did make some traffic. I could throw in some more traffic in Dusk, since it will also feature my civilian voxel 12 pack
PostPosted: Fri Nov 09, 2007 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
This map will definitelly be evaluated for spotlight, after my physics test.
PostPosted: Fri Nov 09, 2007 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I just noticed something. The veinhole in the middle of the city is highlighted with orange light, whereas the veinhole in the bottom of the map has no lightning at all (or negative lightning). Either remove the lightning from the other veinhole, or add the orange lightning to the other veinhole.
PostPosted: Fri Nov 09, 2007 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
The one on the top has lighting because it's in a lighted city. The one in the bottom is in a sort of no-man's land, and to gie it additional light would take away from the effect
Ixith
PostPosted: Sat Nov 10, 2007 9:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
me on tibweb wrote:
Well I played it and I must say it was quite good. Though of course I always come up with stuff to say about it and how to improve. smile.gif
Cliff work: 8.7/10 no cliff errors were found. They just seemed...well....that the placement style was quite repetitive across the map. Also I'm adding it to this section because it kinda has to do with cliffs but anyways 2 of your back facing tunnels were overlapped by other things. 1 is near way point 21 and its where the train ramp comes down right after the bridge. I think its being caused by the back tunnel being too close to the ramp. 2nd one is up in the top right by that war factory. The war factory kinda, though not too badly, overlaps the tunnel and kinda looks weird. Also a third thing is next to that where the tunnel opens up on the other side and goes to a bridge across a water way...part of the bridge looks like a normal overlay was placed on top of it and it made me think there was a cliff error at first. I suggest fixing that.
Layout/concept: 9/10 it was an interesting layout however I didn't really like how there was only 1 access into each base except the bottom left player who had 2 bridges although he could choose if those bridges would be destroyed and would stay that way.
Lighting: 8.8/10 the lighting was great. Just needed a day night loop and maybe something more on the city area as for some reason I felt that was lacking something.
Triggers: 8.5/10 the trigger were nice. although I do suggest putting the meteor shower thing to be a little later on as I didn't get to see it as I was still getting my base set up to basics and scouting around the general area. Coulda possibly used an ion storm in there somewhere.
Game play: 7/10 this one hurt ya i think. Due to small things here and there I really didn't like game play. The AI played how they normally play. However, at times it was just too easy to defend against them due to there only being 1 entrance to a base and it being easy to protect from AI. also I really disliked the sniper things...too many of them here and there made for an annoyance IMO when traveling around and getting sidetracked on "where the hell is that stupid thing" XD sure it was a laugh for awhile but it just wasn't that great.
Overall: 8.4/10 Spotlight worthy** (truthfully i think i go too easy on my judging though XD ) All in all I say this would make for a better map to play against other people online much more than against an AI as the AI is just too easy to defend against but bundles up their artilleries/juggernauts and makes it hard to penetrate their base except via air. So against the AI you get a kinda long boring game.
Now this one I didn't add because its more of a stupid AI thing than anything but the top right AI just kept shooting at a random part of the laser fence walls with their juggernauts. They didn't target the building towers.....just a section of the wall which does nothing obviously. So yea.... thats just one reason not to include walls a lot of the time.
is this a long enough review for ya XD didn't expect it to be THIS long.
**Note that spotlight is harder to get here on PPM usually so yea...I mean come on Yelcraz didn't or at least hasn't gotten spotlighted.
Kalistia Crestland (2)
Denmon
PostPosted: Sun Nov 11, 2007 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
That is amazing! I love it!
PostPosted: Tue Dec 25, 2007 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Version 1.3
>fixed air transports, now they work %100!
>added more delay on the meteor storm
>removed that random old war factory
>Civilian mammoth tanks & gates don't reveal shroud
Download the newest version here
Crash
PostPosted: Wed Dec 26, 2007 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
What you could've done better, is making the fonas smaller, they are a bit large. Some of them are.
PostPosted: Wed Dec 26, 2007 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
There is too much of the same LAT tile used in some places, for instance all four of the starting possitions. Though, the game-play easily makes up for that. This map still has my approval (As we agreed in the Intoxication thread #Tongue).
I Wonder what happened to the spotlight round up? Intoxication and Seige City where not spotlighted? =S
Edit : Err, Team Black? There is a spawning problem. When I started up the map, My units where spawned right next to one of the chinook's. Confused This is normally caused by a C'n'P Error, It's happened to me once before. Did you do any Copying and Pasting on the newer version, Blackster?
PostPosted: Wed Dec 26, 2007 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Crash, I appreciate the feedback, but that's a pretty silly thing to complain about #Tongue
I place all the unused player waypoints in one spot ,so I don't have to worry about em when I'm using the "place waypoint" tool -
'cept I forgot to delete em after I was done Laughing
Updated to 1.31:
>Start locations fixed
>Some snipers removed
Download the newest verson here
Crash
PostPosted: Tue Jan 01, 2008 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's not a silly thing to complain about, huge blocks of fonas are ugly #Tongue
You want to make the map as good looking as possible don't you?
PostPosted: Tue Jan 01, 2008 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
This map has been spotlighted!
PostPosted: Wed Jan 02, 2008 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a ton Bansh!
I made another small update to v1.32
>Removed sniper billboards
Because of the change, this map now works in Dusk Smile
(it was a REAL bugger figuring out what the problem was)
DeathMummy
PostPosted: Wed Jan 02, 2008 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Can we have the newest/latest download then TB :p ? Brilliant, it deserved the spotlight with all the hard work you put into it.
Edit: TB, btw the TS Dusk link in your sig doesn't work...better fix that #Tongue!
http://www.ppmsite.com/forum/files/tifansig1_copy_180.png[/img][/url]
PostPosted: Wed Jan 02, 2008 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The link in the first post will give you the latest version.
I'll fix my sig soon, to represent the new project that I'm working on Wink
Jeffman12
PostPosted: Sun Apr 13, 2008 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
The file host you're using is dead. This makes me sad.
PostPosted: Sat Jul 05, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
updated - fixed many errors, and it is once again available for download! (no thanks to stinky sagafx)
Dregon Wars
PostPosted: Sat Sep 20, 2008 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thenks , Cool Map
superdjidane
Cyborg Engineer
PostPosted: Sun Dec 04, 2011 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Good map design. (City and infested zones)
I just notist that the train is bugging on a bridge (stop) A little shame...
Great Works.
GREEN
Light Infantry
PostPosted: Tue Mar 21, 2023 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
[ Time: 0.2135s ][ Queries: 13 (0.0094s) ][ Debug on ]
