The time now is Wed Apr 24, 2024 5:33 pm
Naval Yard/Alt war factory V 2.0
Post new topic   Reply to topic Page 1 of 1 [44 Posts] Mark the topic unread ::  View previous topic :: View next topic
Machine
PostPosted: Sun Jul 01, 2007 7:03 pm    Post subject:  Naval Yard/Alt war factory V 2.0
Subject description: Without using mobile buildings
I suggest you to read Morpher's Naval Yard/Alt war factory, if you can understand it properly, and apply it to your mod you should be able to understand this, as it's heavily based on it. With this you can replicate an almost exact copy of RA shipyards, though it's more close to RA2 shipyards Laughing
Knowledge/Abilities required:
-Full understanding of Morpher's tutorial.
-Create new sides.
-AI editing (very little)
-Common rules.ini modding
Notes:
-It will work fine if captured.
-It doesn't need to be deployed from a vehicle, you can build it from the Conyard.
-It won't cause problems if it's not the primary building, in fact it doesn't matter if you set the naval yard or the war factory as primary, vehicles will be built from the appropriate building.
-You can set some vehicles to be built from both factories (RO's using that for GDI hovers).
-It has the same limitations than Morpher's method; the AI won't use it properly(I suggest that it shouldn't be allowed to build units from the alternate warfactory), and you won't be able to build a unit from each warfactory at the same time.
-It will make you reach the 100 units limit faster.
-It works with any type of factory.
-This was the real reason to include a navy in RO, as I wanted to utilize this logic.
-This was originally RO exclusive coding feature, however I decided than that was being mean with the community, as all mods should post their discoveries
-Screenshots of this will appear soon in RO forums; I'll fix the link when ready.
-Only few people knew this logic, since I told them Laughing, RO modding team, and Morpher, maybe some other TO members, as he might have included/discussed this logic.
Introduction to Morpher's method:
Well, we have all noticed that if we capture an opposite side's factory, we'll be able to build their units, and those units will only come from their respective factory.
So a side's factory just builds their own side units. As Morpher said, if we make a factory with owner=Neutral, only units that belong to the Neutral house will be built from there (with owner=Neutral).
The problem to exploit this was how could you build another side's factory, if this already limited you (your conyard has it's ownership tagged to the side you chose when you start the game, so you can't build enemy buildings, even if they have the same prerequisite, since they have owner=the other side. Also this seems to apply only to conyards, as factories keep dual ownership if built by some side).
Morphers solution was to abuse deploying code, which allowed units from an specific side to deploy into buildings from other side. With this, he created 1 virtual (dummy) side for each side, a set of units and a factory that were owned by one of those sides.
However it had a big problem, the building couldn't be placed from the conyard, losing the RA feeling to it.
Machine's Extended Method:
To have that RA feel it would be necessary to have naval yards built from the conyard; this was thought to be impossible, however I found a workaround (not really, it was more like theorical illumination Laughing)
All I had to do was to find a way to build a building from another side. The answer was really easy, just had to set owner tag to a dual owner.
Owner=GDINAVAL,GDI
Example coding from RO:
; GDI Ship Yard
[GAWEAP2]
Name=Ship Yard
WeaponsFactory=yes
Factory=UnitType
WaterBound=yes ; just if you want it as a shipyard
AIBuildThis=no
Owner=GDINAVAL,GDI
In this way I could build the naval yard from the conyard, however a problem appeared, ground units could be built from the naval yard. So i gave the warfactories an small edit. Owner=GDI,GDIARMOR
; GDI Starport
[GADROP]
Name=Starport
WeaponsFactory=yes
Factory=UnitType
Owner=GDI,GDIARMOR   ;*;
And then made a clone of every GDI unit built by the AI. And gave to the originals, the ones that are going to be built by the player, Owner=GDIARMOR instead of Owner=GDI
After that I edited AI.ini to suit the changes made to the units, ensuring than the AI was only able to build the cloned units.
; Medium Mech; built by the player
[MMCH]
Name=Titan
Owner=GDIARMOR
; Cloned Medium Mech; built by the AI
[CMMCH]
Name=Titan
Owner=GDI
Doing this, the result would be that the player could only build units with Owner=GDIARMOR on his warfactory and units with Owner=GDINAVAL on his shipyard.
However this is not the end, as you would have the cloned units in your build tab greyed out, and have the new constructions options bug every time you built a new unit/building. Finally, to have the logic properly working, I had to get rid of the bug, the edit is quite simple, an exploit of AI cheats.
Since the AI ignores the prerequisites, I gave all the AI clones an extra prerequisite, a dummy building which could be never be built by the player, in this way, the player wouldn't notice any change and have 2, or more alternate warfactories built from the conyard working without problems withing them.
[CMMCH]
Name=Titan
Owner=GDI
Prerequisite=GDIFACTORY,DUMMYBUILD
;DUMMYBUILD exist in the building list, and has it's own entries to prevent any problem.
Finally I edited AI.ini. not a hard change just replaced the original unit entries with their cloned versions, be sure to do it in Firestorm too.
Key Words: #Tutorials #Modding #TiberianSun #Firestorm #Rules.INI #AI.INI
PostPosted: Sun Jul 01, 2007 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant, my day just gets better and better!
DragonFly
PostPosted: Sun Jul 01, 2007 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I havn't tested it yet but this should work for creating seprate factorys for anything not just ships. (eg if your useing vechicles with jumpjet loco you could have them built by a hanger rather than the warfactory)
Machine
PostPosted: Sun Jul 01, 2007 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wink Exactly, I also tested it as a helicopter factory, using a helicopter which was, in reality, a shp infantry. However now, with Team Black's research, it could be perfectly used into making a jumpjet aircraft factory #Tongue
BTW, it does work, at least it does in RO. I hope, that I haven't forgot some small coding, so when you test it, please notify me if it worked #Tongue, as I don't want to have posted it incomplete; anyways I don't think that something is missing, it's just to be safe.
DragonFly
PostPosted: Sun Jul 01, 2007 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
one improvemnt you can make:
There is no need to change the ai.ini at all. Make the origenal the one for the AI and your copy the player version. (as i did when testing the above)
And yes it did work apart from some minor bugs that came from me adding the image= to every object includeing those that already had an image= resulting in it looking for non existant grafics)
Machine
PostPosted: Sun Jul 01, 2007 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I know, though I prefer it that way, it was the same thing than Morpher suggested long ago.
Good that it works fine, now I know that I didn't forgot anything #Tongue
Creagor
PostPosted: Sun Jul 01, 2007 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aha, the secret finally revealed eh?
I think there is a bug with this I found while testing btw - it relates to the "mutant hijacker" type units in online multiplayer. When you capture a "double owned" unit with it, afik you do not get the unit.
Judeau
PostPosted: Mon Jul 02, 2007 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I've researched this method a little more, i've elimiminated the need for AI clones, and i've found a bug with the MCV, due to it's nature, it can also go out of the naval yard/alt factories
but i'd say that's an acceptable bug, i've tried to fix it, but it all got rather messy, so i simply let that little bug remain
Micro TS
Portable, no campaign, movies or music, just the engine and needed resources for skirmish and lan.
Clarkson
PostPosted: Mon Jul 02, 2007 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Curious, but will the AI actually use these units if given them in a taskforce? or is this only for human players...?
Judeau
PostPosted: Mon Jul 02, 2007 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
i suppose you could try, in fact, i'm going to try once i get back home, seeing the ai attack you with ships would simply be way too cool
knowing the ai though, the bastard will probably be entirely useless with em
Micro TS
PostPosted: Mon Jul 02, 2007 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
if I recall correctly, AI are also allowed to disobey TechLevel=-1, right?
I think I remember mutants building 4tnks in that one Nod firestorm mission.
Nice work, Machine XD
Machine
PostPosted: Mon Jul 02, 2007 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought that too, but I made some test with that, and the AI ignored the scripts with units with TechLevel=-1 Confused
@Carnotaurus:
AFAIK, the AI won't use them even if you add the taskforces, since naval units would belong to another faction. Also I think that's likely that the AI would ignore the hack and still get units from every warfactory.
@Creagor:
Weird, I didn't notice any bugs with the mutant hijacker other than hijacked units which are not selected with the same type of units (that's because the AI units are clones, and not really the same unit)
@Judeau:
It would be good if you could post the changes you made #Tongue. BTW I don't have any problems with the MCV, AFAIK.
PostPosted: Mon Jul 02, 2007 7:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh I see - they gave the 4tnk and mutants TechLevel=11 and made the [GDI] house techlevel=11
so that's only something that'll work on singleplayer I guess
PostPosted: Mon Jul 02, 2007 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't play around with AI and TechLevel much, but was there not a comment in the RA1 rules or something saying that TechLevel=11 or above are for special case only... maybe that means AI...
Judeau
PostPosted: Mon Jul 02, 2007 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Machine wrote:
@Judeau:
GDIN and NodN mean "normal" unit
GDINAVAL means naval unit, same with nod
[MCV2] ;home for GDI and Nod
Nominal=yes
Name=Mobile Construction Vehicle
Image=MCV
Prerequisite=Factory
Strength=6000
Category=Support
Armor=heavy
DeploysInto=gacnst
TechLevel=1
Sight=6
Speed=4
Owner=GDIN,NodN,GDI,Nod ;if i include the both standard and "normal unit" designation, it SHOULD not be buildable from the naval yard, it does exit the blasted thing as well though
CrateGoodie=yes
Cost=2500
Points=250
AllowedToStartInMultiplayer=yes
ROT=5
Crewed=yes
Crusher=yes
Explosion=TWLT070,S_BRNL58,S_CLSN58,S_TUMU60
VoiceSelect=25-I000,25-I002,25-I004,25-I006
VoiceMove=25-I012,25-I014,25-I016,25-I018,25-I022
VoiceAttack=25-I014,25-I022,25-I024,25-I026
VoiceFeedback=ZAP,SERVO-BUG1,SERVO-BUG2
MaxDebris=24
ThreatAvoidanceCoefficient=1.00
Weight=3.5
MovementZone=Normal
ThreatPosed=1   ; This value MUST be 0 for all building addons
DamageParticleSystems=BuildingSparkSys,SmallGreySSys
SpecialThreatValue=1
ZFudgeColumn=12
ZFudgeTunnel=15
[GANAVYARD]
Nominal=yes
Name=GDI Naval Yard
Image=GDIYARD
WeaponsFactory=yes
Factory=UnitType
Prerequisite=GARADR,GAWEAP
DeployTime=.022
Strength=1400
Armor=concrete
TechLevel=1
Sight=6
BaseNormal=no
Cost=2000
Points=200
Power=-50
Capturable=false
Repairable=true
Crewed=no
Bib=no
Adjacent=20
WaterBound=yes
MaxDebris=8
DamageParticleSystems=BuildingSparkSys,SmallGreySSys,BigGreySmokeSys
DamageSmokeOffset=408, 880, 435
AIBuildThis=no
Owner=GDINAVAL,GDI
DeploySound=MECHANICAL2
; Medium Mech
[MMCH]
Nominal=yes
Name=Titan
WalkRate=2
Image=MMCH
Primary=120mm
Elite=E120mm
Strength=1300
Category=AFV
Armor=heavy
Turret=yes
IsTilter=no
TooBigToFitUnderBridge=true
TechLevel=3
Sight=8
Speed=4
CrateGoodie=yes
Crusher=yes
Owner=GDIN ;titans exit the right building as they should
Cost=800
Points=40
ROT=5
MaxDebris=6
Locomotor={55D141B8-DB94-11d1-AC98-006008055BB5}
MovementZone=Destroyer
ThreatPosed=5.5   ; This value MUST be 0 for all building addons
DamageSmokeOffset=100, 100, 275
Weight=1.5
VeteranAbilities = FASTER,STRONGER,FIREPOWER,ROF,SIGHT,SENSORS,VEIN_PROOF
EliteAbilities = FASTER,STRONGER,FIREPOWER,ROF,SIGHT,SELF_HEAL
Accelerates=false
ZFudgeColumn=8
ZFudgeTunnel=13
CloakingSpeed=3
this should be enough info for you
Micro TS
Machine
PostPosted: Tue Jul 03, 2007 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Judeau wrote:
[GANAVYARD]
Name=GDI Naval Yard
Owner=GDINAVAL,GDI
With that coding the MCV should be able go out from the naval yard, as both have owner GDI, just remove GDI, NOD from it's owners, and the problem would be solved.
Judeau
PostPosted: Tue Jul 03, 2007 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Machine wrote:
Judeau wrote:
[GANAVYARD]
Name=GDI Naval Yard
Owner=GDINAVAL,GDI
except the resulting mcv would deploy into a conyard with owner GDIN or NodN
which can't make most buildings
and don't forget it can't be a starting unit anymore then
i tried making mcv clones with only GDIN or NodN, with their own conyard clones to deploy into
but a lot of build options were unavailable with those
Micro TS
DragonFly
PostPosted: Tue Jul 03, 2007 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
ive got around this by having owner=Civilian on all buildings and then using
Prerequisite=GACNST2 ;New GDI Con Yard
and
Prerequisite=NACNST ;New Nod Con Yard
on all the buildings so only the correct sides can construct the buildings.
(this requires each side having it's own MCV and Con Yard)
Judeau
PostPosted: Tue Jul 03, 2007 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
and
interesting, implementing now
Micro TS
DragonFly
PostPosted: Tue Jul 03, 2007 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another note I forgot. The starting MCV's and the buildable MCV's are seprate.
Main diffrences are:
Start MCV:
Owner=GDI
Buildable MCV:
Owner=GDIARMOUR
This means the mcv the player builds is GDIARMOUR so must come from the correct factory but the starting one is able to be given at map start.
They both deploy into the same structure so if deployed then undeployed they would both end up being the buidable version.
Judeau
PostPosted: Tue Jul 03, 2007 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Start MCV:
Owner=GDI
Buildable MCV:
Owner=GDIARMOUR
that was what i tried when i said it got messy
i seemingly messed up the buildings then
Micro TS
Machine
PostPosted: Wed Jul 04, 2007 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
MCV Coding, that I'm using:
;Buildable MCV/Starting MCV
[MCV]
Name=MCV
Prerequisite=FACTORY,TECH
DeploysInto=GACNST
TechLevel=10
Owner=GDIARMOR,NODARMOR
;AI's MCV
[CMCV]
Name=MCV
Prerequisite=FACTORY,TECH,DUMMYBUILD
DeploysInto=GACNST
TechLevel=10
Owner=GDI,Nod
That should solve your problems #Tongue
space_marine
PostPosted: Mon Jul 09, 2007 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
in theoretical terms, wouldnt this allow you to have a third.....well......very complicated and messy working third side?
go to http://uni2.star-battle.com/regref.php?id=1145 and join star battle!!!!!! its kinda fun if you get into it.
Judeau
PostPosted: Mon Jul 09, 2007 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
we already could make more sides
I might write up some extra tutorials to show how one does all these things together
[MCV]
Name=MCV
DeploysInto=GACNST
TechLevel=10
;AI's MCV
[CMCV]
Name=MCV
DeploysInto=GACNST
TechLevel=10
Owner=GDI,Nod
WRONG Laughing
sorry, couldn't help myself
either way if it's a buildable MCV, it can't be your starting MCV
seeing as the sides you start with are GDI and Nod.
But, don't worry, I know how to do it properly
Micro TS
Machine
PostPosted: Mon Jul 09, 2007 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Judeau wrote:
WRONG Laughing
Weird, it works perfectly for me. Even after setting the owner to different sides. I mean, that I still get that MCV (Owner=GDIARMOR,NODARMOR), maybe BaseUnit=MCV has something to do with that.
Well anyways, if it causes problems to anyone, just invert both MCVs, it should work properly.
Something like this:
;AI's MCV/Starting MCV
[MCV]
Name=MCV
DeploysInto=GACNST
TechLevel=10
Owner=GDI,Nod
;Buildable MCV
[CMCV]
Name=MCV
DeploysInto=GACNST
TechLevel=10
Morpher
PostPosted: Wed Sep 23, 2009 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to drag up this old tutorial but I'd like to ask machine if he has used this tutorial to create anything like the following:
GDI Ground Factory, GDI Naval Factory
Nod Ground Factory, Nod Naval Factory.
I used this tutorial to achieve this and ever since adding these new houses and creating the buildings I have been getting this problem again:
http://www.ppmsite.com/forum/viewtopic.php?t=21375
[TiberianFuture]
Scrin Overlord
PostPosted: Wed Sep 23, 2009 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had that FS problem I while ago too, I solved it by removing few houses that I had added. It is possible that there's maximum number of houses
you can add. If this is the case, the limit is 6 (including neutral+special).
[I had GDI, Nod, Special, Neutral, GDINaval and CABAL as houses and it worked. Then I added Forg and CABNaval and FS refused to work.
I got it to work again by removing GDINaval and CABNaval.]
Check out some TF Kane's Wrath action:
Tournament 3rd place.
Vs. bikeRushOwnz in tournament.
Ladder wars vs. bikeRushOwnz.
Morpher
PostPosted: Wed Sep 23, 2009 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm it used to work previously with:
GDI
Nod
Neutral
Special
GDINaval
NodNaval
Neutral2
So I don't know. It was when I incorporated this new logic and I had to create a new house for each sides Ground units:
GDIGround
NodGround
PostPosted: Wed Sep 23, 2009 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
do you added them to end of the Houses list?
TI has
GDI
Nod
TMF
GDIA
GDIB
NodA
NodB
Neutral
Special
and FinalSun as well as the game work perfectly well.
Morpher
PostPosted: Sun Dec 13, 2009 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm dragging this up yet again, but ever since I've used this alternate method, my G.D.I. A.I only ever builds Hover MLRS, and not any of the original units, and I really can not see why?
I may be completely wrong and this has nothing to do with it, just the Hover MLRS is the only unit thats buildable in both a war factory and a naval yard.
PostPosted: Sun Dec 13, 2009 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want, you can PM me the inis and i have a look at them.
Right now i have no clue why this tutorial isn't working for you.
In TI I used this to have 2 helipads and 2 barracks for one side. The separated aircraft/infantry work and don't even need clones of the units.
PostPosted: Tue Jan 12, 2010 10:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just noticed an issue with this workaround.
Whenever you capture a building that is the prerequisite for the other sides warfactory, you get a greyed out build-option for that warfactory.
e.g.
you play Nod
and the GDI weaponsfactory has
[GAWEAP]
Prerequisite=GAPILE
Owner=GDI,GDIARMOR
If you then capture GAPILE you get a greyed out build-option for the weapons factory that is listed at the end of your buildlist and you always hear EVA saying "new building options" whenever you finish building something.
I've isolated this problem already to the dual ownership of the building. If you would have only one owner (regardless if GDIARMOR or GDI), the greyed out build-options bug doesn't occurs.
It seems the game just checks
If Owner has more than 1 entry,
then show the building for all player who have the correct prerequisites
and not
then show the building for all player who have the correct prerequisites and the correct Owner.
Has anyone found a solution for this problem?
I guess this is the reason why RA2 has the key ForbiddenHouses.
PostPosted: Tue Jan 12, 2010 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
You think ForbiddenHouses fixes this? Ill look into it right away. Very Happy
PostPosted: Tue Jan 12, 2010 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure, but i think that's one purpose of this key.
Though RA2 also profits from the fact of having separate conyards for each side which can be assigned as prerequisite to the problematic buildings with more than one owner. And since you'll never be able to have all the necessary prerequisites without the conyard that builds the building, this could be why the greyed-out-build-options-bug doesn't happens in RA2.
PostPosted: Tue Jan 12, 2010 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
ForbiddenHouses is checked in HouseClass::Can_Build() and HouseClass::Generate_AI_Build_List(), also checks if it can build a building type from the games array, i think that is about where it chooses AI lists.
PostPosted: Tue Jan 12, 2010 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just checked modenc and RA2 still has the same problem
http://modenc.renegadeprojects.com/New_Construction_Options
There it seems to be fixed simply by assigning the side specific conyard as prerequisite to the navalyard and warfactory. (lazy/sloppy programmers that #Tongue )
right now i can only think of adding the other house to the building to fix the New-Construction-Options bug.
e.g.
you play Nod
[GAWEAP]
Prerequisite=GAPILE
Owner=GDI,GDIARMOR,Nod
Then you would be able to build the GDI weaponsfactory as soon as you capture the GDI barracks. But you don't get the NCO-Bug anymore.
Machine
PostPosted: Wed Jan 13, 2010 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't remember what I did, but I guess it was that.
Anyway, you could add GDI's power plant to the prerequisite, so the player can't build GDI's war factory by just having the barracks.
MrTweek
PostPosted: Wed Jul 25, 2012 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
i have tested it in addition to it is requied to add additional Sites like "GDIArmory" and "NodArmory" otherwise the tanks will build in the Yard (when it is primary) =)
and the
Adjacent=6
should also been setted =) Otherwise the Base must build directly on Water =)
My Problem:
But when the naval-yard is primary setted and im build a tank, then the Side-Speak says "New Construction Option" everytime =/
ShipYard=yes
is that like the behavor in RA2? (i have found it in rules.ini for TS)
ShipYard = This building is a ship yard or sub pen
Krow
PostPosted: Wed Jul 25, 2012 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm quite sure that tag doesn't work.
Team Black wrote:
MrTweek
PostPosted: Wed Jul 25, 2012 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
It Seems to be work, i have removed the weaponfactory=yes and added Shipyard=yes. The ships will produced in the Navalyard and cam out on it at all 4 Sites ^^
PostPosted: Wed Jul 25, 2012 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Shipyard=yes doesn't do anything; what allows your naval yard to produce units is Factory=UnitType.
MrTweek
PostPosted: Wed Jul 25, 2012 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahso hmm it seems the logic for ships worse removed =(
PostPosted: Wed Jul 25, 2012 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why do you think this tutorial was posted in the first place? Razz
MrTweek
PostPosted: Sat Aug 04, 2012 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
To enable Navalunits with an workaround? xD
[ Time: 0.2163s ][ Queries: 11 (0.0101s) ][ Debug on ]
