Ok this map is finaly finished i can only show finalsun pics right now because my disk drive is ruined
if you really want to have a look at it then play it and rate
EDIT: err ignore the things at the top of the first two images i don't know how that happened
Er...learning to crop your pics so it's not enormous would be wonderful. The map doesn't look bad from the screenies, but that's only goes so far in saying how the actual map is. I'd play, but RA2 and YR are all not cooperating with mah PC, so installing's not working. _________________
Well the map doesn't look too bad from the initial shots but already I can see wrong things i.e. using Special Forces as normal civilians and huts next to houses. You also don't really need those long sandbag walls which go off for miles, try to randomise things but make it believable. _________________
