Posted: Tue Feb 20, 2007 8:14 pm Post subject:
ETS Project rules
ETS Project Rules
Something here added after RPCE release.
1)
The wishlist only helps me to find good ideas.
It's not list of demands.
2)
Different ETS versions won't compatible with each other.
Yeah, I will try to make it compatible as long as possible.
but it will be always compatible with original FireStorm
3)
RP and ETS is totally different projects.
It means: no comparison between RP and ETS.
If something is done in RP, it does not mean that it will be done in ETS.
and backward.
4)
You can (and I recommend) to include ETS installer in you mod package, but only original installer.
5)
ETS don't support any illegal cracks, like No-CD cracks.
Only legal versions are supported.
6)
Bug definition:
Bug - when IE appeared, or something does not work totally, or if does not work as declared.
If something does not work as you want, it's not a bug.
Before post anything like: "Hey, ETS have a bug".
Test it at least two times.
If it cause IE you must upload except.txt file.
7)
Revisions is only fix bugs, no new features in it (this allow ETS be more stable).
If you use ETS, it mean that you agreed with rules.
If you have any suggestions or ideas about it, post it here
ETS logo thanks gamemate.
186.46 KB
31239 Time(s)
_________________ ARM forever - x86 sucks QUICK_EDIT
TSHyper has done a few modifications to the internal strings and such, like renamed files and a few menu and ingame modifications.
He says he'd be able to easily update these changes for every new version of ETS which is released, so we'd be able to work that, no problem. _________________ If there is a problem on the forums, PM me. QUICK_EDIT
Joined: 08 Feb 2009 Location: The United States of America
Posted: Mon Feb 15, 2010 7:46 pm Post subject:
Just wondering: Now that TS and FS are freeware, can you release ETS as an .exe rather than a patch to an .exe. I could never get these kinds of things to work (RP, NP, ETS, HP if I ever tried that). QUICK_EDIT
