The time now is Thu Apr 25, 2024 10:13 am
Adding new sounds, wavs to auds.
Post new topic   Reply to topic Page 1 of 1 [14 Posts] Mark the topic unread ::  View previous topic :: View next topic
IVI
PostPosted: Sat Nov 18, 2006 9:06 am    Post subject:  Adding new sounds, wavs to auds. Reply with quote  Mark this post and the followings unread
often, when you try to use Olaf Van Der Speck's winamp plug-in script to convert wavs to auds, the plug in fails to do so. This is because the frequency is different (The DvD pointed this out).
In order for the Winamp plugin to read and convert your wavs, the wav must first be in 44,100kHz to 48,000kHz 16bit Mono/Stereo. This is easily done through the Windows Sound Recorder 32 (I think even windows95 already came with this). Just open your problematic wav with Sndrec32 and click on File>Properties and then near the bottom is a part that reads Format conversion. Click on the adjacent button that says 'Convert Now' then select 44,100kHz 16bit Mono or Stereo the 16bit is very important because otherwise the winamp plug in won't read your wav file.
After executing your now 44,100kHz 16bit mono/stereo wav files with the winamp plugin, just go to your target directory and see if the converted auds are there.  Wink
I've uploaded Olaf Van Der Speck's Winamp plugin and a Sndrec32.exe so you can get started right away!  Very Happy
sndrec32exe and wavtoaud plugin.zip
 Filename:  sndrec32exe and wavtoaud plugin.zip
 Filesize:  109.85 KB
 Downloaded:  675 Time(s)
Key Words: #Tutorials #Modding #TiberianSun #Firestorm #Sounds #WinAmp #WindowsSoundRecorder #Media
Tony
PostPosted: Sun Nov 19, 2006 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice #Tongue this will help me..eventually.
IVI
PostPosted: Wed Nov 29, 2006 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
hey I found out that 22,050 kHz works too but what's important is you make sure that is 16 bit mono or stereo Smile
Navy SEAL
PostPosted: Tue May 06, 2008 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
dont know how to use it.
Welcome to the unit, I´ll see you around.
Tiberian Sun 2.05:
https://www.moddb.com/mods/tiberian-sun-205
View user's profile Send private message Send e-mail ModDB Profile ID
Navy SEAL
PostPosted: Tue May 06, 2008 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I need tutorial.
Tiberian Sun 2.05:
EVA-251
Also Known As: evanb90
PostPosted: Tue May 06, 2008 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alternatively, get to the WAV file in XCC Mixer after making sure it is in the correct format for conversion, right click "Copy as AUD"
YR modder/artist, DOOM mapper, aka evanb90
Former Project Lead Developer Star Strike (2005-2012), Z-Mod (2006-2007), RA1.5 (2008-2013), The Cold War (2006-2007)
Navy SEAL
PostPosted: Wed May 07, 2008 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got it but where I can paste it.
Tiberian Sun 2.05:
GameMaster0000
PostPosted: Wed May 07, 2008 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
It will auto paste into XCC Mixer's folder.
PostPosted: Thu May 08, 2008 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not clipboard copy... and you can make it copy to any place you want if you pull open the second file browser:
(this works in both directions, but you can't copy straight into an opened mixfile)
Navy SEAL
PostPosted: Thu May 08, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
And where is that ( not in Program Files it isnt.
Tiberian Sun 2.05:
PostPosted: Thu May 08, 2008 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't you know where you copied/installed your XCC Utils? How do you start them if you don't know the path to the exe?
A Windows file search to find your lost file can help too. Wink
Navy SEAL
PostPosted: Thu May 08, 2008 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know where it is but there is no aud file.
Tiberian Sun 2.05:
PostPosted: Thu May 08, 2008 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gah!
I just posted how you control where it ends up!
It will be copied wherever the second file browser is located. Just pull it open in XCC Mixer, right click in it and select "Explore", and you got the folder.
OrangeNero
PostPosted: Sat Nov 30, 2013 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
5 years later Audacity could do the job too couldn't it? Setting it to 16bit 44,100kHz and then export as WAV to then convert with the XCC mixer to aud.
Free Tibed!
[ Time: 0.1672s ][ Queries: 13 (0.0088s) ][ Debug on ]
