The time now is Sat Apr 20, 2024 1:34 pm
[RA2-YR] Cold Winter [2]
truefeel
Rocket Cyborg
PostPosted: Sun Sep 03, 2006 4:04 pm    Post subject:  [RA2-YR] Cold Winter [2] Reply with quote  Mark this post and the followings unread
Hi all.
I'm a long time mapper; some may know me from ROTS; I made a map for Holy Master. I just finished making maps that can be released publicilally.
Before I go deeper into this map, I first wanna say that my maps are NOT made for battles vs. AIs. I made them clearly for online battles and the AI is just too dumb to the necessary things needed on those maps.
About the map:
this is a cliffy, snowy map. It kinda reminds you on Snow Valley, but also a bit on Heck Freezes Over. It's infact a mix of so much maps. You start on a cliff, with a small patch of gems and a medium sized ore field in the envoriment. Gems and ore are everywhere to find, the problem is reaching them. the ore and gems near your starting position are easy to harvest, but you need base walk for the rest. In the middle, there's a good amount of gems; you need to basewalk completely down into the valley to get them. In that same valley, there are also 4 derricks. There are also 2 small towns, in each an airport. The buildings around can be protection or the dead for the airport, depends if you do are don't garrison those buildings. The map is at the same time a rushing map and it can turn out into a basewalk fight.
Minimap:
some screenies:
I have putted both a YR and a RA2 version in the file Smile.
EDIT: screenies added.
coldwinter.zip
 Filename:  coldwinter.zip
 Filesize:  202.87 KB
 Downloaded:  1373 Time(s)
truefeel
Rocket Cyborg
PostPosted: Mon Sep 04, 2006 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
common people. i don't posted those maps here for nothing.
Viper
PostPosted: Thu May 10, 2007 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
zomg no1 sed anythin, thats a nice map Smile
ORCACommander
PostPosted: Thu May 10, 2007 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
do I have to ask why you bump these old topics?
[ Time: 0.1771s ][ Queries: 13 (0.0092s) ][ Debug on ]
