The time now is Wed Apr 24, 2024 11:10 pm
[TS] Nod Scorpion Super Heavy Walker (MMKII is history)
Moderators: Global Moderators, Media Hut Moderators, OpenRA Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Post new topic   Reply to topic Page 1 of 1 [23 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Sun Aug 20, 2006 4:38 pm    Post subject:  [TS] Nod Scorpion Super Heavy Walker (MMKII is history)
Subject description: elite nod unit
Hi
This is a unit i've made and already posted on tiberiumsun.com.
Its a giant scorpion for Nod as a Walker unit with 8 legs
It comes with a 20 Frames walking animation
8 Standing Frames
40 Deathframes (yeah it gets destroyed spectacular, i think) + unique explosion separated in two stages (take a look at my example code how this works)
40 Firing Frames for each of the 8 facings (charge up animation for very heavy Laser Cannon mounted on the tail)
1 Build-menu Icon
1 Hit animation for the laser cannon
use it as you want, but if you release a mod using this unit, I would like to see a little note that it is from me. Smile
here comes the code for art rules and sound ini for a faster implementation. but its only an example
oh before i forget it. the unit uses FiringSyncFrame1= and that is as far as i know a firestorm command. means, that it is possible that only with firestorm installed the firing animation is perfect syncronized to the weapon firing. i dont know how it is if someone only has TS. but if you have FS it is usable in TS too.
art.ini
[SCORPION]
Voxel=no
Remapable=yes
Cameo=SCORICON
PrimaryFireFLH=140,0,300
Facings=8
WalkFrames=20
StandingFrames=1
DeathFrames=40
DeathFrameRate=3
StartWalkFrame=0
StartStandFrame=160
StartDeathFrame=488
MaxDeathCounter=256
FiringFrames=40
StartFiringFrame=168
FiringSyncFrame1=25
[SCDETH1X];Scorpion Walker Destruction Prepare Explosion
Normalized=yes
Translucent=no
Report=EXPNEW09
UseNormalLight=yes
Rate=500
Next=SCDETH2X
[SCDETH2X];Scorpion Walker Destruction Final Explosion
Normalized=yes
Translucent=yes
Translucency=75
Report=HUGEEXP1
UseNormalLight=yes
Crater=yes
Scorch=yes
Rate=500
[SCEXPLO];Scorpion Walker Laser Explosion
Normalized=yes
Translucent=yes
Report=EXPNEW09
UseNormalLight=yes
Crater=yes
Scorch=yes
[SCEXPLOINIT];Scorpion Walker Laser Explosion
Image=none
Elasticity=0.0
MinZVel=0.1
MaxXYVel=1
ExpireAnim=SCEXPLO
Spawns=SCEXPLOWAVE
SpawnCount=500
LoopStart=0
LoopEnd=1
LoopCount=0
Rate=0
DetailLevel=0
RandomRate=0,0
Bouncer=yes
[SCEXPLOWAVE];shockwave damage effect
Image=none
Elasticity=0.0
MinZVel=1.0
MaxXYVel=100.0
ExpireAnim=INVISO
Damage=0   ;inviso already has 1 damage, thats enough
DamageRadius=50
Warhead=SuperScorpion
LoopStart=0
LoopEnd=8
LoopCount=-1
Rate=500
DetailLevel=0
RandomRate=220,500
Bouncer=yes
rules.ini
[VehicleTypes]
66=SCORPION
[Animations]
841=SCEXPLOINIT
842=SCEXPLOWAVE
843=SCEXPLO
844=SCDETH1X;Scorpion Walker Destruction Prepare Explosions
847=SCDETH2X;Scorpion Walker Destruction Final Explosion
[Warheads]
53=SuperScorpion
[SCORPION]
Name=Score-P-Ion ;okay its only a beta version name, find a better one
Prerequisite=NODFACTORY,NARADR,NATECH,NATMPL
Primary=ScorpionLaser
Elite=ScorpionLaserElite
Strength=1000
Category=AFV
Armor=concrete
TechLevel=9
Turret=no
IsTilter=no
TargetLaser=no
TooBigToFitUnderBridge=true
Sight=10
Speed=3
SelfHealing=yes
CrateGoodie=no
Crusher=yes
Owner=Nod
Cost=2500
Points=25
ROT=5
Explodes=no   ;if yes death-anim makes more and more damage
Explosion=SCDETH1X  ;use his own explosion
VoiceSelect=drrpsel1,drrpsel2,drrpsel3
VoiceMove=drrpmov1,drrpmov2,drrpsel1,drrpsel2
VoiceAttack=drrpatk1,drrpatk2,drrpatk3,drrpatk4,drrpsel3,drrpsel1
VoiceFeedback=
MaxDebris=4
DebrisTypes=PIECE,GASTANK
DebrisMaximums=2,2
Locomotor={55D141B8-DB94-11d1-AC98-006008055BB5}
MovementZone=Destroyer
ThreatPosed=15   ; This value MUST be 0 for all building addons
Weight=3.5
VeteranAbilities=SELF_HEAL,STRONGER
EliteAbilities=SENSORS
Accelerates=false
ImmuneToVeins=yes
BuildLimit=2
[ScorpionLaser]
Damage=200
ROF=150
Range=10
Speed=100
Report=MOBEMP1
LaserInnerColor = 255,175,175
LaserOuterColor = 255,0,0
LaserOuterSpread= 20,40,40
LaserDuration = 20
Projectile=LLine
IsBigLaser=true
IsLaser=true
Charges=yes
[ScorpionLaserElite]
Damage=300
ROF=150
Range=13
Speed=100
Report=MOBEMP1
LaserDuration = 25
Projectile=LLine
IsBigLaser=true
IsLaser=true
Charges=yes
[SuperScorpion]
Spread=1024
Verses=100%,100%,100%,100%,100%
InfDeath=5
Tiberium=yes
ProneDamage=60%
Sparky=yes
AnimList=SCEXPLOINIT
sound.ini
[SoundList]
400=hugeExp1
[hugeExp1]
Priority=75 ; this one is rare, so it must come when its time
Volume=1.0
scorpion ingame showing the standing frames
some firing frames
some walking frames (it makes dust while walking)
 Filesize:  229.34 KB
 Viewed:  29156 Time(s)
build menu icon
 Filesize:  3.31 KB
 Viewed:  29157 Time(s)
scovoice.zip
the voice effects i used in the example code (for those who are interested)
BUT its in german.
 Filename:  scovoice.zip
 Filesize:  76.04 KB
 Downloaded:  1172 Time(s)
hugeExp1.zip
explosion sound effect for destruction (used in my example code)
 Filename:  hugeExp1.zip
 Filesize:  52.25 KB
 Downloaded:  1164 Time(s)
LKOscorpion30.zip
zio with
scorpion.shp (the unit)
scoricon.shp (cameo)
scdeth1x.shp (death explosion stage 1)
scdeth2x.shp (death explosion stage 2)
scexplo.shp (weapon explosion)
 Filename:  LKOscorpion30.zip
 Filesize:  837.42 KB
 Downloaded:  1968 Time(s)
Blade
PostPosted: Sun Aug 20, 2006 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the record, if you have the latest TS patch you can use any FS code in TS without any problems.
Lee
Jumpjet Infantry
PostPosted: Sun Aug 20, 2006 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
:O Nice.
Folio.
Tratos
PostPosted: Sun Aug 20, 2006 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Next to the preview shot with the size comparison of the tick tank, whats that little insect looking unit?
PostPosted: Sun Aug 20, 2006 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
thats my Nod Cobra. a fast walking/running medium mech.
i already posted that too on tiberiumsun.com.
Alex06
PostPosted: Mon Aug 21, 2006 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
The attack animation has a remappable ball when it fires, which has a black outline and looks bad when it is very dark. You should fix that...
PostPosted: Mon Aug 21, 2006 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
how
removing it and instead make it as a firing animation isn't possible because it doesn't charge up before the weapon fires.
and to remove the dark outline is a problem to, because it is a light effect with glowing light source that gets rendered in front of a black background. so it always fades into the dark background.
IVI
PostPosted: Mon Aug 21, 2006 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
That's uber amazing!!! and to think that it's all SHP too! I have to say that that is the coolest and best made SHP I've ever seen yet!! Surprised
I made a stealth tank and called it 'Sting' and I thought it was rather good; but it surely pales in comparison to your scorpion vehicle! Very Happy
Alex06
PostPosted: Mon Aug 21, 2006 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lin Kuei Ominae wrote:
how
Use the RA2 unittem.pal palette in SHP builder, it has a blue background instead of a black background, and uses all the same colors as the TS unittem.pal palette. That way you could try to remove the outlines, and also, I wouldn't mind this unit not having that ball when it attacks, look at the Obelisk of Light, no red glowing ball when it fires either...
ReFlex
Disk Thrower
PostPosted: Mon Aug 21, 2006 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Holy shit, this unit kicks ass!
View user's profile Send private message Visit poster's website YouTube User URL
Darentei
PostPosted: Wed Aug 23, 2006 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I see you posted it here, oh master of SHPs.
When was the last time you checked TumSun? I think you should do just that.
PostPosted: Wed Aug 23, 2006 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks
it's not that long ago (yesterday i think). i'm not one of those who post each day in each thread they find, only a comment like "could be better" or "i like this". I do like more the constructive critism. That doesn't says that i dislike good comments on my units Very Happy
i think today in the evening or tomorrow i have a new unit ready for posting it there.
Grievous
Disk Thrower
PostPosted: Wed Aug 23, 2006 6:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the chassis should be larger to support that fat tail, but very good work.
If the world didn't suck, we'd all fall into space...
Von Kriplespac
PostPosted: Wed Aug 23, 2006 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I fuggin Agree! Shocked
Darentei
PostPosted: Thu Aug 24, 2006 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I meant check out some of the comments and maybe reply to them... You haven't done that in weeks.
pd
PostPosted: Thu Aug 24, 2006 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
O M G, that thing pwnerz!! thumbs up, awesome work!
PostPosted: Thu Aug 24, 2006 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
this unit is a friggamaister! excelent work! I guess you could work with the fire anim though, I don't like when it turns out yellow.
PostPosted: Thu Aug 24, 2006 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
then it would fade into a blue outline. i don't think i'm going to remake the fire anim soon. At least i like it that way, even with the black ball that starts glowing red. Perhaps one day i feel like redoing that but not now. sorry. In addition i wanted it's anim sth special compared to the already known one from original units/buildings. btw i have a new idea coming in my mind that removes the outline at all, but i will see when i make this or even if.
hmm, i'm not someone for much small talk. even if i don't answer every comment i read them all and am thankful for all the great comments.
the reason why i did it remappable is, because this is the only pure red colorsceme. else it would have become a mix of yellow, gold and red.
TS
PostPosted: Sun Aug 27, 2006 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow...Surprised That SHP is amazaing, nice work man. What did you make it with?
View user's profile Send private message Send e-mail Yahoo Messenger Account AIM Address
Darentei
PostPosted: Sat Sep 02, 2006 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll remake the fire anim, the one from on the end of the tail, at least. Or I'll try.
Devine Eclipse
PostPosted: Wed Jan 09, 2008 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thats got to be the best unit I've ever seen especially an Shp unit. I guess if i had to critique it, the only thing i would change is the amount of legs, but dont mind me thats brilliant. 5 freaking stars dude!
Tourist: A person who travels a thousand miles to get a picture of himself standing by his car.
Tartan Bunny
Flamethrower
PostPosted: Wed Jan 09, 2008 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Try not to bump topics unless you have something constructive to say. Hey, your new, and i used to do it as well Laughing
PostPosted: Wed Jan 09, 2008 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
TB, stop being a ass hat to the guy, your the one making yourself look stupid...
[ Time: 0.2036s ][ Queries: 15 (0.0120s) ][ Debug on ]
