Posted: Sun May 07, 2006 4:16 pm Post subject:
A never seen before Tesla Zap
Subject description: My homemade Tesla Zap with the help of the SHP Railgun Tutorial
This is my first post on this forum
OK im am a long term visitor of this forum and registered today.
I Think its very wierd that I havent seen this particle system in any other modifications than my home made one, the only others i have seen is one that uses EMP particles with a Flame Thrower particle system and laser based that is not even close to this one. So I created my own one when the SHP Railgun tutorial for RA2 was published.
Íve made a Tesla Zap much like in Redalert1 or in Redalert2 by the help of the Tesla .shp file in Redalert1 and the SHP Railgun tutorial made by Gamemate for Redalert2 in the RA2 Tutorials Vault at: http://www.ppmsite.com/forum/viewtopic.php?t=4825
Here is the code if you want to use it:
; RULES.ini
[Animation]
XXX=TSTIMPCT ;From Redalert2
[Particles]
XX=TeslaZapSpark
[ParticleSystems]
XX=TeslaZapSys
[Warheads]
36=Electric ;alt naming "Shock"
;Altenate Weapon names: CoilBolt OPCoilBolt TeslaZap TTankZap PortaTesla TTankBolt ElectricBolt, and dont forget elite versions ending with E
[TankBolt]
Damage=1 ;needed for the animation at impact point (warhead anim)
AmbientDamage=40 ;choose this value
; use this for the railgun damage field. Leave damage = 0
ROF=5 ;ROF for railgun is tied to the duration (MaxEC) of the railgun particle ;higher value for slower reload rate
Range=7 ;choose this value
Projectile=InvisibleZap
Speed=100
Bright=yes
Warhead=Electric ;Shock
Charges=yes ;Optional ;for buildings with charge anim ;see problem section
Report=TESLA1 ;the old Redalert1 tesla Sound
Bright=yes
IsRailgun=true
AttachedParticleSystem=TeslaZapSys
Burst=2 ;for Twiln Coiled units like the Redalert2 Tesla Tank
[InvisibleZap]
Inviso=yes
Image=none
High=yes ;optional if it works at all
IgnoresFirestorm=yes
AA=yes ;optional for AntiAircraft if unit has a Standing Coil/Barrel
[TeslaZapSys]
BehavesLike=Railgun
HoldsWhat=TeslaZapSpark
SpiralRadius=40 ;can be too wide with 50
ParticlesPerCoord=.02
Laser=yes
LaserColor=255,255,255 ;R,G,B for laser color ;the Zap will make a white line to mimic the effect in Redalert2 a little
[TeslaZapSpark]
BehavesLike=Railgun
BehavesLike=Smoke
MaxEC=8 ;dont use less than 8 (best) or more than 10
Image=TBLST2 ;from Redalert1
Translucency=25 ;optional
Velocity=0.0
EndStateAI=20 ;required
StateAIAdvance=3 ;not required ;you will notice a small (worse) graphical difference without this
dont forget to add TESLA1 sound entries in the Sound.ini or Sound01.ini
also dont forget to add the .shp files into a ecacheXX.mix file and the Sound hopefully into a SoundXX.mix file
There is also a couple of issues with this one:
1. Buildings with charge anims cant use this one, the result is totaly bugged charge anim. The problem can be seen with all Railgun based weapons
2. It works the best with single barreled units becaus it looks more cool if the unit is rapidly firing. If the unit has twin Coils/barrels like the Tesla Tank in RA2 the Zap will altenate between the Coils and has to wait untill the Zap has dispated untill its able to fire from the secondary Coil
3. The Third problem is that the railgun particle system zaps gets stopped by hills and cliffs like Railguns but is still able to do damage if its based on Damage and not Ambientdamage[/url]
My RA2 based Tesla Tank firing to show the effect of the Tesla Railgun Particle System. Note that it looks even better in dark maps or enviroments
245.22 KB
12892 Time(s)
Tesla anim and sound.zip
Tesla Sound from Redalert1, warhead impact anim from RA2 and the Tesla Zap animation from Redalert1
it's not a bumping, he asks something.
I used bits of this to make my blue laser and I remember I crashed the game many many times when testing it. Particles and Particles system are rather sensible. I guess the problem lay there :
[TeslaZapSpark]
BehavesLike=Railgun
BehavesLike=Smoke
try :
[TeslaZapSpark]
BehavesLike=Smoke QUICK_EDIT
Gufu stop posting crap in all the threads I write in and others too. . Ive seen most of your post and most of them are pure crap. This is not MSN dude.
And Worm4981 I like the white laser line in the middle if you see this
I dont want to be another bump master but I really do advisde you to use a tesla animation in Unittemp pallette and simply use the alt pallete tag in art.ini and it will look much more bright blue instead of being shaded down. _________________ QUICK_EDIT
Gufu has been really annoying here in PPM, he has been annoying lately and when i made my first post on PPM he already told me that i was bumping <.<
Back to Topic-
Those Tesla shocks are cool but the laser line in the center makes it look like a laser with electric shocks coming out of it but still cool _________________ Please, I DON'T read the signature rules of the forum. QUICK_EDIT
The animation empfx01 looks better _________________ 0h noez!11!!! one 11!! U just p00rd n00bs@uc3 a11 0v3r my l33t sk1llz!!!!!!11one!!111!!!one111!!!!!!!
[img]http://ppmsite.com/forum/viewtopic.php?t=16541[/img] QUICK_EDIT
