Joined: 22 Nov 2010 Location: Iszkaszentgyorgy, Hungary
Posted: Mon Mar 30, 2015 12:28 pm Post subject:
Could you render a buildup for this? (without turret, simple popup is okay) Would use as a mercenary barracks. _________________ "If you didn't get angry and mad and frustrated, that means you don't care about the end result, and are doing something wrong." - Greg Kroah-Hartman
Contributions: EE Fixpack | Enhanced Edition Trilogy | DSotSC (Trilogy) | UB_IWD | SotSC & a lot more... QUICK_EDIT
Search for a basic tutorial, even a simple buildup where the objects come out of the ground at different times would do the job. With those textures you don't even need to do anything complex, make some simple movement and it will look great.
Otherwise, if you could turn it into a 3ds scene file, I could do the animation. It would be a waste if this beauty doesn't get his buildup anim. QUICK_EDIT
Uhh, I haven't researched what meshes are, try turning into a poly if it gives you trouble, I believe you should have none.
Try moving the slider that says 0 / 74 and see if something happens, if not then just make an animation yourself, press the autokey button, select the WHOLE model and press the key (literally a key that's next to the autokey button), then move the slider to another time, move the model aswell, and press the key again, that's the basics of animating, the objects you selected will move from one point to the other in the time between the two frames you selected.
Sorry, my english got a little rusty in that last pharagrahp. Try it a few times, if you need more help, pm me.
The fun of 3ds max comes when you make a box and make it an editable poly / mesh, try it, you'll have fun
Posted: Tue Mar 31, 2015 2:18 pm Post subject:
Looks solid. Good job on a first. _________________ "If you didn't get angry and mad and frustrated, that means you don't care about the end result, and are doing something wrong." - Greg Kroah-Hartman
I agree, if you want to practice more, try moving the keys on the time slider, you can copy keys with shift click. Also try the link option, an object that has been linked to another will suffer all the transformations that the parent suffers, that will help you make the building pop up by parts. _________________
You cannot post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
