The time now is Sat Apr 20, 2024 7:49 am
Map Conversion Tutorial
Moderators: Global Moderators, OpenRA Moderators
Phrohdoh
PostPosted: Thu Mar 12, 2015 11:16 pm    Post subject:  Map Conversion Tutorial Reply with quote  Mark this post and the followings unread
This tutorial on github via gist.
=== Information ===
Author: Taryn Hill <Phrohdoh@gmail.com>
Date: 12th March, 2015
If you want to convert TS maps you need to have the TS mod installed.
If you want to convert RA2 maps you need to have the RA2 mod installed.
<mod id> = ts or ra2
In the provided examples I prefix the lines I am adding with a +.
Do not include this + in your file.
If you have any questions, comments, or concerns please do not hesitate to email me.
=== Section I: Convert TS/RA2 tilesets to OpenRA ===
1) Read 'Section III'
2) Run `OpenRA.Utility.exe <mod id> --extract <tileset name>.ini`
   temperate.ini,
   urban.ini,
   snow.ini,
   etc..
3) Run `OpenRA.Utility.exe <mod id> --tileset-import <extracted file>`
   When you run this command you will need to pipe the result into a file, example:
   OpenRA.Utility.exe ra2 --tileset-import urban.ini > tilesets/urban.yaml
4) Open mod.yaml and add a path (relative to the root of OpenRA) to your new file,
   to the Tileset section, example:
   TileSets:
       ./mods/ra2/tilesets/temperat.yaml
       ./mods/ra2/tilesets/snow.yaml
     + ./mods/ra2/tilesets/urban.yaml
5) Open sequences/misc.yaml
   Add a sequence block like the others for your new tileset type, example:
   You may have to tweak the `Offset` values.
   build-valid-snow: place
       Start: 0
       Offset: 0, -15
 + build-valid-urban: place
     + Start: 0
     + Offset: 0, -15
You should be done now.
=== Section II: Convert TS/RA2 maps to OpenRA ===
2) Run `OpenRA.Utility.exe <mod id> --import-ts-map /link/to/your.map`
3) Navigate to the mod directory (at mods/ts/, or mods/ra2/)
4) Make these changes (adjusted to the correct values):
   Open the newly created map.yaml in maps/<map name>/
   Change `Tileset: TEMPERAT` to the correct tileset.
You should now be able to play your converted map
=== Section III: Building OpenRA ===
1) Download and extract https://github.com/Phrohdoh/OpenRA/archive/map-ed.zip
2) Build OpenRA:
   Linux / OS X: Open your shell and cd to the root of the extracted files then run `make dependencies`, `make`
   Windows: Run make.cmd, use the commands `make dependencies` then `make`
That should be all you need to build the engine and utility.
Key Words: #Tutorials #OpenRA #Mapping #OpenRAUtility
PostPosted: Fri Mar 13, 2015 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
This isn't really about this tutorial specifically but there probably should be a tutorial section for OpenRA. I might put some easy stuff up there to get people started if it is created.
[ Time: 0.1474s ][ Queries: 11 (0.0075s) ][ Debug on ]
