The time now is Thu Apr 25, 2024 11:05 am
Help me code this Mech please
Moderators: Global Moderators, OpenRA Moderators
Post new topic   Reply to topic Page 1 of 1 [15 Posts] Mark the topic unread ::  View previous topic :: View next topic
Holy_Master
PostPosted: Tue Feb 24, 2015 2:07 pm    Post subject:  Help me code this Mech please Reply with quote  Mark this post and the followings unread
Ok first feel free to use my mech in your mod if you want [but not sure how well he work in real game].  Razz
*Note*This mech optimize to use for TD
Download Here
http://www.sleipnirstuff.com/forum/download.php?id=27637
but I'll be glad if anyone can help me to code him to the game. everything seem fine only real problem is his move animation didn't work with current code he still slide along the ground like TD tank with no animation. [Make me wonder do this engine already support to make mecha unit if not my sprite should be helpful]
and another problem i have is about unit "local offset". Ok i know what is this code but i just not sure which Number is FLH since it not mention in Tutorial.
behe:
idle:
Start: 0
Facings: 32
run:
Start: 32
Length: 8
Facings: 32
Tick: 100
turret:
Start: 288
Facings: 32
muzzle: gunfire2
Start: 0
Length: *
icon: htnkicnh
Start: 0
and i'll be more grateful if anyone help me answer my question in this topic because it really important for my project specialize unit design stage.
http://www.sleipnirstuff.com/forum/viewtopic.php?f=83&t=17070
Thank you everyone for help.
PostPosted: Tue Feb 24, 2015 4:20 pm    Post subject: Re: Help me code this Mech please Reply with quote  Mark this post and the followings unread
This is the Titan code from their TS mod:
mmch:
   stand:
      Start: 0
      Facings: -8
      Stride: 15
      ShadowStart: 152
   run:
      Start: 0
      Length: 15
      Facings: -8
      ShadowStart: 152
   turret:
      Start: 120
      Facings: -32
   muzzle: gunfire
      Start: 0
      Length: *
   icon: mmchicon
      Start: 0
Holy_Master
PostPosted: Tue Feb 24, 2015 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
doesn't seem much different from what i code only different is Titan move direction on shp is reverse [since he is TS unit] and have 8 facting while my Mech have 32 facing.
PostPosted: Tue Feb 24, 2015 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
You do use tabs there right? YAML is picky about indentation.
Holy_Master
PostPosted: Tue Feb 24, 2015 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes the real code have tab.
PostPosted: Tue Feb 24, 2015 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe try stand: instead of idle:?
Holy_Master
PostPosted: Tue Feb 24, 2015 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
no i can't use stand: without idle: it just make the game crash. even use both code still show nothing different.
PostPosted: Tue Feb 24, 2015 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm probably wrong with that then. Although you could look at the debug log to be sure.
You should probably post the mech's code, not just the sequence. The way it's acting, I'm thinking there's an issue with the rendering trait.
Holy_Master
PostPosted: Tue Feb 24, 2015 10:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I decide to post only Sequence code since all problem i have is move animation not working while other function seem work normally. here is my rule code.
BEHE:
Inherits: ^Tank
Valued:
Cost: 1000
Tooltip:
Description: Heavily Artillery Walker. \nHas heavy armour.\n Strong vs Buildings. \n Weak vs Aircraft.
Buildable:
BuildPaletteOrder: 80
Prerequisites: anyhq, ~techlevel.medium
Queue: Vehicle.GDI
Mobile:
Crushes: wall, heavywall, crate, infantry
Speed: 50
ROT: 3
Health:
HP: 1000
Armor:
Type: Heavy
RevealsShroud:
Range: 6c0
Turreted:
ROT: 3
Armament:
Weapon: Beheshell
Recoil: 170
RecoilRecovery: 42
LocalOffset: 900,180,340, 900,-180,340
MuzzleSequence: muzzle
AttackTurreted:
WithMuzzleFlash:
RenderUnit:
WithTurret:
AutoTarget:
SelfHealing:
Ticks: 10
HealIfBelow: 50%
DamageCooldown: 200
LeavesHusk:
HuskActor: BEHE.Husk
Explodes:
Weapon: UnitExplodeSmall
EmptyWeapon: UnitExplodeSmall
Selectable:
Bounds: 34,34,0,-3
PostPosted: Wed Feb 25, 2015 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, ok. I suspect your problem is that you're using the trait RenderUnit. Try using RenderInfantry which renders animations. That's what the Titan uses and hence why it has a stand entry instead of an idle one. You could also specify the stand animation if you don't like changing idle but it seems easier this way. So change idle to stand and RenderUnit to RenderInfantry like this:
behe:
stand:
Start: 0
Facings: 32
run:
Start: 32
Length: 8
Facings: 32
Tick: 100
turret:
Start: 288
Facings: 32
muzzle: gunfire2
Start: 0
Length: *
icon: htnkicnh
Start: 0
BEHE:
Inherits: ^Tank
Valued:
Cost: 1000
Tooltip:
Buildable:
Queue: Vehicle.GDI
Mobile:
Speed: 50
ROT: 3
Health:
HP: 1000
Armor:
Type: Heavy
RevealsShroud:
Range: 6c0
Turreted:
ROT: 3
Armament:
Weapon: Beheshell
Recoil: 170
RecoilRecovery: 42
AttackTurreted:
WithMuzzleFlash:
RenderInfantry:
WithTurret:
AutoTarget:
SelfHealing:
Ticks: 10
HealIfBelow: 50%
DamageCooldown: 200
LeavesHusk:
Explodes:
Selectable:
Bounds: 34,34,0,-3
Holy_Master
PostPosted: Wed Feb 25, 2015 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
wow! Ok now It alive.. It aliveeeee !!!  Muha ha ha!!
Thank you very much. now i need to fix his remap.  = ="
Holy_Master
PostPosted: Wed Feb 25, 2015 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK now I fixed his remap color [Thank to Apollo]  this's perfect version of him. feel free to use it in your mod but since i design it for TD it can be limit for your mod.
behe.zip
 Filename:  behe.zip
 Filesize:  185.87 KB
 Downloaded:  17 Time(s)
PostPosted: Thu Feb 26, 2015 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I'm glad you got it worked out. For future reference, the OpenRA IRC is a great place to get quick help with something. There are usually a few of the devs there to help out.
Holy_Master
PostPosted: Sat Feb 28, 2015 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
for weird reason the game not allow me add new graphic for projectile.  i just try to put Ra fire ball into TD.  completely no idea why.
this's how i did.
[Add to Sequences--->misc]
fireb1:
idle:
Start: 0
Length: *
fireb2:
idle:
Start: 0
Length: *
[Add to mod root-->weapons]
FireballLauncher:
ReloadDelay: 65
Range: 5c0
Burst: 2
BurstDelay: 20
Projectile: Bullet
Speed: 204
Trail: fireb2
Image: fireb1
Warhead@1Dam: SpreadDamage
Spread: 213
Damage: 50
DeathType: 5
Versus:
None: 100
Wood: 50
Light: 75
Heavy: 25
Concrete: 50
Warhead@2Smu: LeaveSmudge
SmudgeType: Scorch
Warhead@3Eff: CreateEffect
Explosion: med_napalm
ImpactSound: flamer2.aud
log.zip
 Filename:  log.zip
 Filesize:  30.68 KB
 Downloaded:  7 Time(s)
Holy_Master
PostPosted: Sat Feb 28, 2015 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry for double post just wanna tell my problem is solve. [it cause from wrong size of shp it self which i have no idea why however it work now]
[ Time: 0.2367s ][ Queries: 13 (0.0105s) ][ Debug on ]
