The time now is Fri Mar 29, 2024 10:29 am
Open Source SHP Builder: Information
Post new topic   Reply to topic Page 2 of 2 [87 Posts] Mark the topic unread ::  View previous topic :: View next topic
Goto page: Previous 1, 2
tomsons26lv
PostPosted: Sat Dec 07, 2013 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried just reinstalling in the same folder i started the exe now i'm getting
Access violation at address 00405FB9 in module 'SHP_Builder.exe'. Read of address 00000000.
Access violation at address 004058E2 in module 'SHP_Builder.exe'. Read of address 01573050.
almost everytime i start it
Also all cameoBG files are 0kb and the commlist is still the wrong file(its a xml)
Tiberian Dawn, Red Alert, Tiberian Sun ,Red Alert 2,Renegade, Command & Conquer 3,Tiberium and Tiberium Wars and Westwood related image & video archive
https://picasaweb.google.com/113361105083292812413?noredirect=1
Skype live:tomsons26
Don't forget to state who are you otherwise i'll ignore the invite
tomsons26lv
PostPosted: Sat Dec 07, 2013 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Forgot to mention,i ran it as Admin when I installed it
PostPosted: Sat Dec 07, 2013 7:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Delete all these files and re-download the SHP_Builder.exe from the link from the first post.
All the bugs you've mentioned were already fixed.
tomsons26lv
PostPosted: Sat Dec 07, 2013 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am using the latest version, clean install, all those bugs are still present for me, now i get the address errors even if i copy the latest exe over a older working installation(37 beta 12 downloaded as tar from the svn)
Zaaz
PostPosted: Sat Dec 07, 2013 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm having some exceptions too. I think it has to do with write/reading the added LastPalettePath property.
PostPosted: Sun Dec 08, 2013 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I've tested installing it in the same dir and in a different dir using my windows XP and it worked correctly with no warnings/exceptions, etc so far. I'll have to test it in Windows 7 as soon as possible.
Zaaz
PostPosted: Sun Dec 08, 2013 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
@tomsons26lv
I cant post anything here, so I created a thread in beta testing. Tell me if that fixes your issues.
Im a link. Click me.
PostPosted: Sun Dec 08, 2013 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Revision 39 has a very minor attempt fix for it, although I can't test it if it fixes it, since I'm unable to reproduce this problem on my Windows XP.
Edit: I've tested revision 39 with Windows 7 and UAC. Now it always runs as administrator (the setup trick in the description has successfully fooled UAC). The installation was successfull and nothing wrong happened. When I've left the program, windows has suspected that the program wasn't properly installed, but I had to tell it that it was installed correctly. Then, I've executed the program again and I've seen one access violation message. Then, when I run it again, there are usually 2 access violations.
I still don't know what causes it. Once I return from a party, I'll test a version with a bunch of ShowMessage to be able to debug where exactly are these access violations happening and why do they only happen with Windows 7 and not with XP.
PostPosted: Fri Dec 13, 2013 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: The recent revisions from OS SHP Builder 3.37 seems to fix all installation issues reported by tomson26lv, Bittah and Zaaz and it is running quite in a stable way.
PostPosted: Fri Dec 13, 2013 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
One thing that could be improved in the installer is that it doesn't seem to accept certain keyboard commands. When I try to paste a path in it via Ctrl+V, nothing happens, while right-clicking and then clicking Paste does work. Ctrl+A also doesn't select the whole path that's already been entered (for this I need to put the mouse cursor at the beginning of the line, hold shift and then press End).
View user's profile Send private message Send e-mail ModDB Profile ID YouTube User URL Facebook Profile URL
PostPosted: Fri Dec 13, 2013 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
That seems to be a bug from the VCL TEdit component.
PostPosted: Fri Jan 03, 2014 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update 03/01/2014: OS SHP Builder 3.37 has been officially released! (revision 58)
PostPosted: Fri Jan 03, 2014 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Sat Jan 04, 2014 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
3.38 Beta is just a way to call the latest SVN build. And the latets SVN build is indeed 3.37 at the moment. So, there is no difference.
Even in the future, there won't be any difference at all, because the installer naturally downloads the latest version of the program in the SVN.
ramil16
PostPosted: Mon Mar 03, 2014 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
wish you can create a step by step video tutorial on it
PostPosted: Mon Mar 03, 2014 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Matthias M.
PostPosted: Mon Jun 16, 2014 4:22 pm    Post subject: Re: Open Source SHP Builder: Information Reply with quote  Mark this post and the followings unread
PostPosted: Mon Jun 16, 2014 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is not closed source program. It is open source and it does not cost a cent.
Go to http://svn.ppmsite.com to get the source code.
The only thing that it does not do is to follow any of the GNU GPL liscenses.
PostPosted: Mon Jun 16, 2014 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
He means SHP Builder is not a "freeware" per definition of freeware.
Since it is Open Source it should be called "Open source software" or "free software".
PostPosted: Mon Jun 16, 2014 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Edit: With all due respect, I like a part of GNU's cause, but not its means, nor its fanatism for free software. I do not support GNU.
I couldn't care less if their so beautiful definition of freeware doesn't match SHP Builder's case.
I usually understand freeware as a program that doesn't cost a cent, regardless if the source code is available or not.
Edit 2: In order to avoid confusion, I've edited the freeware part of the text.
Matthias M.
PostPosted: Tue Jun 17, 2014 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Choosing a http://opensource.org/licenses does not mean you support any ideological course. It just helps to avoid misunderstandings. Which terms have you chosen for OS SHP Builder?
PostPosted: Tue Jun 17, 2014 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
None of them and I have no plans to change that.
This program was made by Banshee and Stucuk, with contributions from PaD and VK. You can make anything with it as long as the authors receive credit for their work. If you make an unoficial patch of the program, this liscense must be unchanged and Project Perfect Mod must be credited for hosting support for the official OS SHP Builder.
Matthias M.
PostPosted: Tue Jun 17, 2014 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Tue Jun 17, 2014 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Technically speaking, the quoted lines are already a license.
PostPosted: Wed Jun 18, 2014 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Correct.
xanax
PostPosted: Tue Feb 24, 2015 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Tue Feb 24, 2015 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a link to be used by your SVN client. If you try it with the browser, it will be dead indeed.
Milch&Muesli
PostPosted: Sun Feb 12, 2017 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Banshee,
over at OpenRA.net your shp builder gets used quite frequently for sprites and custom units in the RA and TD universes for custom maps.
I planned to use this tool for a OpenRA mod map of Dune 2000 as well, but unfortunately your tool does not support the d2k palette :/
Its very similar to the palette of Tiberian Sun, but not the same. Could you please implement the d2k palette as well, so i can use the shp builder for this Westwood game as well? Wink
I could provide you with the palette.bin if required. Send me a message. I just don't know how to translate that into your custom .pal format. ^^
Thanks very much!
Reaperrr
PostPosted: Sun Feb 12, 2017 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
@Milch&Muesli:
The d2k palette.bin is just a normal, simple Westwood 6-bit palette, same as what SHP Builder uses.
All you should need to do is to rename the palette.bin to d2k.pal and copy that into the Palettes\User subfolder of SHP Builder. Then you should be able to select it.
PostPosted: Mon Feb 13, 2017 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
In truth we call it only Westwood 6-bit (or in total 18-bit) since saw it there but it is actually VGA Classic standard, not actually Westwood designed at all.
http://www.shikadi.net/moddingwiki/VGA_Palette
Milch&Muesli
PostPosted: Sun Feb 19, 2017 8:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the hints.
Importing from the images with the d2k palette selected fixed the color-issues in the editor. And exporting as shp(TS) might have fixed some issues with broken shp(TD) exports.
But still haven't had success so far. I am not sure I use the settings correctly and using TS settings for the d2k content is kind of far fetched, too Very Happy
Having d2k options for import/export would be so much better Smile  ...and i would not have to suspect any potential errors there...
PostPosted: Sun Feb 19, 2017 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you tell me what are the best options to set there when importing D2K infantry, buildings, animations and cameos, I can set profiles there to speed up the process.
Milch&Muesli
PostPosted: Fri Feb 24, 2017 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't right now, since i just recently found a way to get the shp's to work.
* using d2k custom palette from the palette.bin file for importing, optimized for TS.
* using XCC to convert the shp(TS) of SHP Builder back to png's and then into shp/shp(TD) format. Only then it works fine.
@banshee: you compare your output shp(TD) and XCC's output shp for the same file, maybe you can fix that issue with your shp(TD). XCC does it the right way.
Aftter collecting some experience with Builder I will report back Smile
PostPosted: Fri Feb 24, 2017 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you go over XCC anyway, why not convert the PNGs with XCC Mixer directly?
Just add the D2K Palette to a mix file which XCC finds, select that palette and then import the PNG frames with XCC Mixer.
CrAshB63
PostPosted: Wed Oct 13, 2021 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyway, the latest revision should fix most of the problems that were reported above. I just don't know if it solves the issues of installing things on program files without the bless from UAC, which is what I plan to test asap.
The SHP's, link seems to be down. I can't download the program.
4StarGeneral
PostPosted: Fri Oct 15, 2021 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Fri Oct 15, 2021 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Post new topic   Reply to topic Page 2 of 2 [87 Posts] Goto page: Previous 1, 2
[ Time: 0.1998s ][ Queries: 11 (0.0139s) ][ Debug on ]
