The time now is Sat Apr 20, 2024 2:07 pm
XCC Mixer file insertion in Win7, and also Descriptions!
Post new topic   Reply to topic Page 1 of 1 [27 Posts] Mark the topic unread ::  View previous topic :: View next topic
Millennium
PostPosted: Thu Nov 13, 2014 10:35 am    Post subject:  XCC Mixer file insertion in Win7, and also Descriptions!
Subject description: Two questions!
I have two questions related to XCC Mixer 1.47 (which I assume is the latest version, yes? The official site has nothing newer).
Firstly:
I'm running Win7 and inserting files into a mix simply does not work. I can drag files into the mix and it acts as if it was inserting them, but they do not actually get saved into the file. If I look at the file list in the mix right after drag-and-drop, they will not be in there. I'm assuming this is related to the user authorization obsession MS seems to have coded into Win7 (I need to confirm "run as administrator" on nearly every program), but I already have XCC Mixer set to Run as Admin and whatnot, but to no avail. Maybe I'm having it all wrong though and the cause is something different.
Does anyone know how to solve this problem?
And #2:
In XCC Mixer, there is a column labeled "Description", which is mostly empty for all mixes I've seen. Is there a way to add descriptions to files in a mix with XCC Mixer or some other method? It would greatly help me differentiate between otherwise pretty bland filenames.
PostPosted: Thu Nov 13, 2014 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
You cannot just drag-and-drop files in XCC Mixer, lol...
You need MIX Editor for that.
Also, don't modify the default MIXes.
Mig Eater
PostPosted: Thu Nov 13, 2014 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Umm o.0 yes you can, it's been a feature for about 10 years.
View user's profile Send private message Visit poster's website ModDB Profile ID YouTube User URL Facebook Profile URL Twitter Channel URL
PostPosted: Thu Nov 13, 2014 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Descriptions are only in global mix database.dat, if the file name isn't in there and in he part that relates to the game XCC thinks the mix is from, it won't show one.
PostPosted: Thu Nov 13, 2014 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
RP, a FYI, if you use Compact after editing a mix in Mix Editor, that entire mix gets corrupted, so yes, it's better to use Mixer for that - Mix Editor is only better when one creates new mixes.
Millennium, check permissions. Sounds like that. Was Mixer installed or simply copied over?
PostPosted: Thu Nov 13, 2014 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is exactly what I mean!
PostPosted: Thu Nov 13, 2014 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
@Millennium
Make sure you don't have the same mix opened twice with 2 XCC Mixer or for example while the game is running.
In such a case the mix is write protected since it is currently used by another process, and thus the added files wont be saved.
Having the game/mix files in any System folder (C:\Program files or the desktop) is a bad choice too. In stupid Windows you can be even Admin and run a program as Admin, yet the program has still no write permission in "Program Files".
Mig Eater
PostPosted: Thu Nov 13, 2014 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using FS/FA2 also locks the mix files too BTW.
Millennium
PostPosted: Sat Feb 14, 2015 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hate bringing this up again, but Mixer is still not working. I've tried running the program from an external HD as admin AND I had the mixes themselves on my external HD as well. It still didn't work.
I could work around these problems until now because Ares allows me to use shp's and voxels right from the folder without the need for mixes, but I'm now using custom palettes and those apparently can onyl be read from a mix, so that soon, I will reach the point where I can't just work around this issue.
Does anyone have any further ideas/solutions/suggestions?
PostPosted: Sat Feb 14, 2015 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
It works on Win7 both 32/64 bit. Either set the admin in compatibility for the exe files or give it when asked.
- Create new empty mix files from XCC Mixer - File menu
Using XCC Mixer
- Browse to the folder where you have kept the empty mix file and double click on the mix file. Now
local mix database.dat file should be visible inside the mix file.
- Using windows explorer, select all the files you need and drag-n-drop in the opened mix file in XCC Mixer.
- That adds the content to mix file.
Using XCC Mix Editor
- Always use empty mix files. Never use insert/delete/compact buttons.
- Run XCC Mix Editor, click open and select the empty mix file. Now local mix database.dat file should be visible
- Using windows explorer select all the files you need and drag-n-drop in the opened mix file.
- Then click Save and Close.
Millennium
PostPosted: Sat Feb 14, 2015 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am sorry, but it really does not work. I know how to use XCC, I've used those tools for years with no issues on WinXP, but on Win7, drag-and-drop simply does... nothing. The mix stays empty.
And I've run them as Admin too and given all permissions. The only thing I've not yet tried is hacktivating the actual Win7 Admin account, but I don't think that would change anything either.
PostPosted: Sat Feb 14, 2015 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
It does work on Win7, I've been using it for years. I don't have to run it with admin rights or anything.
I only know it doesn't work the when the mixes are opened by something else, like the game or FA2.
Millennium
PostPosted: Sat Feb 14, 2015 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Then... I'm at a complete loss as to what I'm doing wrong or what settings I need to change.
Mao Zedong wrote:
Our mission, unfinished, may take a thousand years.
PostPosted: Sun Feb 15, 2015 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Is your Mixer started in Admin mode, but your Windows Explorer in User mode (or vice versa)?
Windows is stupid and doesn't allows drag&drop between programs in different security levels.
Can you delete files from a mix? Do they stay deleted and does it change the mix?
PostPosted: Sun Feb 15, 2015 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
- Is your file read only or the detacheable media is read only or do you see padlock symbol on the folder icons?
- Do you login as an administrator or your user account has admin rights?
- Have you tried Control Panel -> User Accounts -> Change User Account Control Settings -> Never Notify?
- If XCC Mixer installation, mix file or mod contents are in C:\Program Files\ or C:\Program Files (x86)\ , then
move the files to a different drive and try re-installing XCC Mixer to a different drive.
Millennium
PostPosted: Sun Feb 15, 2015 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
@LKO:
I can delete files with no issues.
...how do I start Explorer in Admin mode? o_o
@E1E:
- No padlock symbol.
- I've not logged in as Admin or with default Admin Control yet. I'm going to activate Admin accounts now and try it.
- UAC is set to the lowest level.
- All files were on my external HD, not in /Program Files.
PostPosted: Sun Feb 15, 2015 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is very strange then.
If you can delete them inside a mix, you should be also able to add them.
I'm out of ideas. Sad
Millennium
PostPosted: Sun Apr 26, 2015 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Belatedly, I fixed this by accident - I renamed the game folder (but left it in the same directory), and it works now. Very strange, but I don't mind.
PostPosted: Mon Apr 27, 2015 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
What was it called before?
Do you used some crazy characters like á à â ö ä ã å æ ç  in your folder names?
I assume Mix Editor had trouble with your path name and thus could not locate the mix in the saving routine.
Millennium
PostPosted: Thu Jun 23, 2016 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I do believe that the First Decade version installs itself with a "™" added to each game folder name, so that might have been what was interfering with it.
Can that file be modified by a layperson?
PostPosted: Thu Jun 23, 2016 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
No problem with ™ in the folder name, just tried.
Global mix db file comes with XCC utilities, layperson can't modify it. I am not aware of any tool for
that. You could edit it with hex editor.
I use Total Commander as file manager, you could try some other file manager instead of Windows
Explorer.
Millennium
PostPosted: Thu Jun 23, 2016 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, the problem itself is solved by now, XCC Mixer works fine.
If it wasn't the TM, I have no idea what caused it and why changing the folder name solved it.
Thanks for the info on GMDB.dat
PostPosted: Thu Jun 23, 2016 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
The XCC source comes with code for a small util which builds the database as well as the files that it generates it from. Just grab the source, compile the libraries that it needs and then compile the tool. If you look at the code under https://github.com/OmniBlade/xcc/tree/encoding, there are more complete filename files that when built to a database cover most WW games that used mix files.
Millennium
PostPosted: Fri Jun 24, 2016 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Link is a 404, sadly.
HG_SCIPCION
Gauss Rifle Trooper
PostPosted: Fri Jun 24, 2016 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
https://www.moddb.com/mods/global-crisis
https://www.patreon.com/scipcion
View user's profile Send private message Facebook Profile URL
PostPosted: Fri Jun 24, 2016 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
The day Millenium compiles that without any help I will be impressed mildly as I think he swallowed more than can chew with average joe skills.
Millennium
PostPosted: Fri Jun 24, 2016 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah... I was going to give it a try though before I pointed out that that was not quite within my reach.
[ Time: 0.1799s ][ Queries: 11 (0.0101s) ][ Debug on ]
