The time now is Thu Apr 25, 2024 3:41 pm
Red Alert edwin Map Editor - High Resolution Patch and more
Moderators: Global Moderators
Post new topic   Reply to topic Page 1 of 1 [5 Posts] Mark the topic unread ::  View previous topic :: View next topic
FunkyFr3sh
PostPosted: Sun Jan 25, 2015 4:17 pm    Post subject:  Red Alert edwin Map Editor - High Resolution Patch and more Reply with quote  Mark this post and the followings unread
Download:
http://downloads.cncnet.org/Games/RedAlert/edwinHighRes.zip
Features:
[*]High Resolution Patch
[*]Standalone (Runs without having Red Alert installed)  -> edwin.ini -> [Options]RedalertMix= [Options]MainMix=
[*]Multiple instances are now possible, start the editor as often as you need
[*]No disk space error has been fixed
[*]No-CD patch
[*]Crash fixes
[*]Loads a new settings file named "edwin.ini" (change your resolution in there)
[*]Too fast scrollrate is fixed -> edwin.ini -> [Options]SlowerScrollRate=Yes
[*]Tile selection via mousewheel and category selection via mouse middle button
[*]Loads now a blank mega map with 126x126 size instead of 96x96 size on startup
[*]Multi-Language support -> edwin.ini -> [Options]EditorLanguage (0=English, 1=French, 2=German)
[*]Supports now loading maps via command line (drag and drop a map on top of edwin.exe)
[*]Loading maps with long filenames is now possible, the old limit of 13 chars has been raised to 256 chars
[*]External map browser has been added (RedAlertEditorLauncher.exe)
[*]Loads any custom theater (Jungle, Winter and Desert are already included)! Here is how it works:
- Lets say we create a new theater named "herpderp", you will now have to do the following things:
- 1. Add the following key to a map to enable it: [Map]Theater=herpderp
- 2. Create a mix file named "herpderp.mix"
- 3. Create your custom tiles and give them as extension the name ".her" (the first 3 chars of the theater name)
- 4. Put your custom tiles into "herpderp.mix" and move "herpderp.mix" into "raed1.mix"
RP
PostPosted: Sun Jan 25, 2015 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
You may want to check the exit routine or something, because when I closed the editor it went full CPU. Just clicked the cross in the top right and it started to eat a lot of CPU instead of actually stopping.
Mental Omega 3.0 Mission creator - Creator of FinalOmega: APYR 3.0 Map Editor
/ppm/'s stupidity
FunkyFr3sh
PostPosted: Mon Jan 26, 2015 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Eating up all cpu power (or at least 100% of one core on a multicore CPU) is normal, it happens in red alert and other games too. No idea about the other problem though, i cannot reproduce it. Does it also happen if you quit via the editor menus?
FunkyFr3sh
PostPosted: Mon Jan 26, 2015 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Multi-Language support -> edwin.ini ->[Options]EditorLanguage (0=English, 1=French, 2=German)
FunkyFr3sh
PostPosted: Fri Jan 30, 2015 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
4 crash fixes for old westwood bugs
[ Time: 0.1460s ][ Queries: 11 (0.0076s) ][ Debug on ]
